Click to call v8 installation problem on Win7 32 bit
Marco Teruzzi
Hello, I have a problem during the installation of click to call version 8 on a windows 7 32 bit OEM.
The installation goes well but the the application continue to start and stop until I remove it from PC.
Has anyone the same problem?
Thanks in advance,
Marco T
Hi Marco,
Most likely you are running to the same issue as in this post
https://supportforums.cisco.com/message/3243695#3243695
You will need to open an SR with TAC to get the ES.
It will most likely be resolved in the next maintence release.
Let me know if this helps
Thanks!
Christos
