01-20-2011 07:54 AM - edited 03-16-2019 02:59 AM
I've set up a couple of instances of CUCI-Lync on a pair of pc's which seems to be working just fine, however, when I look at the CUCM Admin the softphones aren't showing up as being registered under the Phones tab:
This doesn't seem to be stopping anything working, however, I'm a little concerned why this should happen?
UCM Version is 7.1.5.30000-1
Lync Version is - 8.5.1
Previously I had CUCI-MOC working using exactly the same Framework devices and they showed up as being registered.
Can anyone shed any light on this??
01-20-2011 10:13 AM
Your CUCI-Lync has to be in "soft phone" mode to get those registered.
If you're in "desk phone" mode, it's just using CTI to control desk phones. SIP endpoints won't register.
Michael
01-21-2011 02:08 AM
Thanks, that makes perfect sense!
