Highlighted
Participant
Closed Greeting for Unity User
Unity 11.x.  How do I set the schedule for the open and closed greeting for a user (Not a Call Handler)
Thanks in advance!
All replies rated!
Everyone's tags (2)
3 REPLIES 3
Hall of Fame Cisco Employee
Re: Closed Greeting for Unity User
If you know how to do it for a call handler, it's the exact same thing.
java
if this helps, please rate
VIP Advisor
You can create a schedule and assign that to user directly under 'Active
Schedule' field. Did I get the question correctly?
*** please remember to rate useful posts
Enthusiast
Also enable Closed Greeting for the user, otherwise Standard will be used for both open and closed times.
Content for Community-Ad
August's Community Spotlight Awards
