11-19-2012 09:11 PM - edited 03-16-2019 02:17 PM
I have CUCM Publisher and Subscriber resides at our corporate office. CUCMs are running on 8.5.1.15900-4 code.
I recently installed 2nd Subscriber at our remote office. Those 2 sites are connected via DS3 MPLS network. Bandwidth is not an issue.
Some reason, logging to the remote site Subscriber server administration pages take forever to load. I can access the Subscriber server at our Corp office works just fine. Is there a bug on the code i am on?
Solved! Go to Solution.
11-20-2012 08:15 PM
A.gooding makes a good point,
Other things that can cause slowness:
Have you checked any of these?
11-19-2012 10:35 PM
According to the SRND the latency between any two nodes must not exceed 80ms round trip. Since you have a DS3 it sounds like you have bandwidth. The question is do you have the appropriate round trip latency as well?
If you login to the console of the publisher, run the following command: utils dbreplication runtimestate
The round-trip ping times will be listed. Ensure it is < 80ms.
If that is fine, I'd next look for packet loss and or packet fragmentation issues.
11-20-2012 07:22 AM
The round-trip ping times is around 55-60 msec so i think i am OK.
i terminal in to the remote office server and have tried to access the server but same result.
i am running CUCM on VMWare at the remote office and Pub and Sub server on MCS server at Corp office.
11-20-2012 05:57 PM
Hi there
Is this on an mcs or ucs system. If ucs what's the vmware version. If mcs, I did have a somewhat similar experience a few years ago and after some checks my provider had specific port configs that were blocking Mac addresses which caused slowness initially and then of course db failure eventually.
Just thought I'd chime in
Ps. I also had an issue with the ucs hence the reason but this was an issue ith Irq mapping.
11-20-2012 08:15 PM
11-21-2012 07:34 AM
Thanks all for your responses.
I think LRO is the cause of my issue. It is enabled right now. Since my VM environment is mixed with Windows, i can't disable it right now. I am planning on making changes next weekend. I will post my results once i make the change.
Thanks all for your help.
11-24-2012 06:08 AM
Not even a somewhat helpful point there guy?
12-12-2012 02:24 PM
My VM guy talked to VMware support and they recommended not to disable LRO.
We are running bunch of Windows servers with this VM server. Do you know if disabling LRO feature is going affect the Windows server performance?
12-12-2012 05:08 PM
Vatter,
Cisco recommends you disable it for all UC on VMWare installations. See: http://docwiki.cisco.com/wiki/Disable_LRO
If your UC deployment has abysmal TCP performance that is why. As a general rule I disable LRO on ESXi 4.1 and 5.0 to prevent this from occuring.
Also remember to upgrade your VMWare tools on your UC servers after installing them into VMWare.
- Steven
12-12-2012 07:18 PM
Are you running any windows servers with this VM?
12-12-2012 11:23 PM
Vatter,
Yes I have run MS Windows 2003/2008 servers with LRO disabled. Namely the AQM, WFM, and CUEAC/CUBAC servers. There have been no issues I can recall when using these products.
If you are running non-UC Windows servers with Cisco UC on the same ESXi instance be sure to check the Cisco docwiki site to ensure the applications are fully supported in that mode. Also remember that over-subscribing CPU cores, RAM, and disk I/O will likely cause issues. TAC will very likely recommend you stop the practice before offering detailed support.
This page is a good place to start:
http://docwiki.cisco.com/wiki/Before_You_Buy_or_Deploy_-_Considerations_for_Design_and_Procurement
-Steven
12-13-2012 03:47 PM
Thanks for the information.. We are going to try to disable the feature this weekend.
12-18-2012 09:04 PM
We disabled LRO and I even rebuilt the server but same problem. Anybody have any other ideas?
