01-20-2010 04:59 AM - edited 03-15-2019 09:08 PM
Hello
I have a 7915 Sidecar attached to a 7962G and it will not boot it it stuck on Orange Lights.
I have read many posts about device and sidecar OS versions so I have upgraded to the following, but the problem has not been fixed:
Here are the versions I am running:
Call Manager - 5.1.3.4000-4 [i.e. 5.1 (3c)]
7962G - SCCP42.8-5-3S
7915 - B015-1-0-4
The phone's webpage shows no Expansion Module attached.
This is happening on two phones so I don't think it is faulty equipment.
Another small issue, is that I am not sure which of the following options I should set the expansion module to in CM, as far as I know there is only one module and it has 2 pages of 12 buttons:
7915 12-Button Line Expansion Module
7915 24-Button Line Expansion Module
In any case I have tried it with both options without success.
Has anyone experience of my problem? Can anyone advise me how I can go about troubleshooting?
Many Thanks
Steve
01-20-2010 05:19 AM
I might be wrong. But I don't think the CUCM version you're running recognize 7915. You should try to download the latest device pack and install it on CUCM.
Hope this helps!
Michael
01-20-2010 07:44 AM
Hello thanks for trying to help. I believe it should be supported.
From the datasheet http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/data_sheet_c78-468672.html
Table 4:
Phone Software Requirements: 8.3(5) and later
Call-Control Compatibility: Cisco Unified Communications Manager 4.2(3) SR3a, 4.3(2), 5.1(3)b, 6.1(1), 7.0, 7.1 and later; Cisco Unified Communications Manager Express 4.3/7.0 and later. Cisco Unified Survivable Remote Site Telephony (Unified SRST) 4.1 (IOS 12.4.15T) and later.
Signalling protocols: Skinny Client Control Protocol (SCCP) Software 8.3(5) and later, Session Initiated Protocol (SIP) Software 8.4(1) and later
09-06-2010 06:52 PM
hello, Is this problem solved?
