Sebastian,
Can you provide some info about the VM config that you have CUCM-BE running on your AMD system? This would be helpful to see if there is something that is more specific to my environment that is causing it to fail.
-What model processor is in your machine?
-What is the product and version of VMWare that you are running?
-What type of virtual disk?
-Is the virtual disk a thin disk?
-What size virtual disk?
-Amount of memory allocated to the VM?
-Did you install CUCM directly to the Virtual machine running on the AMD server or did you install on other hardware and image/convert it over?
-What was the exact version of CUCM media that you used to install?
As far the media check goes; I have run it every time, on multiple Cisco shipped DVDs and it passes every time. The media that I am using also installs fine on an MCS server everytime.
Thanks in advance for the additional information.
Best regards,
Mike
