CM 8.5.1 clock issue
Anju Josua
Hello all
We are facing issue with CM time
Curently we are developing CM 8.5.1.10000-26 with 2 types ip phone (6921 and 7942)
We configure CME as ntp master, and use this as our ntp server for CM
6921 clock time is true, but for 7962 type, we got the wrong time
Anybody have ideas?
Thank you for any help
Anju
8 Replies 8
ronpatel
Level 8
Level 8
Hi Anju,
What firmware version you are running in 7962 phone.
Is it happening to all 7962 phone to some 7962?
Ronak Patel
Please rate all helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi ronal
I am sorry, i write the wrong type, actually it is 7942
This is happen on all phone for 7942, my firmware is SCCP42.9-1-1SR1S
Anju
Hi Anju,
No issues.
What time zone you have defined for this phone.
You will have to use time zone which has "*" in the end. For example
Use "(GMT-6:00) America/Chicago*"  instead of non * time zone.
Ronak patel
Hi Ronak,
Sori for late respon
i already use time zone which has "*" in the end.
But the problem still happen for 7942 type
Anju
Hi Anju,
What firmware you are using in 7942 phone.
Ronak Patel
Hi Ronak,
i am using SCCP42.9-1-1SR1S
Anju
Hi Anju,
You are using almost 1.5 year old firmware. Please upgrade to 9.2.3 and see if issue is still present.
Ronak Patel
Hi, Ronak
Thank you for your advise
I already upgrade the firmware, it solved the problem
Thanks again
Anju
