Highlighted
Beginner
CM Hunt Pilot
I have configured a hunt pilot 8000 and a hunt list which has a hunt group with few DNS. These DNs have CFwd all to an external number. i could see the huntlist registered with call manager.
Problem I face is when i dial 8000 i get an engage tone.
Did i miss out anything??
Re: CM Hunt Pilot
if you're expecting to route calls using the CFA from the phones that won't work
calls routed thru hunt pilot and pilot points do not follow call forward settings for the members.
javalenc
if this helps, please rate
java
Beginner
Re: CM Hunt Pilot
Is there any alternate solution for my question?
Beginner
Re: CM Hunt Pilot
HI Guys
Any suggestions??
I want to have a hunt pilot where the hunt members have CFWd all to external number.
When i call this hunt pilot it should pick any of the hunt members and connect to the external number.
VIP Mentor
Re: CM Hunt Pilot
Why do you want to do this?
What you can do is set the CFNA on the hunt pilot to the external number, so that when none of the hunt members answer the call can be transferred to the external number..
But like Javalenc said, you cant forward calls from hunt group members
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Beginner
Re: CM Hunt Pilot
HI,
What happens for the second call when the first hunt pilot call is busy with the external number??
Objective of the hunt is to have a single common number to seize multiple lines for an outgoing calls.
Re: CM Hunt Pilot
try this and let me know
make a CTI port or CTI route point with a number and make the CFWD in the CTI to the external number
and give this CTI the aproperate patrtion and CSS that let it makes an external call
put this CTI as last line or number in ur hunt members
should works
please Rate if helpful
good luck
VIP Mentor
Re: CM Hunt Pilot
I tried adding a cti RP to a line group but ccm qont allow me..It says
"Add failed. [116] CTI Ports and CTI Route Points may not be associated with DNs that are in Line Groups"
I dont think you can add a CTI RP to a line group even with ccm 6.1.2
Re: CM Hunt Pilot
you can only add actual devices, not virtual devices to line groups (it always has been like that in any version). that won't work. the only possible thing i thought of was of using unified mobility but i haven't tried it myself if it works with
javalenc
java
VIP Mentor
Re: CM Hunt Pilot
Javalenc,
Thanks for clearifying this. I rated your posts on the previous posts.
I guess we need to audit what people post in here!
Re: CM Hunt Pilot
hey thanks for the nice rating Deji =)
about the issue being addressed on this post i just went thru the SRND to check if there was any limitation on using a line group with unified mobility and found nothing that says it would not work
oh and also there it is the list of what you can add to line groups:
Line Group Devices
The line group devices are the endpoints accessed by line groups, and they can be of any of the following types:
•Any Skinny Client Control Protocol (SCCP) endpoints, such as Cisco Unified IP Phones, VG248, or ATA 188
•SIP endpoints
•Voicemail ports (for Cisco Unity)
•H.323 clients
•FXS extensions attached to an MGCP gateway
also this:
Computer Telephony Integration (CTI) ports and CTI route points cannot be added within a line group. Therefore, calls cannot be distributed to endpoints controlled through CTI applications such as Cisco Customer Response Solution (CRS), IP Interactive Voice Response (IP IVR), and so forth
so, right now i guess the only thing to try would be the mobility manager or unified mobility config along with a line group, hope you have any of the above. if you got 6.x use unified mobility, if not mobility manager
javalenc
java
Beginner
Re: CM Hunt Pilot
Hi Team,
Its kind of an urgent issue now.....
does anybody have a solution for my question in this forum??????????????
Re: CM Hunt Pilot
u said when u put CFWD all to external number on the last member of ur hunt list dose not forward anything !
i suspect that u need to enable the off-net to off-net calls on the service parmeters on ur CM becase it is disabled by default for security issues
try to enable it and see what happne
way-2 and also after u enable it
try to make CTI route point
then make the CFW all on ur list member, to the DN number of this CTI and on that CTI make the CFWD all to an exaternal number
good luck
if worked rate if not let me know :)
Ask the Expert- Webex Hybrid Services Solutions
