CMC & FAC with LDAP PIN
W S H FERNANDO
Level 4
Level 4
I have CUCM 9.1, integrated with LDAP, I have configured FAC for some users, so these is seperate PT and CSS for each user matching exact Route pattern for FAC, can I user user PIN (End User PIN) as FAC or CMC ? so users can change their PIN using user web page, also i noneed to configure seperate PT and CSS for each user,
Please guide,
Regds
Jaime Valencia
No, FAC and CMC codes are not synced with anything, you need to change them manually via CCMadmin.
You don't need a PT and CSS for EACH user, you just need them to dial via the specific RP which has them enabled.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
