02-29-2016 04:03 AM - edited 03-17-2019 06:04 AM
I ma running CME10.5 15.4 IOS 2921 router. I have 7841 SIP phones that will not re-register themselves after a router reload/power-cycle. I have to power-cycle the phone for them to register, they will not re-register automatically. The phones maintain their extension info, but can't make calls until a phone re-boot.
AT
02-29-2016 05:31 AM
Hi AT,
If the issue is reproducible then you should get packet captures from one of the 7841's after you reboot the router. This will allow to check the packets exchanged with the CME to see which part of the registration is going wrong.
Manish
03-01-2016 03:50 AM
I discovered that SIP phones do not have a keep-alive function like SCCP?. I think you can adjust the registrar expires time to help with this.
03-01-2016 09:23 AM
Hi AT,
Are the phones on latest firmware? there are similar known issues with 78XX. If not I will recommend you upgrade to latest version and then check.
If it does not help then we will need packet capture from back of phone and "debug ccsip message" from CME to understand the issue.
Are you using DHCP? Have you tried using manual IP?
