06-08-2017 05:49 AM - edited 03-18-2019 12:15 PM
Strange issue ,
Outgoing PSTN not working with 90T or 90... pattern but working with 9T pattern..
90T or 90.... pattern are working perfectly with CSIM Start command.. not sure when not working with the physical phone..
Enclosed logs for suggestion..
Currently three phones register with CME.. i.e. Cisco 3905 , Cisco 7821 and Cisco IP Communicator..
when destination pattern is 90T or 90.... , user only able to dial 90 and after then busy tone is coming..
Solved! Go to Solution.
06-08-2017 06:32 AM
Hi Anil,
Can you try the following on the respective Voice register pools of those phones:
voice register pool 1
no digit collect kpml
Do a no create profile and create profile, reset the pool for the config to take effect.
Rajan
Pls rate all useful posts
06-09-2017 06:29 AM
Hi Anil
Replicated your scenario in the lab , you can configure the destination-pattern as 9[0]T or 0[0][0]T. if this doesn't help you can try upgrading the Ios
(rate if this helps)
06-08-2017 06:32 AM
Hi Anil,
Rajan
06-09-2017 12:51 AM
06-09-2017 02:47 AM
Hi Anil,
Did you make test call from extension 395805 ?
If yes, i could see Incoming Dial-peer as 20002. Is it a shared line on an sccp phone as well ?
Jun 9 07:20:50.112: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=395805, Called Number=, Voice-Interface=0x7FE45E9AD280,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20002
What happens when you make a call from a SIP phone extension with that config (no kpml). Please provide the below debugs for one such call along with the call details to check (calling number, called number).
debug ccsip messages
debug voip ccapi inout
Rajan
06-09-2017 03:03 AM
Yes, I made call from extension 5805.. the dial peer 20002 is automatic dial peer created by CME.. I think it has been created once u give dialplan-pattern 1 395... extension-length 4 under telephony-services... Similarly 40001 , 40002 dial peer u will see for SIP phones i.e. extention 5800 and 5801..
Also, When I am changing the destination patter to 00T or 00.... , it is behaving the same.. means after 00 it is not allowing to dial the number.. but when I am changing it to 0T or 0....., it is working.., So seems when it is matching continuous two digit no.. of any destination pattern.. then router is not waiting for next digit as per destination pattern.. and try to hit the destination and thus call is getting failing..
Give me 30 minute to collect the requested logs from router
06-09-2017 06:40 AM
after doing No digit collect KPML in voice register pool.. it started working for SIP phones.. but not for SCCP Phones..
and for SCCP Phones to work.. I had tried the option given by Sourabh and it worked for both i.e. for SIP and SCCP phones..
Will plan for IOS upgrade finally at later stage..
Great support from the team (Sourabh and Rajan) /
this forum , really helpful.
Heads off to you guys..
06-08-2017 06:52 AM
Hi Anil
Can you provide running configs for this router?
Need to verify codec negotiation between inbound and outbound dial-peers
06-08-2017 09:05 AM
Hello Saurabh,
thanks for your quick reply.. PFA requested show run..
for safety purpose, I have removed any incoming dial-peer.. so that it would not collide with any dial peer.. As per debug logs enclosed earlier the call is looping inside the CME router.. not sure why..
why a simple call I am not able to make it.. whereas everything is working perfect with 9T destination pattern..
I am not able to dial 0 after 9... as getting busy tone.. but if I will dial other then 9 then it will work.. means if I will change the dial peer destination pattern from 90........ to 9...... then I am able to dial and math the patter and call is going outside..
Actually I have to create three or four different dial peer based on India standard calling privilege..
like 0 for STD, 00 for ISD and 9 would be the access code..
kindly review the both logs (earlier and current) and suggest the changes..
@ Rajan: I will do the changes on tomorrow morning and then will share the result..
Currently I am doing the testing via CIPC phone.. and the strange part is that.. everything is working perfectly with CSIM Start command.
06-08-2017 10:30 AM
Hello Anil
You are using pots dial peer and As per the behavior of pots dial peers, it forwards digits that match a pattern.
for eg if destination pattern is 90T and you dial 90123455676 so only 123455676 will be forwarded to PSTN which is an incorrect number for PSTN. PSTN aspects 0-123455676.
when you configure destination-pattern as 9T, full 0123455676 goes and the call is connected
in your outbound dial peer towards PSTN make forward digit <value> if you want destination pattern as 90T in dial peer
06-08-2017 10:37 AM
Hello Saurabh..
I tried all permutation and combination.. and Everthing is working perfect in CSIM Start command but not on hardpone..
In hardphone only 9T pattern is working..
90T pattern is very well supported in India.. and I am trying to dial my mobile no.. which is any way will be accepted by PSTN provider.. but strage thing is that.. once I press zero after 9 then I am getting busy tone.. Not sure why it is happeing..
some bug is there or what is there..
06-08-2017 10:40 AM
Hi Anil
06-08-2017 10:45 AM
Ok.. I will provide that first thing on tomorrow morning..
Appreciate your quick response here..
90 pattern is matching.. but after matching.. it is not requesting or waiting for some other digit to dial in.. and matching to Null value dial peer or looping in between..
06-08-2017 10:47 AM
I am suspecting.. SIP Dial peer is creating some issue.. as it is created by default by CME when registering SIP Phones like in our environment cisco 3905 and 7821 IP phone are there.. would request you to have look into that also..
06-08-2017 11:01 AM
provide SIP logs also.
06-08-2017 11:14 AM
