Highlighted
Beginner
CME 10.5 SIP Phone (7841) Call Transfer Release Issue
We have a mixed SCCP and SIP phone environment running on CME 10.5 - recently upgrade to support the SIP only 7841 IP phones.
The SCCP environment is well established and all functionality works as expected. The problem comes with the new SIP phones when they receive a call and it requires transferred to another DN (SIP or SCCP) - the first part of the transfer works but the release does not as part of full-consult.
Quick Summary of the Problem:
Incoming Call to 001 > Transfer Softkey > Dial 002 to transfer > Transfer Sofkey (to release - this doesn't work!)
The problem is the call doesn't release to the new DN and the incoming call just hangs on hold on both IP phones. The softkey is visible but no matter how many times the key is pressed it's unresponsive.
Maybe I am missing a command on the voice register global configuration. Has anyone seem this problem? Can you help? Assistance appreciated.
 mode  cme
 source-address X.X.X.X port 5060
 max-dn 20
 max-pool 20
 load 7841 sip78xx.10-3-1-12
 authenticate register
 authenticate realm omniaccess.com
 timezone 23
 time-format 24
 date-format D/M/Y
 tftp-path flash:
 file text
 create profile sync 2089505729701103
 ntp-server X.X.X.X mode directedbroadcast
2 REPLIES 2
Beginner
Solution:
Solution:
voice service voip
no supplementary-service sip refer
Beginner
Very, Very good man.
Solved my problem.
Thanks a lot.
Content for Community-Ad
August's Community Spotlight Awards
