CME 11 - Dial peer isses, need assistance
s4siddiqui
Hello there...
I am new on the CME platform and learning as I go with this system; I am actually taking over this system from the previous folks who deployed this.
I have 2 DIDs (canadian) and I like to split them internally to extensions, I was told outside cannot call into the extensions as I don't have the autoattendent module installed yet (its a 2921 ISR).
  1. I need someone to explain me the dial peers configured here already and I seem to have lost the ability to call between 2 extensions (1001 and 1002, ignore the 82xx extensions from before), are they look OK?
  2. is my SIP trunking configuration OK? I can call out from the main number but outsiders cannot call me (perhaps my FW issue, will deal with it later with my security folks).
I would really appreciate if someone would just explain what the heck is going on in here.
(Please see attached, also please let me know if anyone of you require a specific output)
11 Replies 11
Dennis Mink
Can you provide a debug ccsip message and debug voip dialpeer and add what number is being called that is failing inbound.  cheers
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis...so I tried calling from ext 1001 to 1002 its fast busy. I could call out fine to 14168778426 and my main number is being displayed 604-283-3262, but that toronto number not able to call in (no output is displayed in debug) I am thinkg my FW is blocking it.
Essentially below is what I want:
  1. first number 604-283-3262 broken down to 1000, 1002, 1003 to 1010
  2. second number 604-283-3263 broken to 2000, 2001, 2002 to 2050
  1. so finally I see the incoming calls shown on my CME but recording says'number is not in service'
  2. I lost the calling out now (see logs)it definitely appears that my dial peers are not set properly.
PLEASE HELP (full running config attached)
WHEN CALLING OUT to 014168778426
KEMVG1#debug voice dialpeer
voip dialpeer default debugging is on
KEMVG1#
May 7 09:47:04.847: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=0, Called Number=0, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=0
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
May 7 09:47:04.847: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=0, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
May 7 09:4
KEMVG1#7:04.847: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
May 7 09:47:04.847: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=1001, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=40002
KEMVG1#xxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
May 7
KEMVG1#09:47:04.847: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:47:04.847: //-1/1B60FA5D80D2/DPM/dpAssociateIncomingPeerCore:
Calling Number=1001, Called Number=0, Voice-Interface=0x0,
KEMVG1#g Dial-peer=40002
May 7 09:47:04.847: //-1/1B60FA5D80D2/DPM/dpMatchSafModulePlugin:
May 7 09:47:04.847: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=40002
Result=0 Bitmap=0x0
May 7 09:47:04.851: //-1/1B60FA5D80D2/DPM/dpMatchPeersCore:
Calling Number=, Called Number=0, Peer Info Type=DIALPEER_INFO_SPEECH
KEMVG1#MatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
May 7 09:47:04.851: //-1/1B60FA5D80D2/DPM/dpMatchSafModulePlugin:
dialstring=0, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
May 7 09:47:04.851: //-1/1B60FA5D80D2/DPM/dpMatchPeersMoreArg:
Result=MORE_DIGITS_NEEDED(1)
May 7 09:47:04.919: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
KEMVG1#r=1001, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
May 7 09:47:04.919: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Call
KEMVG1#ing Number=0, Called Number=0, Voice-Interface=0x0,
May 7 09:47:05.743: //-1/xxxxxxxxxxxx/DPM/dpAssociateInc
KEMVG1#omingPeerCore:
Calling Number=0, Called Number=0, Voice-Interface=0x0,
May 7 09:47:05.743: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 7 09:47:05.743: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:47:05.743: //-1/1B60FA5D
KEMVG1#80D2/DPM/dpMatchPeersCore:
Calling Number=, Called Number=01, Peer Info Type=DIALPEER_INFO_SPEECH
May 7 09:47:05.747: //-1/1B60FA5D80D2/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=01
May 7 09:47:05.747: //-1/1B60FA5D80D2/DPM/dpMatchSafModulePlugin:
dialstring=01, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
KEMVG1#sMoreArg:
May 7 09:47:05.771: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 7 09:47:05.771: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
KEMVG1# dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
May 7 09:47:05.815: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
KEMVG1#MatchSafModulePlugin:
May 7 09:47:05.843: //-1/1B60FA5D80D2/DPM/dpMatchPeersCore:
Calling Number=, Called Number=014, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=014
May 7 09:47:05.843: //-1/1B60FA5D80D2/DPM/dpMatchSafModulePl
KEMVG1#ugin:
dialstring=014, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
May 7 09:47:05.843: //-1/1B60FA5D80D2/DPM/dpMatchPeersMoreArg:
May 7 09:47:05.943: //-1/1B60FA5D80D2/DPM/dpMatchPeersCore:
Calling Number=, Called Number=0141, Pe#
WHEN CALLING IN FROM THAT NUMBER
KEMVG1#
May 7 09:52:12.783: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=16042833262, Called Number=16042833262, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=16042833262
Result=Success(0) after DP_MATCH_DEST
May 7 09:52:12.783: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=16042833262, saf_enabled=1, saf_dndb_lookup=1, d
KEMVG1#p_result=0
May 7 09:52:12.783: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20001
May 7 09:52:12.783: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=4168778426, Called Number=, Voice-Interface=0x0,
R
KEMVG1#esult=NO_MATCH(-1) After All Match Rules Attempt
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
May 7 09:52:12.787: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
KEMVG1#erCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
May 7 09:52:12.787: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:52:12.787: //-1/C532BD0F1FBA/DPM/dpAssociateIncomingPeerCore:
Calling Number=4168778426, Called Number=16042833262, Voice-Interface=0x0,
KEMVG1#PM/dpAssociateIncomingPeerCore:
May 7 09:52:12.787: //-1/C532BD0F1FBA/DPM/dpMatchSafModulePlugin:
May 7 09:52:12.787: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=1
Result=0 Bitmap=0x0
May 7 09:52:12.791: //-1/C532BD0F1FBA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=32
KEMVG1#62, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=3262
May 7 09:52:12.791: //-1/C532BD0F1FBA/DPM/dpMatchSafModulePlugin:
dialstring=3262, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
May 7 09:52:12.791: //-1/C532BD0F1FBA/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
May 7 09:52:1
KEMVG1#2.791: //-1/C532BD0F1FBA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=3262, Peer Info Type=DIALPEER_INFO_SPEECH
May 7 09:52:12.791
KEMVG1#: //-1/C532BD0F1FBA/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
May 7 09:52:12.791: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=3262, Called Number=3262, Peer Info Type=DIALPEER_INFO_SPEECH
KEMVG1#09:52:12.791: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:52:12.791: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
May 7 09:52:12.791: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=3262, Called Number=, Voice-Interface=0x0,
KEMVG1#fter All Match Rules Attempt
May 7 09:52:12.791: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Result=NO_MATC
KEMVG1#H(-1) After All Match Rules Attempt
KEMVG1#s Matched; Result=NO_MATCH(-1)
Result=NO_MATCH(-1)
May
KEMVG1# 7 09:52:12.791: //-1/C532BD0F1FBA/DPM/dpMatchPeersCore:
dialstring=3262, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
Result=NO_MATCH(-1)
KEMVG1#xxxxxxx/DPM/dpMatchPeersCore:
May 7 09:52:12.791: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
KEMVG1#er=8268, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8268
Result=NO_MATCH(-1)
May 7 09:52:12.
KEMVG1#791: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 7 09:52:12.791:
KEMVG1#//-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
Calling Number=, Called Number=8269, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8269
dialstrin
KEMVG1#g=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Result=NO_MATCH(-1)
May
KEMVG1# 7 09:52:12.791: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Result=NO_MATCH(-1)
Calling Number=, Called Number=8270, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8270
KEMVG1#atchPeersCore:
Result=NO_MATCH(-1)
Match Rule=DP_M
KEMVG1#ATCH_DEST; Called Number=3262
Result=NO_MATCH(-1)
Calling Number=, Called Number=8271, Peer Info Type=DIALPEER_INFO_SPEECH
May
KEMVG1# 7 09:52:12.791: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=8271
Result=NO_MATCH(-1)
KEMVG1#Calling Number=, Called Number=3262, Peer Info Type=DIALPEER_INFO_SPEECH
Result=NO
KEMVG1#_MATCH(-1)
Calling Number=, Called Number=8272, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8272
May 7 09:52:12.795: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 7 09:52:12.795: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
KEMVG1#lt=-1
May 7 09:52:12.795: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
KEMVG1#fModulePlugin:
Result=NO_MATCH(-1)
Calling Number=, Called Number=1002, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=1002
KEMVG1#CH_DEST
Result=SUCCESS(0)
1: Dial-peer Tag=40001
Match Rul
KEMVG1#e=DP_MATCH_DEST; Called Number=3262
Result=NO_MATCH(-1)
Calling Number=, Called Number=8274, Peer Info Type=DIALPEER_INFO_SPEEC
KEMVG1#H
Match Rule=DP_MATCH_DEST; Called Number=8274
Result=NO_MATCH(-1)
KEMVG1#:
Res
KEMVG1#ult=NO_MATCH(-1)
Calling Number=, Called Number=8275, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8275
KEMVG1#p_result=-1
Result=NO_MATCH(-1)
KEMVG1#atchSafModulePlugin:
Result=NO_MATCH(-1)
Calling Number=, Called Number=8276, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8276
KEMVG1# Matched; Result=NO_MATCH(-1)
Result=NO_MATCH(-1)
May 7 09:52
KEMVG1#:12.795: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=NO_MATCH(-1)
Calling Number=, Called Number=8277, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8277
Result=NO_MATCH(-1)
KEMVG1#nfo Type=DIALPEER_INFO_SPEECH
Result=NO_MATCH(-1)
Calling Number=, Called Number=8278, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8278
KEMVG1#xx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
KEMVG1#bled=0, saf_dndb_lookup=0, dp_result=-1
Result=NO_MATCH(-1)
Calling Number=, Called Number=1001, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=1001
KEMVG1#xxxx/DPM/dpMatchSafModulePlugin:
Result=SUCCESS(0)
1: Dial-peer Tag=40002
May 7
KEMVG1# 09:52:12.795: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=NO_MATCH(-1)
Calling Number=, Called Number=8280, Peer Info Type=DIALPEER_INFO_SPEECH
KEMVG1#PM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=8280
Result=NO_MATCH(-1)
KEMVG1#Peer Info Type=DIALPEER_INFO_SPEECH
Result=NO_MATCH(-1)
KEMVG1#/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=8281, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8281
KEMVG1#xxxxxxxx/DPM/dpMatchPeers:
Result=NO_MATCH(-1)
dialstring=NULL, s
KEMVG1#af_enabled=0, saf_dndb_lookup=0, dp_result=-1
Result=NO_MATCH(-1)
Calling Number=, Called Number=8268, Peer Info Type=DIALPEER_INFO_SPEECH
May 7 09:52
KEMVG1#:12.795: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Result=NO_MATCH(-1)
KEMVG1#Core:
Result=NO_MATCH(-1)
Calling Number=, Called Number=1235, Peer Info Type=DIALPEER_INFO_SPEECH
KEMVG1#; Called Number=1235
Result=NO_MATCH(-1)
CALLING FROM extension 1001 to 1002 - fast busy
KEMVG1#
May 7 09:54:19.183: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=1, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
May 7 09:54:19.183: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=1, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
May 7 09:5
KEMVG1#4:19.183: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
May 7 09:54:19.183: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 7
KEMVG1#09:54:19.183: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:54:19.183: //-1/1E42C8E580EC/DPM/dpAssociateIncomingPeerCore:
Calling Number=1001, Called Number=1, Voice-Interface=0x0,
May 7 09:54:19.183: //-1/1E42C8E580EC/DPM/dpMatchSafModulePlugin:
May 7 09:54:19.183: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=40002
Result=0 Bitmap=0x0
May 7 09:54:19.187: //-1/1E42C8E580EC/DPM/dpMatchPeersCore:
Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
May 7 09:54:19.187: //-1/1E42C8E580EC/DPM/dpMatchSafModulePlugin:
dialstring=1, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
May 7 09:54:19.187: //-1/1E42C8E580EC/DPM/dpMatchPeersMoreArg:
May 7 09:54:19.239: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 7 09:54:19.239: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Call
KEMVG1#ing Number=1, Called Number=1, Voice-Interface=0x0,
May 7 09:54:19.511: //-1/xxxxxxxxxxxx/DPM/dpAssociateInc
Calling Number=1, Called Number=1, Voice-Interface=0x0,
May 7 09:54:19.511: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 7 09:54:19.511: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:54:19.511: //-1/1E42C8E5
KEMVG1#80EC/DPM/dpMatchPeersCore:
Calling Number=, Called Number=10, Peer Info Type=DIALPEER_INFO_SPEECH
May 7 09:54:19.511: //-1/1E42C8E580EC/DPM/dpMatchPeersCore:
May 7 09:54:19.511: //-1/1E42C8E580EC/DPM/dpMatchSafModulePlugin:
dialstring=10, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
KEMVG1#sMoreArg:
May 7 09:54:19.639: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 7 09:54:19.639: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:54:19.639: //-1/1E42C8E580EC/DPM/dpMatchPeersCore:
Calling Number=, Called Number=100, Peer Info Type=DIALPEER_INFO_SPEECH
May 7 09:54:19.639: //-1/1E42C8E580EC/DPM/dpMatchSafModulePlugin:
dialstring=10
KEMVG1#0, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
May 7 09:54:19.639: //-1/1E42C8E580EC/DPM/dpMatchPeersMoreArg:
May 7 09:54:19.927: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
KEMVG1#NCOMING_DNIS; Incoming Dial-peer=1
May 7 09:54:19.927: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:54:19.927: //-1/1E42C8E580EC/DPM/dpMatchPeersCore:
KEMVG1#P_MATCH_DEST
May 7 09:54:19.927: //-1/1E42C8E580EC/DPM/dpMatchSafModulePlugin:
dialstring=1002, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
May 7 09:54:19.927: //-1/1E42C8E580EC/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
KEMVG1# Match Rule=DP_MATCH_DEST; Called Number=1002
dialstring=1002, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Result=SUCCESS(0)
KEMVG1# Calling Number=, Called Number=1002, Peer Info Type=DIALPEER_INFO_SPEECH
Result=SUCCESS(0
KEMVG1#)
May 7 09:54:19.927: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=1002, Called Number=1002, Peer Info Type=DIALPEER_INFO_SPEECH
dials
KEMVG1#tring=1002, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
May 7 09:54:19.927: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Calling Number=1, Called Number=, Voice-Interface=0x0,
May 7 09:54:19.931: //-1/xxxxxxxxxxxx/
KEMVG1#DPM/dpAssociateIncomingPeerCore:
May 7 09:54:19.931: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 7 09:54:19.931: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=1002, Called Number=, Voice-Interface=0x0,
KEMVG1#xxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=40001
May 7 09:54:19.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 7 09:54
KEMVG1#:19.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
May 7 09:54:19.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
May 7 09:54:19.931: //-1/1E42C8E580EC/DPM/dpMatchPeersCore:
KEMVG1#ER_INFO_SPEECH
May 7 09:54:19.931: //-1/1E42C8E580EC/DPM/dpMatchSafModulePlugin:
dialstring=1002, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
May 7 09:54:19.931: //-1/1E42C8E580EC/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-
KEMVG1#peer Tag=40001
KEMVG1#abled=0, saf_dndb_lookup=0, dp_result=0
May 7 09:54:19.987: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 7 09:54:19.987: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
KEMVG1#dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
TRANSLATION RULES
voice translation-rule 1
rule 1 /^0/ //
voice translation-rule 2
rule 1 /1604283/ //
voice translation-rule 3
rule 1 /^10/ /1604283/
voice translation-rule 4
voice translation-profile inbound
translate called 2
voice translation-profile remove0
translate calling 3
translate called 1
dial-peer voice 100 voip
description SIP Trunk with IXICA
translation-profile outgoing remove0
destination-pattern 0...........
session protocol sipv2
session target ipv4:208.43.27.75
voice-class codec 1
voice-class sip reset timer expires 183
dtmf-relay rtp-nte
dial-peer voice 1 voip
description **Incoming Call from SIP Trunk**
translation-profile incoming inbound
session target registrar
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
Hi there
Please try adding a voip dial peer for dialing internal numbers
dial-peer voice 2 voip
destination-pattern 1...
session target ipv4:<CME IP>
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Please let me know how it goes.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
thanks.
that dial peer is now calling from 1002 to 1001 but not vice versa.
Hi there
Could be a corelist issue. I assume you have configured the privilege for that phone to call out. Please post the ephone config of that phone.
Hope this helps!
Cheers
Rath!
here:
voice register dn 12
number 1001
name Kemano test
voice register pool 12
busy-trigger-per-button 1
id mac 2852.61C0.6409
type 7821
number 1 dn 12
dtmf-relay rtp-nte
username cisco12 password 123
description 604-283-3262
codec g711ulaw
EPHONE DN
ephone-dn 1
number 16042833262
ephone 1
description Seb
mac-address 3CA8.2A87.8440
ephone 2
description cPhil
mac-address 0005.9A3C.7A00
 I don't have the ephone dn configured for any of these 2 extensions, do I have to? i thought ephone dn 1 is the main number to be displayed on both the phones.
Hi there
So, here you can dial from 1002 to 1001 but not vice versa. Does this 1001 can call outside, to any other extensions ?
Hope this helps!
Cheers
Rath!
both can actually call out but 1001 cannot call to 1002...strange...also the incoming call is received on the phone but not lasting 7 seconds for some odd reasons.
Hi there
could you try resetting the phone to factory default and try
cheers
Rath!
i can  see 1001 extension configured on SIP phone. where is the other extension 1002 configured? is it any SCCP phone? i cant find it in your show run output. where is the other extension 1002 configured?
Saiful Islam
