CME & 3rd party SIP (Cyberdata Intercom)
danielblock1
I'm trying to get a Cyberdata Intercom to work with a UC520. I followed the instructions at: http://supportwiki.cisco.com/wiki/images/5/58/Cyberdata_uc500_Doorphone_external_last-v3.pdf. I can get it to make calls and everything seemingly works as expected, however it is not registering. This is what I'm getting when it trys to register:
Jan 15 21:21:28.062: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.1.1.1:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.16:5060;rport;branch=z9hG4bK1986204771
To: <sip:407@10.1.1.1>
Call-ID: 1592243375@192.168.10.16
CSeq: 2 REGISTER
Contact: <sip:407@192.168.10.16:5060>
Max-Forwards: 5
User-Agent: CyberData Intercom
Expires: 3600
Content-Length: 0
Jan 15 21:21:28.062: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Jan 15 21:21:28.062: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: Re qLine IP addr does not match with host IP addr
Jan 15 21:21:28.062: //196/4E2404168187/SIP/Error/ccsip_spi_register_incoming_re gistration: Registration Authorization failed with authorization header=
Jan 15 21:21:28.066: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 15 Jan 2009 21:21:28 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 2 REGISTER
Content-Length: 0
Sent:
SIP/2.0 401 Unauthorized
To: <sip:407@10.1.1.1>;tag=4C617B0-1A7E
CSeq: 2 REGISTER
WWW-Authenticate: Digest realm="",nonce="05A495BC007A3591",algorithm=MD5,qop="au th"
Content-Length: 0
This is my config:
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 1
max-pool 1
authenticate register
voice register dn 1
number 407
no-reg
voice register pool 1
id mac 0020.F735.02A1
number 1 dn 1
dtmf-relay rtp-nte
username 407 password ext407
codec g711ulaw
no vad
Any help would be appreciated. Thanks
5 Replies 5
paolo bevilacqua
The device wants to register with same ip as CME ?!?
Hmm.. I'm not sure what that is about.. Maybe it is NAT'ng.
I changed the IP of the device to 10.1.1.5. Set up the port it is plugged into to be on the Voice VLAN. Same thing:
Received:
Via: SIP/2.0/UDP 10.1.1.5:5060;rport;branch=z9hG4bK1411286857
To: <407>
Call-ID: 335855849@10.1.1.5
CSeq: 1 REGISTER
Contact: <407>
Max-Forwards: 5
Expires: 3600
Content-Length: 0
Jan 15 22:34:04.470: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Jan 15 22:34:04.470: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Jan 15 22:34:04.470: //227/72C276DF81AE/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Jan 15 22:34:04.470: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <407>
Date: Thu, 15 Jan 2009 22:34:04 GMT
CSeq: 1 REGISTER
Content-Length: 0
Sent:
To: <407>;tag=50890E8-7F7
CSeq: 1 REGISTER
A couple of things to be aware of:
-SIP CME will only allow devices to register without authentication on the same subnet
-If the device is on a different subnet, you must put a 'username password ' on the voice register pool configuration.
-SIP CME doesn't officially support 3rd party devices, but a majority of devices will work anyways
-Paolo is actually incorrect on the IP address. The Via header will be used to direct the SIP packets, and this is normal behavior.
Here is a registration example for a 3951:
Received:
REGISTER sip:172.18.110.80 SIP/2.0
To: <1020>
Call-ID: EP0-lG4QesZjBD@172.18.110.80
CSeq: 187 REGISTER
Via: SIP/2.0/UDP 14.50.233.55:5060;branch=z9hG4bKwokBD-MA5lTcsJ1
Contact: <1020>;+sip.instance="";+u.sip!model.ccm.cisco.com="412"
Max-Forwards: 70
Authorization: Digest username="a",realm="",uri="sip:172.18.110.80",response="ea67ab428023c52b7d9329b2a401d2f1",algorithm=MD5,nonce="4667E6D30003ED8E",qop=auth,cnonce="94de76c0",nc=000000aa
User-Agent: Cisco-CP3951/8.1
Expires: 0
Supported: 100rel, replaces, norefersub, X-cisco-callinfo, X-cisco-service-control
Content-Length: 0
Sent:
SIP/2.0 100 Trying
Date: Fri, 16 Jan 2009 00:09:45 GMT
Content-Length: 0
To: <1020>
CSeq: 187 REGISTER
Sent:
SIP/2.0 200 OK
Content-Length: 0
To: <1020>;tag=244640CC-8FE
Contact: <1020>;expires=0
Expires: 0
CSeq: 187 REGISTER
hth,
nick
I got it to work! I added the realm paramater to voice global and it works great now. Thanks!
Nick is correct, I was confused. After the unauthorized message, an authenticating phone is supposed to try again again with the credentials. So the error messassages are actually misleading in this case.
