02-14-2007 05:02 PM - edited 03-14-2019 08:02 PM
- Has anyone notices that after you install
and reboot to 12.4(11)T or 12.4(11)T1 that
trying to use archive tar /xtract to get the
CME 4.0 files onto the router flash no longer
works successfully? I keep getting an error
to the effect that my tar file is a directory
according to the error text. Backing down
to 12.4(9)Tx does not exhibit this. Or is
there a new change on how to load CME tar
files starting in 12.4(11)x? Thanks.
02-15-2007 03:25 AM
Which router is your? That may be related to the fact directories are not supported on some platforms. Also, I find absolutely unnecessary to load all the files and built my own archive with the necessary files only.
02-22-2007 02:21 PM
there is a bug in 12.4.11(t). if you use the bug tool kit the number is CSCek63178. just got of with tacacs
02-23-2007 04:07 PM
What a strange bug, and severity just 4 ???
However I'm 99% positive I've been extracting tarfiles with 12.4(11)T.
