367
Highlighted
Beginner
cme 4.1 number translation not working
Hi all,
Using sip I want to translate the dialed digits from specific dn's
abbreviated example below:
When I test the rule it is fine, but it isn't being used, can someone confirm it is ok to apply translations under the register dn config ?
Will
voice service voip
allow-connections sip to sip
sip
  registrar server expires max 600 min 60
voice register global
mode cme
source-address 192.168.254.250 port 5060
max-dn 30
max-pool 10
create profile sync 0015337725877546
voice register dn  1
translation-profile incoming replace
number 101
allow watch
name block_1_lift_1
voice register pool  3
id mac 0021.290D.0881
type ATA
number 1 dn 1
username 100 password cisco
codec g711alaw
voice translation-rule 100
rule 1 /07525925703/ /08450049005/
voice translation-profile replace
translate called 100
voice-port 2/0
connection plar 931
dial-peer voice 11 pots
preference 1
destination-pattern .T
port 2/0
2 REPLIES 2
Highlighted
why would you apply it under the registerar
just apply it normally under the dial-peer
fro example if you want the called number to be tranlsated when its come from PSTN
then apply it to you dial peer 11 above in the inbound direction
good luck
if helpful rate
Highlighted
Beginner
I could do that, but i only want to translate this number from specific dn's
how would i do that ?
Will
Content for Community-Ad
Cisco COVID-19 Survey
