I have CME with sip trunk and when calls from ip phone to outside, it gives silence but as i press Acct softkey it gives beep and then i press << theis softkey it given ringback tone,,,
what could be the issue and how can fix it?
below is latest CME configuration:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.07.26 10:53:30 =~=~=~=~=~=~=~=~=~=~=~=
Building configuration...
Current configuration : 18505 bytes
! Last configuration change at 10:34:35 AST Sun Jul 26 2015 by admin
! NVRAM config last updated at 10:25:01 AST Sun Jul 26 2015 by admin
version 15.0
hostname MSHEIREB-CME
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
! card type command needed for slot/vwic-slot 0/2
no aaa new-model
clock timezone AST 3
clock calendar-valid
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.153.20.1 10.153.20.10
ip dhcp pool CME-PHONES
network 10.153.20.0 255.255.255.0
default-router 10.153.20.1
option 150 ip 10.153.20.1
ip domain name vodafone.qa
ip host vodafone.qa 172.16.6.4
ip name-server 8.8.8.8
ip name-server 8.8.4.4
--More-- !
voice-card 0
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
rel1xx disable
header-passing
error-passthru
no update-callerid
bearer-capability clear-channel rdi
early-offer forced
midcall-signaling passthru
g729 annexb-all
voice class codec 4
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
license udi pid CISCO2911/K9 sn FCZ151621AN
hw-module ism 0
hw-module pvdm 0/0
username admin privilege 0 secret 5 $1$ngso$35iTob/Yo7cm9chyFNoyy.
redundancy
--More-- !
interface GigabitEthernet0/0
description *** LAN CONNECTION TO CORE ***
ip address 10.153.20.1 255.255.255.0
duplex auto
speed auto
interface ISM0/0
description *** CUE MODULE ON ISM-300 ***
ip unnumbered GigabitEthernet0/0
service-module ip address 10.153.20.2 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 10.153.20.254
interface ISM0/1
no ip address
shutdown
interface GigabitEthernet0/1
description Alcatel Router pointing interface
ip address 10.72.5.98 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.153.20.254
ip route 10.153.20.2 255.255.255.255 ISM0/0
--More-- ip route 172.16.6.4 255.255.255.255 10.72.5.97
tftp-server flash:SCCP45.9-4-2SR1-1S.loads
tftp-server flash:cnu45.9-4-2ES9.sbn
tftp-server flash:cvm45sccp.9-4-2ES9.sbn
tftp-server flash:dsp45.9-4-2ES9.sbn
tftp-server flash:jar45sccp.9-4-2ES9.sbn
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:admin_user.html
tftp-server flash:admin_user.js
tftp-server flash:CiscoLogo.gif
tftp-server flash:CME_GUI_README.TXT
tftp-server flash:Delete.gif
tftp-server flash:dom.js
tftp-server flash:downarrow.gif
tftp-server flash:ephone_admin.html
tftp-server flash:logohome.gif
tftp-server flash:normal_user.html
tftp-server flash:normal_user.js
tftp-server flash:Plus.gif
tftp-server flash:sxiconad.gif
tftp-server flash:Tab.gif
tftp-server flash:telephony_service.html
tftp-server flash:uparrow.gif
tftp-server flash:xml.template
tftp-server flash:xml-test.html
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
--More-- !
dial-peer voice 1001 voip
description *** CUE Voicemail ***
destination-pattern 800
session protocol sipv2
session target ipv4:10.153.20.2
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 voip
description ** INBOUND LAN SIDE DIAL_PEER FROM CMETO CUBE **
session target sip-server
incoming called-number 9T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 200 voip
description ** OUTBOUND LAN SIDE DIAL_PEER FROM CUBE TO CME **
preference 1
destination-pattern +97440065...$
session target ipv4:10.153.20.1:5060
voice-class codec 4
dtmf-relay rtp-nte
dial-peer voice 1000 voip
description ** INBOUND WAN SIDE DIAL_PEER FROM SP TO CUBE **
incoming called-number +97440065...$
voice-class codec 4
dtmf-relay rtp-nte
dial-peer voice 3000 voip
description *** LOCAL DIALING POOL WAN-SIDE DIAL_PEER ***
translation-profile outgoing QE-out
destination-pattern 9[4].......$
dtmf-relay rtp-nte
codec g711ulaw
--More-- !
dial-peer voice 2000 voip
description *** MOBILE DIALING POOL WAN-SIDE DIAL_PEER ***
destination-pattern 9[3567].......$
voice-class codec 4
dtmf-relay rtp-nte
dial-peer voice 4000 voip
description *** EMERGENCY DIALING WAN-SIDE DIAL_PEER ***
destination-pattern 999$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 5000 voip
description *** INTERNATIONAL DIALING WAN-SIDE DIAL_PEER ***
destination-pattern 900T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 5001 voip
destination-pattern 900#T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 6000 voip
description *** SPECIAL LOCAL DIALING WAN-SIDE DIAL_PEER ***
destination-pattern 9[28]......$
--More-- dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 7000 voip
description *** SHORT DIALING WAN-SIDE DIAL_PEER ***
destination-pattern 91..$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 1002 voip
description *** CUE AutoAttendant ***
destination-pattern 810
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1003 voip
description *** CUE Promptmgmt ***
destination-pattern 820
dtmf-relay rtp-nte
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
sip-ua
authentication username 97440065555@ims.vodafone.qa password 7 14011D0F0D02252521796166
retry invite 2
retry register 10
timers connect 100
registrar dns:vodafone.qa expires 3600
sip-server dns:vodafone.qa:5067
host-registrar
--More-- !
gatekeeper
shutdown
telephony-service
no privacy
privacy-on-hold
video
authentication credential admin cisco
max-ephones 58
max-dn 100 no-reg
ip source-address 10.153.20.1 port 2000
timeouts interdigit 3
system message MSHEIREB-CME
url services http://10.153.20.2/voiceview/common/login.do
url authentication http://10.153.20.1/CCMCIP/authenticate.asp
load 7945 SCCP45.9-4-2SR1-1S
time-zone 31
time-format 24
dialplan-pattern 1 400655.. extension-length 3 extension-pattern 5.. no-reg
voicemail 800
max-conferences 8 gain -6
call-forward pattern .T
moh enable-g711
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp 7960 Jul 26 2015 10:34:35
ephone-dn-template 1
allow watch
ephone-template 1
conference drop-mode creator
conference admin
--More-- max-calls-per-button 4
busy-trigger-per-button 2
ephone-dn 1
number 801... no-reg both
mwi on
ephone-dn 2
number 802... no-reg both
mwi off
ephone-dn 3 dual-line
number 500
label Emin Balcioglu-500
description 40065500
name Emin Ismail Mahir Balcioglu
ephone-dn 4 dual-line
number 521
label Alanoud Mohammed Al-Jaber-521
description 40065521
name Alanoud Mohammed Al-Jaber
ephone-dn 5 dual-line
number 557
label Khalifa Ahmed Al-Obaidli-557
description 40065557
name Khalifa Ahmed Al-Obaidli
ephone-dn 6 dual-line
number 535
label Fahad Abdulla J M Al Turky-535
description 40065535
name Fahad Abdulla J M Al Turky
--More-- ephone-dn-template 1
ephone-dn 7 dual-line
number 531
label Aisha Ali S A Al-Kuwari-531
description 40065531
name Aisha Ali S A Al-Kuwari
ephone-dn 8 dual-line
number 588
description 40065588
name Abdulla Khalid A H Al-Naama
ephone-dn 9 dual-line
number 512
label Linnet Raymond Dsouza-512
description 40065512
name Linnet Raymond Dsouza
ephone-dn 10 dual-line
number 577
label Mohammed Ali Al-Yousuf-577
description 40065577
name Mohammed Ali Al-Yousuf
ephone-dn 11 dual-line
number 508
label Benedict ST Clare Barbour-508
description 40065508
name Benedict ST Clare Barbour
ephone-dn 12 dual-line
--More-- number 553
label Colin Vivian Jones-553
description 40065553
name Colin Vivian Jones
ephone-dn 13 dual-line
number 554
label Amani Al-Tamimi-554
description 40065554
name Amani Al-Tamimi
ephone-dn 14 dual-line
number 551
label Cali Muxidin Maxamed-551
name Cali Muxidin Maxamed
ephone-dn 15 dual-line
number 552
description 40065552
name Nasreen Mohammed A M Al-Malek
ephone-dn 16 dual-line
number 550
label Hafiz Ali Ali-550
name Hafiz Ali Ali
ephone-dn 17 dual-line
number 580
description 40065580
name Christopher Joseph Monaghan
--More-- !
ephone-dn 18 dual-line
number 525
description 40065525
name Aisha Mohamed Saud Al-Sinani
ephone-dn 19 dual-line
number 545
description 40065545
name Nasser Falah S S Al-Remaihi
ephone-dn 20 dual-line
number 546
label Rashid Majid R S AL-Kuwari-546
description 40065546
name Rashid Majid R S AL-Kuwari
ephone-dn 21 dual-line
number 532
label Ghada Ali Al-Sayegh-532
description 40065532
name Ghada Ali Al-Sayegh
ephone-dn 22 dual-line
number 534
label Sara Al-Mannai-534
description 40065534
name Sara Al-Mannai
ephone-dn 23 dual-line
number 505
label Sara Nader Al-Hajri-505
--More-- description 40065505
name Sara Nader Al-Hajri
ephone-dn 24 dual-line
number 569
label Aisha Ali Al-Mannai-569
description 40065569
name Aisha Ali Al-Mannai
ephone-dn 25 dual-line
number 530
label Amnah Al-Faihani-530
description 40065530
name Amnah Al-Faihani
ephone-dn 26 dual-line
number 515
label Yousef M. Y. Deeb-515
name Yousef M. Y. Deeb
ephone-dn 27 dual-line
number 528
label Alya Mahanna A M Al-Nuaimi-528
description 40065528
name Alya Mahanna A M Al-Nuaimi
ephone-dn 28 dual-line
number 557
label Mohammed R. M. Dalloul-557
name Mohammed R. M. Dalloul
--More-- !
ephone-dn 29 dual-line
number 511
label Bin Jelmood House-511
description 40065511
name Bin Jelmood House
ephone-dn 30 dual-line
number 565
label Omnia Fadlalla Ahmed-565
description 40065565
name Omnia Fadlalla Ahmed
ephone-dn 31 dual-line
number 566
label Hana Abounahia-566
description 40065566
name Hana Abounahia
ephone-dn 32 dual-line
number 570
label Zahra Abdulla-570
description 40065570
name Zahra Abdulla
ephone-dn 33 dual-line
number 526
label Safa Arshad-526
description 40065526
name Safa Arshad
ephone-dn 34 dual-line
--More-- number 587
label Mahmud Talla-587
description 40065587
name Mahmud Talla
ephone-dn 35 dual-line
number 589
label Abdullah Hemadi -589
description 40065589
name Abdullah Hemadi
ephone-dn 36 dual-line
number 555
label Msheireb Museums-555
description 40065555
name Msheireb Museums
ephone-dn 37 dual-line
number 522
label Company House-522
description 40065522
name Company House
ephone-dn 38 dual-line
number 533
label MBJ House-533
description 40065533
name MBJ House
ephone-dn 39 dual-line
number 544
label ARadwani House-544
description 40065544
--More-- name Radwani House
ephone-dn 40 dual-line
number 556
label FAX-556
description 40065556
name FAX
ephone-dn 41 dual-line
number 599
label IT Helpdesk-599
description 40065599
name IT Helpdesk
ephone-dn 42 dual-line
number 588
label Ali Rashid Al Senaid-588
name Ali Rashid Al Senaid
ephone 1
description 500
mac-address 8890.8D73.B052
ephone-template 1
presence call-list
type 7945
button 1:3
ephone 2
description 521
mac-address 8890.8D73.AFBD
ephone-template 1
presence call-list
--More-- type 7945
button 1:4
ephone 3
description 557
mac-address 8890.8D73.B207
ephone-template 1
presence call-list
type 7945
button 1:5
ephone 4
description 535
mac-address 8890.8D73.B054
ephone-template 1
presence call-list
type 7945
button 1:6
ephone 5
description 531
mac-address 8890.8D73.B9AB
ephone-template 1
presence call-list
type 7945
button 1:7
ephone 6
description 588
mac-address 8890.8D73.B53D
ephone-template 1
presence call-list
type 7945
button 1:8
--More-- !
ephone 7
description 512
mac-address 8890.8D73.AFD4
ephone-template 1
presence call-list
type 7945
button 1:9
ephone 8
description 577
mac-address 8890.8D73.B34C
ephone-template 1
presence call-list
type 7945
button 1:10
ephone 9
description 508
mac-address 8890.8D73.AEBA
ephone-template 1
presence call-list
type 7945
button 1:11
ephone 10
description 553
mac-address 8890.8D73.ABA8
ephone-template 1
presence call-list
type 7945
button 1:12
ephone 11
--More-- description 554
mac-address 8890.8D73.ACB5
ephone-template 1
presence call-list
type 7945
button 1:13
ephone 12
description 551
mac-address 8890.8D73.B046
ephone-template 1
presence call-list
type 7945
button 1:14
ephone 13
description 552
mac-address 8890.8D73.B535
ephone-template 1
presence call-list
type 7945
button 1:15
ephone 14
description 550
mac-address 8890.8D73.AA2B
ephone-template 1
presence call-list
type 7945
button 1:16
ephone 15
description 580
mac-address 8890.8D73.B428
ephone-template 1
--More-- presence call-list
type 7945
button 1:17
ephone 16
description 525
mac-address 8890.8D73.AD36
ephone-template 1
presence call-list
type 7945
button 1:18
ephone 17
description 545
mac-address 8890.8D73.B0C0
ephone-template 1
presence call-list
type 7945
button 1:19
ephone 18
description 546
mac-address 8890.8D73.B04A
ephone-template 1
presence call-list
type 7945
button 1:20
ephone 19
description 532
mac-address 8890.8D73.AD7A
ephone-template 1
presence call-list
type 7945
button 1:21
--More-- !
ephone 20
description 534
mac-address 8890.8D73.B2EB
ephone-template 1
presence call-list
type 7945
button 1:22
ephone 21
description 505
mac-address 8890.8D73.B0C4
ephone-template 1
presence call-list
type 7945
button 1:23
ephone 22
description 569
mac-address 8890.8D73.AFCA
ephone-template 1
presence call-list
type 7945
button 1:24
ephone 23
description 530
mac-address 8890.8D73.AFC2
ephone-template 1
presence call-list
type 7945
button 1:25
--More-- ephone 24
description 515
mac-address 8890.8D73.B429
ephone-template 1
presence call-list
type 7945
button 1:26
ephone 25
description 528
mac-address 8890.8D73.AD06
ephone-template 1
presence call-list
type 7945
button 1:27
ephone 26
description 557
mac-address 8890.8D73.AF0B
ephone-template 1
presence call-list
type 7945
button 1:28
ephone 27
description 511
mac-address 8890.8D73.AA27
ephone-template 1
presence call-list
type 7945
button 1:29
ephone 28
description 565
mac-address 40A6.E853.B9D8
--More-- ephone-template 1
presence call-list
type 7945
button 1:30
ephone 29
description 565
mac-address 8890.8D73.B23F
ephone-template 1
presence call-list
type 7945
button 1:31
ephone 30
description 544
mac-address 8890.8D73.B0C1
ephone-template 1
presence call-list
type 7945
button 1:32
ephone 31
description 570
mac-address 8890.8D73.B541
ephone-template 1
presence call-list
type 7945
button 1:33
ephone 32
description 526
mac-address 8890.8D73.B051
ephone-template 1
presence call-list
type 7945
--More-- button 1:34
ephone 33
description 587
mac-address 8890.8D73.B381
ephone-template 1
presence call-list
type 7945
button 1:35
ephone 34
description 589
mac-address 8890.8D73.B23C
ephone-template 1
presence call-list
type 7945
button 1:36
ephone 35
description 555
mac-address 8890.8D73.B23D
ephone-template 1
presence call-list
type 7945
button 1:37
ephone 36
description 522
mac-address 40A6.E853.96F1
ephone-template 1
presence call-list
type 7945
button 1:38
--More-- !
ephone 37
description 533
mac-address 8890.8D73.B271
ephone-template 1
presence call-list
type 7945
button 1:39
ephone 38
description 544
mac-address 1111.1212.1213
ephone-template 1
presence call-list
type 7945
button 1:40
ephone 39
description 556
mac-address 8890.8D73.B278
ephone-template 1
presence call-list
type 7945
button 1:41
ephone 40
description 599
mac-address 8890.8D73.B333
ephone-template 1
presence call-list
type 7945
button 1:42
line con 0
password cisco
--More-- login local
line aux 0
line 131
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password cisco
login local
scheduler allocate 20000 1000
end
Generally speaking, you don't need to connect the cable physically to your router as long as IP reachability is established. However, looking at your config I see lot of things to be done.
1. You need to create a new subnet for WAN (either physical or subinterface). You can't share the same subnet for both LAN/WAN. Based on your current static routes and DHCP you will create asymmetric routing which will break connections.
2. You need to prepare your gateway for SIP trunk. I am share some config below but still you need to configure inbound dial-peers, translation-rules, etc.
voice service voip
ip address trusted list
ipv4 #Your ITSP IP#
sip
bind control source-interface #Source Interface for Signaling#
bind media source-interface #Source Interface for Signaling#
sip-ua
credentials username 97440065555@ims.vodafone.qa password 7 vodafone123 realm vodafone.qa
authentication username 97440065555@ims.vodafone.qa password 7 vodafone123 realm vodafone.qa
retry invite 3
retry register 2
retry options 1
timers trying 200
timers connect 100
sip-server ipv4:172.16.6.4:5067
thanks
Sharma,
I would love to assist here but really want you to read more. You can't copy/paste a config from any document without understanding what is inside it.
The reason of this forum, to my understanding, for people to assist each other to get things working but it should be in the right approach.
Please spend some time to understand basic CME configuration and basic SIP trunk integration.
Here are good links:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html
http://www.innotechcg.com/resources/HowTo/Cisco%20CME%20SIP%20Trunk%20Configuration.pdf
http://www.dasblinkenlichten.com/cme-configuring-a-sip-trunk/
thanks for your reply Mohammed!
i am also going through multiple steps to apply it as per current setup and see the results.
I will review your document and see if help me to setup fully trunk with cme.
thanks
share config
thanks for your reply...
please find the attached show run of cme..
as i dial the number..it accept whole number but wait for long time and as i press Acct on ip phone and back softkey it provides the ringback tone..
why is this happening and how can i fix it/
