CME 7.1 with SIP trunk for calls
Amit23
Level 4
Level 4
I have CME with sip trunk and when calls from ip phone to outside, it gives silence but as i press Acct softkey it gives beep and then i press << theis softkey it given ringback tone,,,
what could be the issue and how can fix it?
below is latest CME configuration:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.07.26 10:53:30 =~=~=~=~=~=~=~=~=~=~=~=
Building configuration...
Current configuration : 18505 bytes
! Last configuration change at 10:34:35 AST Sun Jul 26 2015 by admin
! NVRAM config last updated at 10:25:01 AST Sun Jul 26 2015 by admin
version 15.0
hostname MSHEIREB-CME
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
! card type command needed for slot/vwic-slot 0/2
no aaa new-model
clock timezone AST 3
clock calendar-valid
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.153.20.1 10.153.20.10
ip dhcp pool CME-PHONES
   network 10.153.20.0 255.255.255.0
   default-router 10.153.20.1
   option 150 ip 10.153.20.1
ip domain name vodafone.qa
ip host vodafone.qa 172.16.6.4
ip name-server 8.8.8.8
ip name-server 8.8.4.4
 --More--         !
voice-card 0
voice service voip
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  rel1xx disable
  header-passing
  error-passthru
  no update-callerid
  bearer-capability clear-channel rdi
  early-offer forced
  midcall-signaling passthru
  g729 annexb-all
voice class codec 4
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729br8
license udi pid CISCO2911/K9 sn FCZ151621AN
hw-module ism 0
hw-module pvdm 0/0
username admin privilege 0 secret 5 $1$ngso$35iTob/Yo7cm9chyFNoyy.
redundancy
 --More--         !
interface GigabitEthernet0/0
 description *** LAN CONNECTION TO CORE ***
 ip address 10.153.20.1 255.255.255.0
 duplex auto
 speed auto
interface ISM0/0
 description *** CUE MODULE ON ISM-300 ***
 ip unnumbered GigabitEthernet0/0
 service-module ip address 10.153.20.2 255.255.255.0
 !Application: CUE Running on ISM
 service-module ip default-gateway 10.153.20.254
interface ISM0/1
 no ip address
 shutdown
interface GigabitEthernet0/1
 description Alcatel Router pointing interface
 ip address 10.72.5.98 255.255.255.248
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.153.20.254
ip route 10.153.20.2 255.255.255.255 ISM0/0
 --More--         ip route 172.16.6.4 255.255.255.255 10.72.5.97
tftp-server flash:SCCP45.9-4-2SR1-1S.loads
tftp-server flash:cnu45.9-4-2ES9.sbn
tftp-server flash:cvm45sccp.9-4-2ES9.sbn
tftp-server flash:dsp45.9-4-2ES9.sbn
tftp-server flash:jar45sccp.9-4-2ES9.sbn
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:admin_user.html
tftp-server flash:admin_user.js
tftp-server flash:CiscoLogo.gif
tftp-server flash:CME_GUI_README.TXT
tftp-server flash:Delete.gif
tftp-server flash:dom.js
tftp-server flash:downarrow.gif
tftp-server flash:ephone_admin.html
tftp-server flash:logohome.gif
tftp-server flash:normal_user.html
tftp-server flash:normal_user.js
tftp-server flash:Plus.gif
tftp-server flash:sxiconad.gif
tftp-server flash:Tab.gif
tftp-server flash:telephony_service.html
tftp-server flash:uparrow.gif
tftp-server flash:xml.template
tftp-server flash:xml-test.html
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
 --More--         !
dial-peer voice 1001 voip
 description *** CUE Voicemail ***
 destination-pattern 800
 session protocol sipv2
 session target ipv4:10.153.20.2
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 100 voip
 description ** INBOUND LAN SIDE DIAL_PEER FROM CMETO CUBE **
 session target sip-server
 incoming called-number 9T
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 200 voip
 description ** OUTBOUND LAN SIDE DIAL_PEER FROM CUBE TO CME **
 preference 1
 destination-pattern +97440065...$
 session target ipv4:10.153.20.1:5060
 voice-class codec 4
 dtmf-relay rtp-nte
dial-peer voice 1000 voip
 description ** INBOUND WAN SIDE DIAL_PEER FROM SP TO CUBE **
 incoming called-number +97440065...$
 voice-class codec 4
 dtmf-relay rtp-nte
dial-peer voice 3000 voip
 description *** LOCAL DIALING POOL WAN-SIDE DIAL_PEER ***
 translation-profile outgoing QE-out
 destination-pattern 9[4].......$
 dtmf-relay rtp-nte
 codec g711ulaw
 --More--         !
dial-peer voice 2000 voip
 description *** MOBILE DIALING POOL WAN-SIDE DIAL_PEER ***
 destination-pattern 9[3567].......$
 voice-class codec 4
 dtmf-relay rtp-nte
dial-peer voice 4000 voip
 description *** EMERGENCY DIALING WAN-SIDE DIAL_PEER ***
 destination-pattern 999$
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 5000 voip
 description *** INTERNATIONAL DIALING WAN-SIDE DIAL_PEER ***
 destination-pattern 900T
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 5001 voip
 destination-pattern 900#T
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 6000 voip
 description *** SPECIAL LOCAL DIALING WAN-SIDE DIAL_PEER ***
 destination-pattern 9[28]......$
 --More--          dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 7000 voip
 description *** SHORT DIALING WAN-SIDE DIAL_PEER ***
 destination-pattern 91..$
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 1002 voip
 description *** CUE AutoAttendant ***
 destination-pattern 810
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1003 voip
 description *** CUE Promptmgmt ***
 destination-pattern 820
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
gateway
 timer receive-rtp 1200
sip-ua
 authentication username 97440065555@ims.vodafone.qa password 7 14011D0F0D02252521796166
 retry invite 2
 retry register 10
 timers connect 100
 registrar dns:vodafone.qa expires 3600
 sip-server dns:vodafone.qa:5067
 host-registrar
 --More--         !
gatekeeper
 shutdown
telephony-service
 no privacy
 privacy-on-hold
 video
 authentication credential admin cisco
 max-ephones 58
 max-dn 100 no-reg
 ip source-address 10.153.20.1 port 2000
 timeouts interdigit 3
 system message MSHEIREB-CME
 url services http://10.153.20.2/voiceview/common/login.do
 url authentication http://10.153.20.1/CCMCIP/authenticate.asp
 load 7945 SCCP45.9-4-2SR1-1S
 time-zone 31
 time-format 24
 dialplan-pattern 1 400655.. extension-length 3 extension-pattern 5.. no-reg
 voicemail 800
 max-conferences 8 gain -6
 call-forward pattern .T
 moh enable-g711
 web admin system name admin password cisco
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 transfer-pattern 9.T
 secondary-dialtone 9
 create cnf-files version-stamp 7960 Jul 26 2015 10:34:35
ephone-dn-template  1
 allow watch
ephone-template  1
 conference drop-mode creator
 conference admin
 --More--          max-calls-per-button 4
 busy-trigger-per-button 2
ephone-dn  1
 number 801... no-reg both
 mwi on
ephone-dn  2
 number 802... no-reg both
 mwi off
ephone-dn  3  dual-line
 number 500
 label Emin Balcioglu-500
 description 40065500
 name Emin Ismail Mahir Balcioglu
ephone-dn  4  dual-line
 number 521
 label Alanoud Mohammed Al-Jaber-521
 description 40065521
 name Alanoud Mohammed Al-Jaber
ephone-dn  5  dual-line
 number 557
 label Khalifa Ahmed Al-Obaidli-557
 description 40065557
 name Khalifa Ahmed Al-Obaidli
ephone-dn  6  dual-line
 number 535
 label Fahad Abdulla J M Al Turky-535
 description 40065535
 name Fahad Abdulla J M Al Turky
 --More--          ephone-dn-template 1
ephone-dn  7  dual-line
 number 531
 label Aisha Ali S A Al-Kuwari-531
 description 40065531
 name Aisha Ali S A Al-Kuwari
ephone-dn  8  dual-line
 number 588
 description 40065588
 name Abdulla Khalid A H Al-Naama
ephone-dn  9  dual-line
 number 512
 label Linnet Raymond Dsouza-512
 description 40065512
 name Linnet Raymond Dsouza
ephone-dn  10  dual-line
 number 577
 label Mohammed Ali Al-Yousuf-577
 description 40065577
 name Mohammed Ali Al-Yousuf
ephone-dn  11  dual-line
 number 508
 label Benedict ST Clare Barbour-508
 description 40065508
 name Benedict ST Clare Barbour
ephone-dn  12  dual-line
 --More--          number 553
 label Colin Vivian Jones-553
 description 40065553
 name Colin Vivian Jones
ephone-dn  13  dual-line
 number 554
 label Amani Al-Tamimi-554
 description 40065554
 name Amani Al-Tamimi
ephone-dn  14  dual-line
 number 551
 label Cali Muxidin Maxamed-551
 name Cali Muxidin Maxamed
ephone-dn  15  dual-line
 number 552
 description 40065552
 name Nasreen Mohammed A M Al-Malek
ephone-dn  16  dual-line
 number 550
 label Hafiz Ali Ali-550
 name Hafiz Ali Ali
ephone-dn  17  dual-line
 number 580
 description 40065580
 name Christopher Joseph Monaghan
 --More--         !
ephone-dn  18  dual-line
 number 525
 description 40065525
 name Aisha Mohamed Saud Al-Sinani
ephone-dn  19  dual-line
 number 545
 description 40065545
 name Nasser Falah S S Al-Remaihi
ephone-dn  20  dual-line
 number 546
 label Rashid Majid R S AL-Kuwari-546
 description 40065546
 name Rashid Majid R S AL-Kuwari
ephone-dn  21  dual-line
 number 532
 label Ghada Ali Al-Sayegh-532
 description 40065532
 name Ghada Ali Al-Sayegh
ephone-dn  22  dual-line
 number 534
 label Sara Al-Mannai-534
 description 40065534
 name Sara Al-Mannai
ephone-dn  23  dual-line
 number 505
 label Sara Nader Al-Hajri-505
 --More--          description 40065505
 name Sara Nader Al-Hajri
ephone-dn  24  dual-line
 number 569
 label Aisha Ali Al-Mannai-569
 description 40065569
 name Aisha Ali Al-Mannai
ephone-dn  25  dual-line
 number 530
 label Amnah Al-Faihani-530
 description 40065530
 name Amnah Al-Faihani
ephone-dn  26  dual-line
 number 515
 label Yousef M. Y. Deeb-515
 name Yousef M. Y. Deeb
ephone-dn  27  dual-line
 number 528
 label Alya Mahanna A M Al-Nuaimi-528
 description 40065528
 name Alya Mahanna A M Al-Nuaimi
ephone-dn  28  dual-line
 number 557
 label Mohammed R. M. Dalloul-557
 name Mohammed R. M. Dalloul
 --More--         !
ephone-dn  29  dual-line
 number 511
 label Bin Jelmood House-511
 description 40065511
 name Bin Jelmood House
ephone-dn  30  dual-line
 number 565
 label Omnia Fadlalla Ahmed-565
 description 40065565
 name Omnia Fadlalla Ahmed
ephone-dn  31  dual-line
 number 566
 label Hana Abounahia-566
 description 40065566
 name Hana Abounahia
ephone-dn  32  dual-line
 number 570
 label Zahra Abdulla-570
 description 40065570
 name Zahra Abdulla
ephone-dn  33  dual-line
 number 526
 label Safa Arshad-526
 description 40065526
 name Safa Arshad
ephone-dn  34  dual-line
 --More--          number 587
 label Mahmud Talla-587
 description 40065587
 name Mahmud Talla
ephone-dn  35  dual-line
 number 589
 label Abdullah Hemadi -589
 description 40065589
 name Abdullah Hemadi
ephone-dn  36  dual-line
 number 555
 label Msheireb Museums-555
 description 40065555
 name Msheireb Museums
ephone-dn  37  dual-line
 number 522
 label Company House-522
 description 40065522
 name Company House
ephone-dn  38  dual-line
 number 533
 label MBJ   House-533
 description 40065533
 name MBJ   House
ephone-dn  39  dual-line
 number 544
 label ARadwani House-544
 description 40065544
 --More--          name Radwani House
ephone-dn  40  dual-line
 number 556
 label FAX-556
 description 40065556
 name FAX
ephone-dn  41  dual-line
 number 599
 label IT Helpdesk-599
 description 40065599
 name IT Helpdesk
ephone-dn  42  dual-line
 number 588
 label Ali Rashid Al Senaid-588
 name Ali Rashid Al Senaid
ephone  1
 description 500
 mac-address 8890.8D73.B052
 ephone-template 1
 presence call-list
 type 7945
 button  1:3
ephone  2
 description 521
 mac-address 8890.8D73.AFBD
 ephone-template 1
 presence call-list
 --More--          type 7945
 button  1:4
ephone  3
 description 557
 mac-address 8890.8D73.B207
 ephone-template 1
 presence call-list
 type 7945
 button  1:5
ephone  4
 description 535
 mac-address 8890.8D73.B054
 ephone-template 1
 presence call-list
 type 7945
 button  1:6
ephone  5
 description 531
 mac-address 8890.8D73.B9AB
 ephone-template 1
 presence call-list
 type 7945
 button  1:7
ephone  6
 description 588
 mac-address 8890.8D73.B53D
 ephone-template 1
 presence call-list
 type 7945
 button  1:8
 --More--         !
ephone  7
 description 512
 mac-address 8890.8D73.AFD4
 ephone-template 1
 presence call-list
 type 7945
 button  1:9
ephone  8
 description 577
 mac-address 8890.8D73.B34C
 ephone-template 1
 presence call-list
 type 7945
 button  1:10
ephone  9
 description 508
 mac-address 8890.8D73.AEBA
 ephone-template 1
 presence call-list
 type 7945
 button  1:11
ephone  10
 description 553
 mac-address 8890.8D73.ABA8
 ephone-template 1
 presence call-list
 type 7945
 button  1:12
ephone  11
 --More--          description 554
 mac-address 8890.8D73.ACB5
 ephone-template 1
 presence call-list
 type 7945
 button  1:13
ephone  12
 description 551
 mac-address 8890.8D73.B046
 ephone-template 1
 presence call-list
 type 7945
 button  1:14
ephone  13
 description 552
 mac-address 8890.8D73.B535
 ephone-template 1
 presence call-list
 type 7945
 button  1:15
ephone  14
 description 550
 mac-address 8890.8D73.AA2B
 ephone-template 1
 presence call-list
 type 7945
 button  1:16
ephone  15
 description 580
 mac-address 8890.8D73.B428
 ephone-template 1
 --More--          presence call-list
 type 7945
 button  1:17
ephone  16
 description 525
 mac-address 8890.8D73.AD36
 ephone-template 1
 presence call-list
 type 7945
 button  1:18
ephone  17
 description 545
 mac-address 8890.8D73.B0C0
 ephone-template 1
 presence call-list
 type 7945
 button  1:19
ephone  18
 description 546
 mac-address 8890.8D73.B04A
 ephone-template 1
 presence call-list
 type 7945
 button  1:20
ephone  19
 description 532
 mac-address 8890.8D73.AD7A
 ephone-template 1
 presence call-list
 type 7945
 button  1:21
 --More--         !
ephone  20
 description 534
 mac-address 8890.8D73.B2EB
 ephone-template 1
 presence call-list
 type 7945
 button  1:22
ephone  21
 description 505
 mac-address 8890.8D73.B0C4
 ephone-template 1
 presence call-list
 type 7945
 button  1:23
ephone  22
 description 569
 mac-address 8890.8D73.AFCA
 ephone-template 1
 presence call-list
 type 7945
 button  1:24
ephone  23
 description 530
 mac-address 8890.8D73.AFC2
 ephone-template 1
 presence call-list
 type 7945
 button  1:25
 --More--         ephone  24
 description 515
 mac-address 8890.8D73.B429
 ephone-template 1
 presence call-list
 type 7945
 button  1:26
ephone  25
 description 528
 mac-address 8890.8D73.AD06
 ephone-template 1
 presence call-list
 type 7945
 button  1:27
ephone  26
 description 557
 mac-address 8890.8D73.AF0B
 ephone-template 1
 presence call-list
 type 7945
 button  1:28
ephone  27
 description 511
 mac-address 8890.8D73.AA27
 ephone-template 1
 presence call-list
 type 7945
 button  1:29
ephone  28
 description 565
 mac-address 40A6.E853.B9D8
 --More--          ephone-template 1
 presence call-list
 type 7945
 button  1:30
ephone  29
 description 565
 mac-address 8890.8D73.B23F
 ephone-template 1
 presence call-list
 type 7945
 button  1:31
ephone  30
 description 544
 mac-address 8890.8D73.B0C1
 ephone-template 1
 presence call-list
 type 7945
 button  1:32
ephone  31
 description 570
 mac-address 8890.8D73.B541
 ephone-template 1
 presence call-list
 type 7945
 button  1:33
ephone  32
 description 526
 mac-address 8890.8D73.B051
 ephone-template 1
 presence call-list
 type 7945
 --More--          button  1:34
ephone  33
 description 587
 mac-address 8890.8D73.B381
 ephone-template 1
 presence call-list
 type 7945
 button  1:35
ephone  34
 description 589
 mac-address 8890.8D73.B23C
 ephone-template 1
 presence call-list
 type 7945
 button  1:36
ephone  35
 description 555
 mac-address 8890.8D73.B23D
 ephone-template 1
 presence call-list
 type 7945
 button  1:37
ephone  36
 description 522
 mac-address 40A6.E853.96F1
 ephone-template 1
 presence call-list
 type 7945
 button  1:38
 --More--         !
ephone  37
 description 533
 mac-address 8890.8D73.B271
 ephone-template 1
 presence call-list
 type 7945
 button  1:39
ephone  38
 description 544
 mac-address 1111.1212.1213
 ephone-template 1
 presence call-list
 type 7945
 button  1:40
ephone  39
 description 556
 mac-address 8890.8D73.B278
 ephone-template 1
 presence call-list
 type 7945
 button  1:41
ephone  40
 description 599
 mac-address 8890.8D73.B333
 ephone-template 1
 presence call-list
 type 7945
 button  1:42
line con 0
 password cisco
 --More--          login local
line aux 0
line 131
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password cisco
 login local
scheduler allocate 20000 1000
end
Warm Regard's
Amit Sahrma
11 Replies 11
Generally speaking, you don't need to connect the cable physically to your router as long as IP reachability is established. However, looking at your config I see lot of things to be done.
1. You need to create a new subnet for WAN (either physical or subinterface). You can't share the same subnet for both LAN/WAN. Based on your current static routes and DHCP you will create asymmetric routing which will break connections.
2. You need to prepare your gateway for SIP trunk. I am share some config below but still you need to configure inbound dial-peers, translation-rules, etc.
voice service voip
 ip address trusted list
  ipv4 #Your ITSP IP#
 sip
  bind control source-interface #Source Interface for Signaling#
  bind media source-interface #Source Interface for Signaling#
 sip-ua
 credentials username 97440065555@ims.vodafone.qa password 7 vodafone123 realm vodafone.qa
 authentication username 97440065555@ims.vodafone.qa password 7 vodafone123 realm vodafone.qa
 retry invite 3
 retry register 2
 retry options 1
 timers trying 200
 timers connect 100
 sip-server ipv4:172.16.6.4:5067
thanks
Warm Regard's
Amit Sahrma
Sharma,
I would love to assist here but really want you to read more. You can't copy/paste a config from any document without understanding what is inside it.
The reason of this forum, to my understanding, for people to assist each  other to get things working but it should be in the right approach.
Please spend some time to understand basic CME configuration and basic SIP trunk integration.
Here are good links:
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html
http://www.innotechcg.com/resources/HowTo/Cisco%20CME%20SIP%20Trunk%20Configuration.pdf
http://www.dasblinkenlichten.com/cme-configuring-a-sip-trunk/
thanks for your reply Mohammed!
i am also going through multiple steps to apply it as per current setup and see the results.
I will review your document and see if help me to setup fully trunk with cme.
Warm Regard's
Amit Sahrma
thanks
Warm Regard's
Amit Sahrma
Warm Regard's
Amit Sahrma
Warm Regard's
Amit Sahrma
Warm Regard's
Amit Sahrma
Warm Regard's
Amit Sahrma
share config
thanks for your reply...
please find the attached show run of cme..
as i dial the number..it accept whole number but wait for long time and as i press Acct on ip phone and back softkey it provides the ringback tone..
why is this happening and how can i fix it/
Warm Regard's
Amit Sahrma
