CME 7.1
clark white
Level 2
Level 2
I have a issue with only 1 user,
when user A dials user B , User A is gets a busy tone though user B is not busy, user A goes on hook and dial again with in a 2 sec still it is a busy tone, when user A again dial thrice to user B the call gets connected, sometime call get connected in 1st attempt sometime 2nd attemt but this is happening with only 1 user.
Any hints please.
2 Accepted Solutions
ronpatel
Level 8
Level 8
Also see if the DN of phone B is configured twice for example
ephone-dn  X
number 2222
ephone-dn  y  dual-line
number 2222
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
You can assign same number to two different phone. It would be shared line.
Like
eohone-dn 1 dual/oct line
Number 11111
Ephone 1
Button 1:1
Ephone 2
Button 1:1
If answers are helpful and the issues is resolved, Please rate all posts by clicking stars below the answer.
Ronak Patel
8 Replies 8
ronpatel
Level 8
Level 8
HI
What is the firmware you have in your Ip phone A.
Ronak Patel
ronpatel
Level 8
Level 8
ephone-dn  X
number 2222
number 2222
Ronak Patel
yes it is there same extension to two ephone-dn, this might could be the reason for this issue.
I have seen similar issue and the issue was resolved by removing the duplicate ephone-dn confgration.
Ronak Patel
Thanks patel,
I have 1 question here if suppose two helpdesk needs a same extension ,then what can be configured for them.
Like
Number 11111
Ephone 1
Button 1:1
Ephone 2
Button 1:1
Ronak Patel
U deserve that i will do  once i do the configuration.
Thanks patel,
U are correct , U deserve the votes.
