01-10-2011 01:31 AM - edited 03-16-2019 02:46 AM
Hi all, I'm trying to use my Iphone as extensions of my CME
I've tryed both CounterPath Bria and Linphone with this configuration:
voice register global
mode cme
source-address 192.168.10.254 port 5060
max-dn 20
max-pool 10
authenticate register
authenticate realm cme
tftp-path flash:
file text
create profile sync 0372431455915402
voice register dn 1
number 1207
allow watch
name Enrico
no-reg
label Enrico
voice register pool 1
id mac 0000.0000.0000
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username 1207 password XXXX
codec g711ulaw
The SIP client is registered with CME and these are the results:
Linphone: two way audio, outgoing calls OK, incoming calls FAIL
Bria: one way audio, outgoing calls OK, incoming calls OK
Can someone share his experience with Iphone, how can I use it with my CME in SIP mode?
Enrico
01-10-2011 02:12 AM
This is what I see in the debug when the incoming calls fail:
CME#
Jan 10 10:07:58.361: //3323/5568370EA07C/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1207@192.168.1.188:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.228:5060;branch=z9hG4bK2BBDB1
Remote-Party-ID: "NAME" <257>;party=calling;screen=no;privacy=off
To: <1207>
Date: Mon, 10 Jan 2011 10:07:58 GMT
Call-ID: 55907EB8-1BD811E0-A081F28B-7149801C@192.168.1.228
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1432893198-0467145184-2692543115-1900642332
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1294654078
Contact: <257>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 323257>1207>257>257>
v=0
o=CiscoSystemsSIP-GW-UserAgent 5106 8027 IN IP4 192.168.1.228
s=SIP Call
c=IN IP4 192.168.1.228
t=0 0
m=audio 18062 RTP/AVP 0 100 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
01-10-2011 04:49 AM
Does the phone registers to CME ?
01-10-2011 05:37 AM
Yes
UC500#show voice register pool 1
Pool Tag 1
Config:
Mac address is 0000.0000.0000
Number list 1 : DN 1
Proxy Ip address is 0.0.0.0
DTMF Relay is enabled, rtp-nte
Call Waiting is enabled
DnD is disabled
Busy trigger per button value is 0
keep-conference is enabled
username 1207 password 1207
blf call list is enabled
Transport type is udp
service-control mechanism is not supported
registration Call ID is 552960606
Privacy feature is not configured.
Privacy button is disabled
active primary line is: 1207
contact IP address: 192.168.99.86 port 5060
Dialpeers created:dial-peer voice 40003 voip
destination-pattern 1207
session target ipv4:192.168.99.86:5060
session protocol sipv2
dtmf-relay rtp-nte
codec g711ulaw bytes 160
after-hours-exempt FALSE
Statistics:
Active registrations : 1
Total SIP phones registered: 1
Total Registration Statistics
Registration requests : 19
Registration success : 19
Registration failed : 0
unRegister requests : 18
unRegister success : 18
unRegister failed : 0
UC500#01-10-2011 06:15 AM
Then something is wrong with the registration, because phone is registered as .86, CME sends invite to a different IP, from which receives no answer.
01-10-2011 07:07 AM
No because I take the debug from another router with different IP.
This is the correct debug:
Jan 10 15:04:32.175: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1207@192.168.99.86:5060 SIP/2.0
Date: Mon, 10 Jan 2011 15:04:32 GMT
Min-SE: 1800
Remote-Party-ID: "Enrico" <1007>;party=calling;screen=no;privacy=off
Cisco-Guid: 3269730557-469832160-2776993663-322050898
Timestamp: 1294671872
Content-Length: 320
To: <1207>
Contact: <1007>
Expires: 180
Call-ID: C380FE5F-1C0111E0-A58A8F7F-13321B52@192.168.99.1
Via: SIP/2.0/UDP 192.168.99.1:5060;branch=z9hG4bK6832B5F7
CSeq: 101 INVITE
Max-Forwards: 701007>1207>1007>1007>
v=0
o=CiscoSystemsSIP-GW-UserAgent 9362 9954 IN IP4 192.168.99.1
s=SIP Call
c=IN IP4 192.168.99.1
t=0 0
m=audio 16402 RTP/AVP 0 100 101 19
a=fmtp:100 192-194
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
1007 is my SCCP phone
1207 is my SIP client
192.168.99.1 is the router IP
192.168.99.86 is the SIP client IP
01-10-2011 11:44 AM
The you have to find why the iphone does not respond to the Invite message.
01-11-2011 05:56 AM
Finally I have my Bria client on Iphone registered and woriking with CME 8.5, the problem is the default NAT configuration so the client present himself with the public IP. In the "advanced setting" menu the NAT configuration MUST be set to "server managed" and this solve the problem.
Enrico Pasqualotto
NetspinLAB
01-11-2011 08:38 AM
Enrico, had you mentioned you were using NAT it would have been easier to suggest a solution
