CME 8.6 and 2 or more SIP Numbers
Michael Durham
Level 4
Level 4
I am running two companies from one location where we have a 2851 with IOS 15.1.  Our SIP provider (Anveo) provides us two phone numbers, one for each business.  We can separate where inbound calls go so we can answer the call with the correct company name.
The problem is when we have to dial a customer, only one company's caller-id information is passed.  How can we set up a dial-peer so that we can dial a code and call go out showing the other company's phone number and CName?
Currently all calls go out with the 386243xxxx number showing.
Thank You,
Michael
voice service voip
ip address trusted list
ipv4 72.9.149.69
ipv4 185.35.78.39
ipv4 10.110.0.2
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
sip
registrar server
voice class codec 1
codec preference 1 g711ulaw
voice register global
max-pool 50
voice register pool 20
no digit collect kpml
voice translation-rule 1
rule 1 /1386243xxxx/ /1000/
rule 2 /1844287xxxx/ /1000/
rule 3 /1386456xxxx/ /1538/
voice translation-rule 2
rule 1 /\([2-9].........\)/ /1\1/
voice translation-rule 3
rule 1 /411/ /18003733411/
voice translation-rule 4
rule 1 reject /0/
voice translation-profile BLOCK-INBOUND
translate calling 4
voice translation-profile Free_411
translate called 3
voice translation-profile Incoming_calls
translate called 1
voice translation-profile Ten_Digit_Dialing
translate called 2
dial-peer voice 100 voip
description *** Incoming Calls VoIP ***
translation-profile incoming Incoming_calls
call-block translation-profile incoming BLOCK-INCOMING
call-block disconnect-cause incoming call-reject
preference 1
session protocol sipv2
session target sip-server
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 210 voip
corlist outgoing Door-National
description *** Outbound 10 Digit Dialing Calls ***
translation-profile outgoing Ten_Digit_Dialing
preference 1
destination-pattern [2-9].........$
translate-outgoing called 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
description *** Outbound 11 Digit Dialing Calls ***
preference 1
destination-pattern 1[2-9]..[2-9]......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
Jaime Valencia
Configure COR and if necessary, configure translation rules to adjust the ANI you're sending.
java
if this helps, please rate
how do I adjust the ANI that I am sending?  I need an example please
e.g. of changing ANI for outbound calls
company1 user ext range : 1XXX
Company2 user ext rnage : 2XXX
voice translation-rule 5
rule 1 /1XXX/ /COMPANY1number/
rule 2 /2XXX/ /COMPANY2number/
translate called 2
translate calling 5
preference 1
