CME 8.6 and Exchange 2013
Seems like I have gotten everything working with merging the two, the only thing I am not getting is why when calls from outside are just ringing and ringing to users extension with out voicemail. Before transferring to user it asks to hit # and leave message and this works but maybe I am missing something?
Hi Frederick,
kindly check the below link, it is helpful
http://technet.microsoft.com/en-us/library/aa997885(v=exchg.150).aspx
just to make sure, you are using exchange 2013 as voicemail system, right ?
Anas
please don't forget to rate the helpful posts
Any recommendations?
Hi Frederick,
Anas
Recognize Your Peers
