02-22-2012 11:38 PM - edited 03-16-2019 09:44 AM
Hi all,
When making ad hoc conference call with 6 persons, how can I press "confrn" to connect others in one CP7942.
1. CP7942 A dial to B
2. Press "confrn" in CP7942 to C
3. Press "confrn" in CP7942
4. A, B and C are in conference
5. Press "confrn" in CP7942
6. C will drop call <------- So, A cannot make conference call with 6 person in CP7942
Leung Che Man
02-23-2012 02:52 AM
This is due to your conferencing config.
Can you post the show run
Rgards
Alex
02-23-2012 06:00 PM
02-24-2012 03:47 AM
You have no DSP resources configured to provide conferencing.
You asre using the default which only allows a 3 way call.
Please read this chapter in the CME Admin guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html
Alex
Please rate useful posts
02-26-2012 05:46 PM
Hi Alex,
Thanks for your information. Could you state which part is the required subject ?
Leung Che Man
02-27-2012 03:12 AM
You need to start at this section of the admin guide.
Perform all the steps
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1020601
•SCCP: Enabling DSP Farm Services for a Voice Card (required)
•SCCP: Configuring Join and Leave Tones (optional)
•SCCP: Configuring SCCP for Cisco Unified CME (required)
•SCCP: Configuring the DSP Farm (required)
•SCCP: Associating Cisco Unified CME with a DSP Farm Profile (required)
•SCCP: Enabling Multi-Party Ad Hoc and Meet-Me Conferencing (required)
•SCCP: Configuring Multi-Party Ad Hoc Conferencing and Meet-Me Numbers (required)
•SCCP: Configuring Conferencing Options for a Phone (required)
•SCCP: Verifying Multi-Party Ad Hoc and Meet-Me Conferencing (optional)
Alex
02-27-2012 07:16 PM
I will follow the steps and post the result
LEung Che Man
03-01-2012 09:38 PM
03-01-2012 09:43 PM
HI
It seems your conference resources are not registered to CME....
Can you send us new configutaion which you have done after following above mentioned steps.
Ronak Patel
03-01-2012 10:11 PM
Please refer to my previous post.
Leung Che Man
03-01-2012 10:25 PM
I am sorry I missed that...
Please send me Show diag and out put of "Show SCCP"
Ronak Patel
03-01-2012 10:34 PM
nshk-cme#sh sccp
SCCP Admin State: UP
Gateway Local Interface: FastEthernet0/1
IPv4 Address: 10.34.195.222
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.10.1, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 1
Trustpoint: N/A
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.10.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 16, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
nshk-cme#sh diag
Slot 0:
C2801 2FE 4SLOT Mainboard Port adapter, 7 ports
Port adapter is analyzed
Port adapter insertion time 00:04:19 ago
EEPROM contents at hardware discovery:
Chassis MAC Address : 001b.548b.49de
MAC Address block size : 34
PCB Serial Number : FOC11150GY0
Hardware Revision : 6.0
Part Number : 73-8190-06
Board Revision : B0
Top Assy. Part Number : 800-23435-04
Deviation Number : 88989
Fab Version : 04
CLEI Code : IPM7S00CRA
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : CISCO2801
Version Identifier : V03
Processor type : 86
Chassis Serial Number : FHK1117F1MC
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C3 06 00 1B 54 8B 49 DE 43 00 22 C1 8B 46
0x10: 4F 43 31 31 31 35 30 47 59 30 40 04 1C 41 06 00
0x20: 82 49 1F FE 06 42 42 30 C0 46 03 20 00 5B 8B 04
0x30: 88 00 01 5B 9D 02 04 C6 8A 49 50 4D 37 53 30 30
0x40: 43 52 41 03 00 81 00 00 00 00 04 00 CB 89 43 49
0x50: 53 43 4F 32 38 30 31 89 56 30 33 20 D9 02 C1 40
0x60: 09 86 C2 8B 46 48 4B 31 31 31 37 46 31 4D 43 FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x110: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x130: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8538-05
Board Revision : A0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC10130M0G
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-16
Version Identifier : V01
0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 31 33
0x20: 30 4D 30 47 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Board Revision : C0
Fab Version : 04
PCB Serial Number : FOC13374RX3
RMA History : 00
Processor type : 00
0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 43 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 33 33 37
0x20: 34 52 58 33 03 00 81 00 00 00 00 04 00 09 00 CB
WIC/VIC/HWIC Slot 1:
4 Port FE Switch
Base MAC Address : 001a.6dee.17be
MAC Address block size : 4
PCB Serial Number : FOC10493T7B
Part Number : 73-8474-06
Board Revision : A0
Top Assy. Part Number : 800-24193-02
Fab Version : 05
CLEI Code : IPUIA00RAA
RMA History : 00
Product (FRU) Number : HWIC-4ESW
Connector Type : 01
0x00: 04 FF CF 06 00 1A 6D EE 17 BE 43 00 04 C1 8B 46
0x10: 4F 43 31 30 34 39 33 54 37 42 40 00 56 41 06 00
0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
4-Port HWIC-ESW Power Daughter Card:
Part Number : 73-8476-04
Board Revision : A0
Fab Version : 03
PCB Serial Number : FOC10484B3P
RMA History : 00
Product (FRU) Number : ILPM-4
CLEI Code : IPUPACDAAA
0x00: 04 FF 40 00 57 41 04 00 82 49 21 1C 04 42 41 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 30 34 38
0x20: 34 42 33 50 03 00 81 00 00 00 00 04 00 CB 86 49
0x30: 4C 50 4D 2D 34 89 56 30 31 20 C6 8A 49 50 55 50
0x40: 41 43 44 41 41 41 FF FF FF FF FF FF FF FF FF FF
0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF 42 C8
WIC/VIC Slot 2:
E1 (1 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision A0
Serial number 20561972 Part number 800-04475-02
FRU Part Number VWIC-1MFT-E1=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 21 01 00 01 39 C0 34 50 11 7B 02 00 00 00 00
0x30: 50 00 00 00 00 06 21 00 FF FF FF FF FF FF FF FF
AIM Module in slot: 0
Service Engine AIM: 0
Hardware Revision : 1.0
Top Assy. Part Number : 800-20063-06
Board Revision : B0
Fab Version : 05
PCB Serial Number : FOC11286LZK
RMA History : 00
Product (FRU) Number : AIM-CUE
0x00: 04 FF 40 03 8E 41 01 00 C0 46 03 20 00 4E 5F 06
0x10: 42 42 30 88 00 00 00 00 02 05 C1 8B 46 4F 43 31
0x20: 31 32 38 36 4C 5A 4B 03 00 81 00 00 00 00 04 00
0x30: CB 87 41 49 4D 2D 43 55 45 89 56 30 33 20 FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
nshk-cme#
Leung Che Man
03-01-2012 11:10 PM
I
believe you have less DSP resources
Let us have look in to
show dspfarm dsp all
show dspfarm profile
show dspfarm profile 2
show voice dsp
Please send it is attachment rather pasting it in post.
Ronak patel
03-01-2012 11:36 PM
