02-08-2016 06:17 PM - edited 03-17-2019 05:48 AM
I swapped out my 2851 with another one today using nearly the same config file. The old router had a few issues but the dialing worked fine. Now the with the replacement router, when I dial a 1 it goes to fast busy instantly. My extension numbers start with a 1 just as they did in the other router, no change there and no change in the dial-peer plans too.
I have a dial-peer for 11 digit dialing and one for 10 digit dialing. The 10 digit dialing just adds the 1 before placing the call. Ten digit dialing works perfectly. Any ideas why I cannot dial a 1? Oh, I do block dialing zero but not the 1.
If you see ANYTHING else wrong i my full config file that is attached, your comments are very much welcome!!!
voice service voip
ip address trusted list
ipv4 7.9.1.6
ipv4 15.3.7.39
ipv4 10.110.0.2
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
sip
registrar server
voice class codec 1
codec preference 1 g729r8
voice translation-rule 1
rule 1 /18885551212/ /1000/
voice translation-rule 2
rule 1 /\([2-9].........\)/ /1\1/
voice translation-rule 3
rule 1 /411/ /18003733411/
voice translation-rule 4
rule 1 reject /0/
voice translation-profile BLOCK-INBOUND
translate calling 4
voice translation-profile Free_411
translate called 3
voice translation-profile Incoming_calls
translate called 1
voice translation-profile Ten_Digit_Dialing
translate called 2
dial-peer cor custom
name LoK_Local
name LoK_National
name LoK_International
name LoK_EMS
dial-peer cor list Keyring-Local
member LoK_Local
member LoK_EMS
dial-peer cor list Keyring-National
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Keyring-International
member LoK_Local
member LoK_National
member LoK_International
member LoK_EMS
dial-peer cor list Keyring-EMS-Only
member LoK_EMS
dial-peer cor list Door-Local
member LoK_Local
member LoK_EMS
dial-peer cor list Door-National
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Door-International
member LoK_Local
member LoK_National
member LoK_EMS
dial-peer cor list Door-EMS-Only
member LoK_EMS
dial-peer voice 911 voip
corlist outgoing Door-EMS-Only
destination-pattern 911
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 100 voip
description *** Incoming Calls VoIP ***
translation-profile incoming Incoming_calls
call-block translation-profile incoming BLOCK-INCOMING
call-block disconnect-cause incoming call-reject
preference 1
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
corlist outgoing Door-National
description *** Outbound 11 Digit Dialing Calls ***
preference 1
destination-pattern 1[2-9]..[2-9]......$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 210 voip
description *** Outbound 10 Digit Dialing Calls ***
translation-profile outgoing Ten_Digit_Dialing
preference 1
destination-pattern [2-9].........$
translate-outgoing called 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 220 voip
description *** Outbound - Free 411 (Information) Calls ***
translation-profile outgoing Free_411
preference 1
destination-pattern 411
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 5000 voip
description Dial-peer to the Voicemail System"
destination-pattern 5000
b2bua
session target ipv4:10.110.0.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer inbound selection sip-trunk
sip-ua
credentials username 8885551212 password 7 082D6D57242 realm anveo.com
authentication username 8885551212 password 7 0114271500 realm anveo.com
mwi-server ipv4:10.110.0.2 expires 3600 port 5060 transport udp unsolicited
registrar dns:sip.anveo.com:5010 expires 180
sip-server dns:sip.anveo.com:5010
ephone-dn 1 dual-line
number 1000
label Solutions
description Main Line
call-forward busy 5000
call-forward noan 5000 timeout 17
corlist incoming Keyring-National
corlist outgoing Keyring-National
ephone-dn 2 dual-line
number 1010
label Sales
description Sales Line
ephone 10
device-security-mode none
description "Michael T. Durham"
mac-address 0024.C4FD.341A
type 7962
mwi-line 2
button 1:10 2:1 3:20 4:21
button 5:22 6:4
Solved! Go to Solution.
02-08-2016 08:57 PM
Your COR assignment isn't correct. You DNs are using Keyring-National for incoming while your Dialpeers are using Door-National for outgoing. Door isn't member of Keyring and the call is getting blocked. For same reasons you can't call other DNs.
Have a quick read about COR Lists and then review your config. For time being try to remove cor-list from all dialpeers and ephones. This will make calls working but without any restrictions.
02-08-2016 08:33 PM
Problem in dialing 11 digit is only from 9971 or from SCCP phones too?
Is this problem similar to your below post;
https://supportforums.cisco.com/discussion/12884816/cme-9971-sip-phone-not-working#comment-11138671
- Vivek
02-09-2016 05:54 AM
I will check the corlists and see what I need to change.
The 9971 cannot dial anywhere, all digits on that phone get a fast busy instantly
02-08-2016 08:57 PM
