CME 8.6 integration with Polycom IP 7000 Sound station
pratapag5
Hi Team,
I need to integrate an IP 7000 device with CME version 8.6. I understand that IP 7000 talks only SIP. So, first of all I would like to know if this integration is posible. If it is possible, I would like to know what the required IP 7000 firmware version is for integration with CME. Also, could you please point me to a document with the integration procedure?
Thanks in advance.
Suchitra
5 Replies 5
paolo bevilacqua
You can search for "CME third-party SIP phone", a subject that has been discussed many many, times already.
Thanks for the reply, Paolo. More than the configuration, I want to know the SIP firmware image for IP 7000 on CME. Could you please let me know this information? I did not get this information from any previous discussion (I have checked most of these).
Suchitra
Polycom IP 7000 is not Cisco product, so Cisco CME will not give any firmware for it.
If you are talking about 7937G phone which are Cisco Conference phones, these phones are SCCP phones.
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi, I am trying to register a Polycom Ip 7000 with CME, but I am getting the following errors:
Mar 31 11:45:01: voice_reg_get_reg_expires_timer: no voice register pool found
Mar 31 11:45:01: VOICE_REG_POOL: Register request for (74500) from (149.77.184.43)
Mar 31 11:45:01: auth absent
Mar 31 11:45:01: VOICE_REG_POOL: key(1026666623088358) added to nonce table
Mar 31 11:45:01: VOICE_REG_POOL: Contact doesn't match any pools
Mar 31 11:45:02: auth present
Mar 31 11:45:02: VOICE_REG_POOL: Contact doesn't match any pools
Mar 31 11:45:02: voice_reg_get_reg_expires_timer: no voice register pool found
Mar 31 11:45:02: VOICE_REG_POOL: Register request for (74500) from (149.77.184.43)
Mar 31 11:45:03: auth absent
Mar 31 11:45:03: VOICE_REG_POOL: key(B96F164F230883E7) added to nonce table
Mar 31 11:45:03: VOICE_REG_POOL: Contact doesn't match any pools
Mar 31 11:45:03: voice_reg_get_reg_expires_timer: no voice register pool found
Mar 31 11:45:03: VOICE_REG_POOL: Register request for (74500) from (149.77.184.43)
Mar 31 11:45:03: auth present
Mar 31 11:45:45: voice_reg_get_reg_expires_timer: no voice register pool found
Mar 31 11:45:45: VOICE_REG_POOL: Register request for (74500) from (149.77.184.43)
Mar 31 11:45:45: auth absent
Mar 31 11:45:45: VOICE_REG_POOL: key(D2AA312B23089480) added to nonce table
Mar 31 11:45:45: VOICE_REG_POOL: Contact doesn't match any pools
Mar 31 11:45:46: auth present
Mar 31 11:45:46: VOICE_REG_POOL: Contact doesn't match any pools
Also, "
sh voice register pool attempted-registrations" clearly tells that this is some authorization issue.
cme1.mjv.shaw.net#sh voice register pool attempted-registrations
Phones that have attempted registrations and have failed:
MAC address:
IP address : 149.77.184.43
Attempts   : 218
Time of first attempt : 11:04:34.217 UTC Sat Mar 31 2012
Time of latest attempt: 11:55:27.169 UTC Sat Mar 31 2012
Reason for failure    :
        Unauthorized registration request
Could you please help me fix this issue?
Here is the related configuration from my device:
voice service voip
allow-connections sip to sip
sip
  registrar server expires max 1200 min 300
voice register global
mode cme
source-address 10.240.215.16 port 5060
max-dn 5
max-pool 5
tftp-path flash:
create profile sync 2251060396647059
voice register dn  1
number 55555
voice register dn  2
number 74500
voice register pool  1
id mac 0004.F2E8.BACC
number 1 dn 2
dtmf-relay sip-notify
username PlcmSplp password PlcmSplp
codec g711ulaw
Suchitra
As you can see, I have not configured any "load" configuration. Please suggest here.
Suchitra
