01-14-2020 12:45 AM
Hello I have installed CME 8.6 on CISCO 2851 Router with the following IOS version c2800nm-adventerprisek9-mz.151-4.M8.bin.
I have several phones 7911 which are not registering themselves though I have added them to the tftp and also loads are perfect.
When the Phone start it takes all the loads properly and hangs at registering
Running the command debug tftp-events
I can see the its trying to read
un 8 17:30:35.447: TFTP: Looking for SEP001A2F336D26.cnf.xml
Jun 8 17:30:35.547: TFTP: Opened system:/its/XMLDefault7960.cnf.xml, fd 0, size 793 for process 81
and stops
Solved! Go to Solution.
01-16-2020 04:45 AM
The problem was from bad loads (Bad Firmware) which I redownloaded and configured it worked.
I dont understand when performing the command
loads 7911 SCCP..XX.X.XX.loads
Some places its mentioned to used the extension and some place its not.
This time I have not used the extension and it worked.
01-14-2020 12:49 AM
Is this a brand new Installation or it was working before and upon upgrade does not work anymore?
Could you post part of your configuration and identify if you have created correct (correct MAC address) the ephone entries on the CME?
Last but not least, under telephony services have you created cnf files? -> Router(config-telephony)# create cnf-files
G
01-14-2020 12:55 AM
I will post my configurations to you soon
01-14-2020 05:11 AM
Meanwhile, you may check the following link where the basic troubleshooting methods are described:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_phreg.html
Hope these help,
G
01-16-2020 04:45 AM
01-17-2020 12:22 AM
This is good to know and thanks for sharing
On the load command you should always be careful the name of the file to be exactly the same as the file that is listed in the flash of the CME. Last but not least you may read (if not already done) the following "Basic Configuration Guide for CUCME/CME" guide:
Kind regards,
George
01-18-2020 09:49 PM
I have seen some times that some firmwares are added using extension. Loads and some are not like
7911 is .Loads and 7940 is without ...
Why is this ??
