CME 8.6 with multiple DID's
Michael Durham
Level 4
Level 4
WE have a working CME 8.6 system on a 2851 router and we have 5 DID's, 2 toll free inbound only and 3 inbound/outbound for 3 divisions of my company.  We use 4 digit dialing for internal calls.  Each phone has an appearance for each of the 3 DIDs and calls come inbound to each appearance correctly; no problems there.
However, when we place outbound calls, all calls have one caller ID.  How do we get the caller ID to change based upon the button (appearance) selected when placing the call
IE: Button 1 is assigned to the extension 1100, button 2 is assigned to 5552220000, button 3 is assigned to 5553334444 and button 4 is assigned to 5557779999.
No matter which button is selected for an outbound call, the receiving party sees the caller ID as 5552220000.  I want it so that if I press button 3 and call my cell phone, my cell phone shows the calling party of 5557779999 NOT 5552220000 as it does now.
Here is my current config:
voice translation-rule 1
rule 1 /15552220000/ /1000/
rule 2 /18442220000/ /1000/
rule 3 /15553334444/ /1538/
rule 4 /15557779999/ /1999/
rule 5 /18447779999/ /1999/
dial-peer voice 200 voip
corlist outgoing Door-National
description *** Outbound 11 Digit Dialing Calls ***
preference 1
destination-pattern 1[2-9]..[2-9]......$
session protocol sipv2
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
ephone-dn 1 dual-line
number 1000
label CTS
description CTS Main Line
call-forward busy 5000
call-forward noan 5000 timeout 17
corlist incoming Keyring-National
number 1538
label KDT
description KDT Main Line
ephone-dn 8 dual-line
number 1999
label "PSE"
description PSE Main  line
call-forward noan 5000 timeout 25
ephone-dn 10 dual-line
number 1100
label Michael
description Michael
name Michael
ephone 10
device-security-mode none
description "Michael"
mac-address 0014.A998.C12D
ephone-template 1
type 7971
mwi-line 2
button 1:10 2:1 3f6 4f8
button 5:30 6:32 7:34 8:36
Turns out it was a setting at our SIP privider that was changing the caller-id on us.  Thank you for the help.
6 Replies 6
Chris Deren
Your translation rule 1 is reverse, it matches the 11 digits and translates to 4 digits, reading you post it appears you want to do the reverse to mask caller id.
You can use "debug voice translation" to see if proper digits are matched and translated when you make the test call.
Still not worling.  My fake cell number is 5552901577 which is the number that I called from button 3 (5557779999) in the debug below
001500: Aug 25 12:19:55.650: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
   Voice port 0x4D0FECB0 dsl=-1 timeslot=0 does not belong to any trunk group
001501: Aug 25 12:19:55.658: //-1/10F6F78D80CB/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4DBA7430; count=1
001502: Aug 25 12:19:55.658: //-1/10F6F78D80CB/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x50451B08
001503: Aug 25 12:19:55.662: //-1/10F6F78D80CB/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4DBA7430; count=1
TDC_CME_Router(config)#
001504: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
001505: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_translate_internal: number=1999 type=unknown plan=unknown numbertype=calling
001506: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_match: No match; number=1999 rule precedence=1
001507: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_match: No match; number=1999 rule precedence=2
001508: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_match_internal: Matched with rule 3 in ruleset 5
001509: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_match: No match; number=1999 rule precedence=1
001510: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_match: No match; number=1999 rule precedence=2
001511: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_match_internal: Matched with rule 3 in ruleset 5
001512: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_match: No match; number=1999 rule precedence=1
001513: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_match: No match; number=1999 rule precedence=2
001514: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/sed_subst: Successful substitution; pattern=1999 matchPattern=1999 replacePattern=15557779999 replaced pattern=15557779999
001515: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
001516: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
001517: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_translate_internal: xlt_number=15557779999 xlt_type=unknown xlt_plan=unknown
001518: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_translate_internal: number=15552901577 type=unknown plan=unknown numbertype=called
001519: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
001520: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
001521: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_translate_internal: No match: number=15552901577 type=unknown plan=unknown
001522: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
001523: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
001524: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-target number not found
001525: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
001526: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
001527: Aug 25 12:20:00.870: //-1/10F6F78D80CB/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
001528: Aug 25 12:20:00.874: //-1/10F6F78D80CB/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
001529: Aug 25 12:20:00.874: //-1/10F6F78D80CB/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
001530: Aug 25 12:20:00.878: //-1/10F6F78D80CB/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4DBA7430; count=1
001531: Aug 25 12:20:00.878: //-1/10F6F78D80CB/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x50451B08
001532: Aug 25 12:20:00.878: //-1/10F6F78D80CB/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4DBA7430; count=1
001533: Aug 25 2017 12:20:19.750: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 10F6F78D88E811E780CBC55FD770BE34, SetupTime 12:19:55.660 DST Fri Aug 25 2017, PeerAddress 1999, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 12:20:02.650 DST Fri Aug 25 2017, DisconnectTime 12:20:19.750 DST Fri Aug 25 2017, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 835, ReceiveBytes 133600
001534: Aug 25 2017 12:20:19.754: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/25/2017 12:19:55.658,cgn:1999,cdn:,frs:0,fid:694,fcid:10F6F78D88E811E780CBC55FD770BE34,legID:5C6FC,bguid:10F6F78D88E811E780CBC55FD770BE34
001535: Aug 25 12:20:19.758: //-1/10F6F78D80CB/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4DBA7430; count=1
001536: Aug 25 12:20:19.758: //-1/10F6F78D80CB/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x50451B08
001537: Aug 25 2017 12:20:19.830: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 10F6F78D88E811E780CBC55FD770BE34, SetupTime 12:20:00.890 DST Fri Aug 25 2017, PeerAddress 15552901577, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 12:20:02.640 DST Fri Aug 25 2017, DisconnectTime 12:20:19.830 DST Fri Aug 25 2017, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 835, TransmitBytes 133600, ReceivePackets 836, ReceiveBytes 133760
001538: Aug 25 2017 12:20:19.830: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/25/2017 12:20:00.874,cgn:15557779999,cdn:15552901577,frs:0,fid:695,fcid:10F6F78D88E811E780CBC55FD770BE34,legID:5C6FD,bguid:10F6F78D88E811E780CBC55FD770BE34
001539: Aug 25 12:20:19.830: //-1/10F6F78D80CB/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
So, the caller ID is still not changing?
The debug shows the number changing:
That does not seem like a correct number, so it's possible carrier rejects the call, etc. Mask it to a DID you own.
Can you post "debug ccsip messages" as well?
5559487364 account number from SIP provider
<sip:1103@sip.anveo.com> not sure why this is coming up.  The phone extension that I am dialing our from is 1100.
001559: Aug 25 13:30:43.402: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:5559487364@100.101.164.76:5060 SIP/2.0
Via: SIP/2.0/UDP 72.9.149.69:5010;branch=0
From: sip:ping@noname.com;tag=uloc-599f6887-1031-8bb502-ae825c36-c7413937
To: sip:5559487364@100.101.164.76:5060
Call-ID: 4501bfe4-2962bad4-3dd51d4@72.9.149.69
CSeq: 1 OPTIONS
Content-Length: 0
001560: Aug 25 13:30:43.406: //379740/F4D2991E815E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: sip:5559487364@100.101.164.76:5060;tag=555DEE40-8B4
Date: Fri, 25 Aug 2017 17:30:43 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Accept: application/sdp
Supported: 100rel,timer,reso
TDC_CME_Router#urce-priority,replaces,sdp-anat
Content-Type: application/sdp
Content-Length: 175
v=0
o=CiscoSystemsSIP-GW-UserAgent 3150 7689 IN IP4 100.101.164.76
s=SIP Call
c=IN IP4 100.101.164.76
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15 3
TDC_CME_Router#
001561: Aug 25 13:30:54.723: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:15552901577@sip.anveo.com:5010 SIP/2.0
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB419E1
Remote-Party-ID: <sip:15557779999@100.101.164.76>;party=calling;screen=no;privacy=off
From: <sip:15557779999@sip.anveo.com>;tag=555E1A74-2436
To: <sip:15552901577@sip.anveo.com>
Date: Fri, 25 Aug 2017 17:30:54 GMT
Call-ID: FB9016F1-88F111E7-8164C55F-D770BE34@100.101.164.76
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 4162403296-2297500135-2170537311-3614490164
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1503682254
Contact: <sip:15557779999@100.101.164.76:5060>
Expires: 180
Content-Disposition: session;handling=required
Content-Length: 253
v=0
o=CiscoSystemsSIP-GW-UserAgent 7367 1818 IN IP4 100.101.164.76
s=SIP Call
t=0 0
m=audio 17336 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
001562: Aug 25 13:30:54.807: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB419E1;rport=7438;received=174.227.13.124
To: <sip:15552901577@sip.anveo.com>;tag=9c1e0102a8b6ae5534bc36ba1ad58706.28dd
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="anveo.com", nonce="WaBf+lmgXs7b/dv//2dKD0QWtSVDqTi8", qop="auth"
Server: Anv Edge Proxy 3.5
Content-Length: 0
001563: Aug 25 13:30:54.811: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:15552901577@sip.anveo.com:5010 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
001564: Aug 25 13:30:54.811: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB526BE
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="5559487364",realm="anveo.com",uri="sip:15552901577@sip.anveo.com:5010",response="b8ff8a2a76ad2cb65685e9aa66610ea8",nonce="WaBf+lmgXs7b/dv//2dKD0QWtSVDqTi8",cnonce="A63C0685",qop=auth,algorithm=md5,nc=00000001
Content-Length: 253
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
001565: Aug 25 13:30:54.895: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Received:
TDC_CME_Router#SIP/2.0 100 trying -- your call is important to us
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB526BE;rport=7438;received=174.227.13.124
CSeq: 102 INVITE
Content-Length: 0
001566: Aug 25 13:30:55.799: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Received:
TDC_CME_Router#SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 100.101.164.76:5060;rport=7438;received=174.227.13.124;branch=z9hG4bKA1EB526BE
Record-Route: <sip:72.9.149.69:5010;lr=on;nat=yes>
To: <sip:15552901577@sip.anveo.com>;tag=as18c22c28
CSeq: 102 INVITE
User-Agent: Anveo Server v10.4
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Contact: <sip:127.0.0.8;anveohash=enc-aKu.c68JXth-cHWQdHavhta-C6lfXHhJC6UJc6lQXHl*>
Content-Length: 0
001567: Aug 25 13:30:57.015: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 227
v=0
o=root 2225 2225 IN IP4 72.9.149.69
s=session
c=IN IP4 72.9.149.69
t=0 0
m=audio 51908 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
a=nortpproxy:yes
001568: Aug 25 13:30:57.035: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:127.0.0.8:5060;anveohash=enc-aKu.c68JXth-cHWQdHavhta-C6lfXHhJC6UJc6lQXHl* SIP/2.0
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB6BE4
Max-Forwards: 70
CSeq: 102 ACK
TDC_CME_Router#p:15552901577@sip.anveo.com:5010",response="b8ff8a2a76ad2cb65685e9aa66610ea8",nonce="WaBf+lmgXs7b/dv//2dKD0QWtSVDqTi8",cnonce="A63C0685",qop=auth,algorithm=md5,nc=00000001
Content-Length: 0
TDC_CME_Router#
001569: Aug 25 13:31:00.635: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.anveo.com:5010 SIP/2.0
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB71D61
To: <sip:1103@sip.anveo.com>
Date: Fri, 25 Aug 2017 17:31:00 GMT
Call-ID: F1701A00-7BE611E7-800CC55F-D770BE34
Max-Forwards: 70
Timestamp: 1503682260
CSeq: 23812 REGISTER
Contact: <sip:1103@100.101.164.76:5060>
Expires: 180
Supported: path
Content-Length: 0
001570: Aug 25 13:31:00.719: //379743/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB71D61;rport=7438;received=174.227.13.124
To: <sip:1103@sip.anveo.com>;tag=9c1e0102a8b6ae5534bc36ba1ad58706.5456
WWW-Authenticate: Digest realm="anveo.com", nonce="WaBgAFmgXtTl720hOE2i8QLd5GB/wreb"
Content-Length: 0
001571: Aug 25 13:31:00.723: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB8C54
Max-Forwards: 70
CSeq: 23813 REGISTER
Expires: 180
Authorization: Digest username="5559487364",realm="anveo.com",uri="sip:sip.anveo.com:5010",response="9a965c40f7c60be18698ad6634ec0b73",nonce="WaBgAFmgXtTl720hOE2i8QLd5GB/wreb",algorithm=md5
Content-Length: 0
TDC_CME_Router#
001572: Aug 25 13:31:00.791: //379743/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden auth ID
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB8C54;rport=7438;received=174.227.13.124
To: <sip:1103@sip.anveo.com>;tag=9c1e0102a8b6ae5534bc36ba1ad58706.721f
Content-Length: 0
TDC_CME_Router#
001573: Aug 25 2017 13:31:07.999: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId F8193BE088F111E7815FC55FD770BE34, SetupTime 13:30:48.909 DST Fri Aug 25 2017, PeerAddress 1999, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 13:30:57.029 DST Fri Aug 25 2017, DisconnectTime 13:31:07.989 DST Fri Aug 25 2017, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 529, ReceiveBytes 84640
001574: Aug 25 2017 13:31:07.999: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/25/2017 13:30:48.906,cgn:1999,cdn:,frs:0,fid:696,fcid:F8193BE088F111E7815FC55FD770BE34,legID:5CB5D,bguid:F8193BE088F111E7815FC55FD770BE34
001575: Aug 25 13:31:07.999: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:127.0.0.8:5060;anveohash=enc-aKu.c68JXth-cHWQdHavhta-C6lfXHhJC6UJc6lQXHl* SIP/2.0
Via: SIP/2.0/UDP 100.101.164.76:5060;branch=z9hG4bKA1EB9220E
Max-Forwards: 70
Timestamp: 1503682267
CSeq: 103 BYE
Proxy-Authorization: Digest username="5559487364",realm="anveo.com",uri="sip:127.0.0.8:5060;anveohash=enc-aKu.c68JXth-cHWQdHavhta-C6lfXHhJC6UJc6lQXHl*",response="6ee551b7e0351b5b3bf547e41255dc68",nonce="WaBf+lmgXs7b/dv//2dKD0QWtSVDqTi8",cnonce="30099E93",qop=auth,algorithm=md5,nc=00000002
Reason: Q.850;cause=16
P-RTP-Stat: PS=529,OS=84640,PR=526,OR=84160,PL=0,JI=0,LA=0,DU=10
Content-Length: 0
001576: Aug 25 13:31:08.071: //379742/F8193BE0815F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 100.101.164.76:5060;rport=7438;received=174.227.13.124;branch=z9hG4bKA1EB9220E
CSeq: 103 BYE
Supported: replaces
Content-Length: 0
001577: Aug 25 2017 13:31:08.071: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId F8193BE088F111E7815FC55FD770BE34, SetupTime 13:30:54.731 DST Fri Aug 25 2017, PeerAddress 15552901577, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 13:30:57.021 DST Fri Aug 25 2017, DisconnectTime 13:31:08.071 DST Fri Aug 25 2017, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 529, TransmitBytes 84640, ReceivePackets 530, ReceiveBytes 84800
TDC_CME_Router#
001578: Aug 25 2017 13:31:08.071: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:08/25/2017 13:30:54.707,cgn:15557779999,cdn:15552901577,frs:0,fid:697,fcid:F8193BE088F111E7815FC55FD770BE34,legID:5CB5E,bguid:F8193BE088F111E7815FC55FD770BE34
Vaijanath Sonvane
Hi Michael,
Please try this configuration on your router:
voice translation-rule 2
 rule 1 /1000/ /15552220000/
 rule 2 /1538/ /15553334444/
 rule 3 /1999/ /15557779999/
voice translation-profile PSTN-OUT
 translate calling 2
 translation-profile outgoing PSTN-OUT
Vaijanath Sonvane
(Please rate if this is helpful.)
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
