CME 8 gui error
i'm using cme8.0 with flash:c2800nm-spservicesk9-mz.150-1.XA.bin
i got the ITSmain error after being authenticated and the gui don't load.
here are my flash files
VOICEGTWCOQITAP01#show flash:
CompactFlash directory:
File Length Name/status
1 54319600 c2800nm-spservicesk9-mz.150-1.XA.bin
2 829440 admin_user.html
3 677820 admin_user.js
5 617 CME_GUI_README.TXT
7 16344 dom.js
9 6146 ephone_admin.html
11 3866 normal_user.html
12 78428 normal_user.js
16 2432 telephony_service.html
18 9968 xml-test.html
19 3412 xml.template
[55959948 bytes used, 72490608 available, 128450556 total]
125440K bytes of ATA CompactFlash (Read/Write)
8 Replies 8
Brandon Svec
Level 7
Level 7
I have the same trouble here after upgrading to 15 and CME 8 gui files. Who wants to call TAC about it?
-- please remember to rate and mark answered helpful posts --
Try this before calling TAC:
ip http server path flash:/gui
instead of:
ip http path flash:gui
MK
but "ip http path flash:gui" is not in his config (or mine) all files are in the root of flash:
one thing I just noticed of possible interest is that if I log in as a user the user gui seems to be fine. It is just the admin gui that is broken. I ran debug ip http and the only thing I can tell is that some logos are not being found. There must be a broken file in there somewhere but the http debugs don't give me enough clue to even know what file to try to fix. The ITSMain error itself might be the best clue.
These are the errors i am receiving using IE 8:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; .NET CLR 1.1.4322; InfoPath.2; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Mon, 16 Nov 2009 21:10:01 UTC
Message: Expected ';'
Line: 3477
Char: 64
Code: 0
URI: https://10.15.9.199/ITSMain
Message: 's' is undefined
Line: 19087
Char: 1
Code: 0
Message: 'maxC' is undefined
Line: 19240
Char: 11
Code: 0
Message: Invalid character
Line: 19398
Char: 7
Code: 0
Line: 19398
Char: 7
Code: 0
Line: 19398
Char: 7
Code: 0
Line: 19398
Char: 16
Code: 0
Line: 19398
Char: 14
Code: 0
Line: 19399
Char: 7
Code: 0
Line: 19399
Char: 7
Code: 0
Line: 19399
Char: 7
Code: 0
Line: 19399
Char: 16
Code: 0
Line: 19399
Char: 14
Code: 0
Line: 19400
Char: 7
Code: 0
Line: 19400
Char: 7
Code: 0
Line: 19400
Char: 7
Code: 0
Line: 19400
Char: 16
Code: 0
Line: 19400
Char: 14
Code: 0
Message: Object expected
Line: 19068
Char: 1
Code: 0
I just looked at the error console in *Firefox* and see the file that is throwing errors seems to be admin_user.js. Anyone here good with javascript that might be able to debug? I attached the CME 8.0 admin_user.js file.
avdberg
Downloaded the updated cme 8.0 from cisco and then it worked.
ustinov.max
Yes, the GUI is broken in the JavaScript code. You need to download and install another CME v8.0.0.0 GUI package that works. It is located in CCO, inside "cme-151-1Tv2.zip" archive. The working GUI package "cme-gui-8.0.0.0.tar" is dated 10/15/2009. It properly works with "c2800nm-advipservicesk9-mz.151-2.T1.bin" IOS image and CUE 7.2.2.
Please mark this post as the solution if this helps.
Max
