Cme 9.0 3rd party Sip phones consult transfer
egiovannetti
Hi all
I knew that since voice register dn is single line, is not allowed to make a full consult transfer call on Call manager express (9.0),
but is there any work around to permit it?
in fact is a heavy constrain if it wouldn't be possible at all.
Any help is appreciated.
thank you
Emanuele
alig.norbert
Level 4
Level 4
I got a lab with cme 8.8, SCCP phones
and spa525g2 as 3party SIP.
On the SPA I can do a consult transfer to/from PSTN/SCCP/SIP.
It depens on the 3party SIP phone setup (on the phone).
I'm going the check the functionality/integration from Snom320 as well.
Norbert
I have an install with ccme 8.6 and sip snom m9 phones. The transfer option you get when on a call works as a consultive transfer no matter what the transfer system is set to under telephony-service.  But if I transfer to a number that does not exist than I get a hung call on the system that can't be cleared.
Here are a few:
rtrCONG-GRB01#sho call active voice compact
  A/O FAX T Codec       type        Peer Address       IP R:
Total call-legs: 4
      9020 ANS     T6056  g711ulaw    VOIP        P140       10.112.3.2:51920
      9257 ANS     T1193  g711ulaw    VOIP        P140       10.112.3.2:53504
      9295 ORG     T540   g711ulaw    VOIP        P140       10.112.3.2:53672
      9303 ORG     T388   g711ulaw    VOIP        P140       10.112.3.2:52392
CSCO10659222
The  setting for  full  consult  or  blind  transfer  is found on the  call  feature  administrative  page  for the third party  SIP  phone.
