rchaussee
Beginner
[CME 9.0] Call-Forward all / busy / no answer doesn't working
Hi guys,
I'm trying to fix my problem since to more time and I need help now.
On Cisco Call Manager Express 9.0:
My customer can manually transfert call to external number without problem (internal to external and external to external).
But when he configure call-forwarding all / busy /noan , the call is disconnected when the original call come from external. It works fine when the orignial call come from internal.
This is the Q931 debug :
I tested to call my customer 0251892248 which have a CFAll to his mobile phone 0610885655.
My number is 0299066161.
Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98383
                Exclusive, Channel 3
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2180, '02025189339666161'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '0610885655'
Nov  5 14:58:49.160: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB696
Nov  5 14:58:52.204: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x0B8E
        Cause i = 0x8A90 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Nov  5 14:58:52.208: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x482F
Nov  5 14:58:52.228: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x8B8E
Nov  5 14:58:52.552: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0B8E
Nov  5 14:58:55.940: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xB696
        Cause i = 0x8A81 - Unallocated/unassigned number
Nov  5 14:58:55.940: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xB631
Nov  5 14:58:55.944: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8B97
        Cause i = 0x8081 - Unallocated/unassigned number
Nov  5 14:58:56.384: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0B97
        Cause i = 0x82E3 - Information element not implemented
Nov  5 14:58:56.384: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8B97
Nov  5 14:58:56.392: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x3696
Nov  5 14:58:56.768: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xB696
Can you help me please ?
Ronan
RETIS
12 REPLIES 12
Jagpreet Singh
Hi Ronana,
     The debug which you attached is not complete. Please collect the debugs for the following scenarios:
> The failing call.
> Call Forward when call is made from an internal extension.
> An external call transfered to an external number.
The debug is "debug isdn q931"
Jagpreet
Hi Jagpreet,
This is the Q931 debug for the first test "failing call" :
External Number : 0299066161
Call to 251892248 whith Call forward no answer to mobile phone : 0610885655
debug isdn q931 is              ON.
STEF-GW#
Nov  6 08:07:46.538: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0C57
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
        Calling Party Number i = 0x2180, '299066161'
        Calling Party Number i = 0x2183, '299066161'
        Called Party Number i = 0xA1, '251892248'
Nov  6 08:07:46.538: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8C57 callID = 0x48F8 switch = primary-net5 interface = User
Nov  6 08:07:46.558: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8C57
Nov  6 08:07:46.558: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8C57
        Progress Ind i = 0x8188 - In-band info or appropriate now available
  Nov  6 08:08:11.566: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 02025189339666161
Nov  6 08:08:11.566: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x3765 callID = 0xB700 switch = primary-net5 interface = User
Nov  6 08:08:11.566: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3765
        Sending Complete
                Standard = CCITT
Nov  6 08:08:12.122: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xB765
Nov  6 08:08:17.310: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x3763
        Cause i = 0x8090 - Normal call clearing
Nov  6 08:08:17.994: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0xB763
Nov  6 08:08:17.994: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x3763
Nov  6 08:08:18.858: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xB765
        Cause i = 0x8A9C - Invalid number format (incomplete number)
Nov  6 08:08:18.858: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xB700
Nov  6 08:08:18.862: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8C57
        Cause i = 0x809C - Invalid number format (incomplete number)
Nov  6 08:08:19.278: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x0C57
Nov  6 08:08:19.278: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8C57
Nov  6 08:08:19.282: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x3765
Nov  6 08:08:19.470: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xB765
Nov  6 08:08:23.502: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x8C59
I can't to do the next test do you need because nobody on site actually...
Ronan
Hi Ronana,
          Thank you for that debug. A debug for a transfer would have been helpful in comparing. However, from this debug I could see that:
> The calling number in the outbound call is : 02025189339666161. Can you confirm if that is correct ? Or do we have some sort of translations or number expansions configured.
> The called Number is : 0610885655; which the service provider is unable to find:
        Cause i = 0x8A9C - Invalid number format (incomplete number) Nov  6 08:08:18.858: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xB765
> Can we collect a debug for a direct call to that mobile phone number from a phone registered on the CME?
If possible, please include the "show run" from the router. We might need to involve your service provider on this one.
Jagpreet
No the calling number is 0299066161 which try to join 0251892248 but this phone has a CFA throught 0610885655.
It really strange because the CME do a translation about the number 0299066161 with the number 02025189339666161 when it try to forward the call...but there isn't any translation like this in my configuration.
I send you the information when I can.
Regards.
Ronan
Hi Guys,
Sorry for the delay but I was on other issue
I managed to translate with a good calling number (modify translation pattern) but the problem persist and I don't know what is the problem.
This is the 2 traces (Call-Forward No Answer to Mobile phone) and manuel transfert to mobile phone :
Manuel transfert from phone 980 (translation to 251892248) to mobile phone 0610885655 : OK
Nov 19 13:26:42.066: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 0251892248
Nov 19 13:26:42.070: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x4AB2 callID = 0xCA50 switch = primary-net5 interface = User
Nov 19 13:26:42.070: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x4AB2
                Standard = CCITT
        Channel ID i = 0xA98381
        Calling Party Number i = 0x2180, '0251892248'
        Called Party Number i = 0x81, '0610885655'
                Plan:ISDN, Type:Unknown
Nov 19 13:26:42.374: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xCAB2
Nov 19 13:26:42.458: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xCAB2
Nov 19 13:26:47.910: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0xA543
Nov 19 13:26:48.118: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xCAB2
Nov 19 13:26:48.230: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x2543
Nov 19 13:26:48.230: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xA543
Nov 19 13:26:51.510: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0xCAB2
        Date/Time i = 0x0D0B130E1A00
                Date (dd-mm-yr)   = 13-11-19
                Time (hr:mnt:sec) = 14:26:00
Nov 19 13:26:51.510: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x4AB2no de
Nov 19 13:26:57.462: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x2545
        Cause i = 0x8A9F - Normal, unspecified
Now, the trace when the CME do Call-Forward from my calling number 0299066161 to Mobile configured in CFNA 0610885655 : KO
Nov  7 16:16:51.475: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 0299066161
Nov  7 16:16:51.475: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x3B83 callID = 0xBB1E switch = primary-net5 interface = User
Nov  7 16:16:51.479: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3B83
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA98384
                Exclusive, Channel 4
        Calling Party Number i = 0x2180, '0299066161'
Nov  7 16:16:52.071: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xBB83
Nov  7 16:16:59.007: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xBB83
Nov  7 16:16:59.007: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xBB1E
Please help me !!!!!
Ronan
share a running-config please
The sh run :
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.153-2.T.bin
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
clock timezone FR 1 0
clock summer-time FR recurring last Sun Mar 2:00 last Sun Oct 3:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
ip dhcp excluded-address 10.X.240.1 10.X.240.30
ip dhcp pool ToIP
network 10.X.240.0 255.255.254.0
option 150 ip 10.X.240.5
default-router 10.X.240.1
lease 8
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
voice rtp send-recv
voice service voip
gcid
rtp-ssrc multiplex
media flow-around
media transcoder sync-streams
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 600 min 60
voice register global
mode cme
source-address 10.x.240.5 port 5060
max-dn 10
max-pool 10
load 6941 SIP69xx.9-3-3-2.loads
authenticate register
authenticate realm ccmsipline
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0000504380044943
voice register dn  1
number 962
allow watch
name Technique
voice register dn  2
number 900
name Responsable quai
voice register dn  3
number 940
name Surgele
voice register dn  4
number 941
allow watch
name Reception
voice register dn  5
number 942
name Zone A
voice register dn  6
number 943
name Zone B
voice register dn  7
number 944
name Micro Distri
voice register dn  8
number 921
name PRESTA-1
voice register dn  9
number 999
name Test
voice register pool  1
id mac B8AC.6FCB.A14F
number 1 dn 1
username 962 password 962
codec g711ulaw
voice register pool  2
busy-trigger-per-button 2
id device-id-name 900
number 1 dn 2
username 900 password 900
codec g711ulaw
voice register pool  3
id mac AAAA.AAAA.AAAA
number 1 dn 3
username 940 password 940
codec g711ulaw
voice register pool  4
id mac AAAA.AAAA.AAAB
number 1 dn 4
username 941 password 941
codec g711ulaw
voice register pool  5
id mac AAAA.AAAA.AAAC
number 1 dn 5
username 942 password 942
codec g711ulaw
voice register pool  6
id mac AAAA.AAAA.AAAD
number 1 dn 6
username 943 password 943
codec g711ulaw
voice register pool  7
id mac AAAA.AAAA.AAAF
number 1 dn 7
username 944 password 944
codec g711ulaw
voice register pool  8
id mac AAAA.AAAA.BAAA
number 1 dn 8
username 921 password 921
codec g711ulaw
voice register pool  9
busy-trigger-per-button 3
id mac 20BB.C01E.CBE5
type 6941
number 1 dn 9
codec g711ulaw
voice hunt-group 1 parallel
final 500
list 510,511,512,513
timeout 25
pilot *101
description #HuntGroup Rv Service Client#
voice hunt-group 2 parallel
final 610
list 611,612,613,614
timeout 25
pilot *102
description #HuntGroup Rv Expeditions#
voice hunt-group 3 parallel
final 600
list 622,622
timeout 25
pilot *103
description #HuntGroup Rv Distri-Ramasse-DN619#
voice hunt-group 4 parallel
final 700
list 710,720,730
timeout 25
pilot *104
description #HuntGroup Rv Saisie#
voice hunt-group 5 parallel
final 500
list 520,521,522,523
timeout 25
pilot *105
description #HuntGroup Rv Emballage#
voice hunt-group 6 parallel
final 900
list 940,941,942,943,944
timeout 25
pilot *106
description #HuntGroup Rv Quai#
voice hunt-group 7 parallel
final 900
list 820,921,922
timeout 25
pilot *107
description #HuntGroup Rv Prestation#
voice hunt-group 8 parallel
list 960,961,962
timeout 25
pilot *108
description #HuntGroup Rv Technique#
voice hunt-group 9 parallel
final 111
list 120,500,600,610,620,700,900
timeout 25
pilot *109
description #HuntGroup Rv Responsables Service#
voice hunt-group 10 parallel
final 610
list 617,618
timeout 25
pilot *110
description #HuntGroup Rv Lot#
voice hunt-group 12 parallel
final 111
list 120,500,600,620
timeout 25
pilot *112
description #HuntGroup Rv Commerce#
voice hunt-group 13 parallel
final 111
list 310,320
timeout 25
pilot *113
description #HuntGroup Rv RH#
voice hunt-group 14 parallel
final 111
list 412,421
timeout 25
pilot *114
description #HuntGroup Rv CGO-Facturation#
voice hunt-group 15 parallel
list 611,621,624,710
timeout 25
pilot *115
description #HuntGroup Rv Standard#
voice hunt-group 16 parallel
final 600
list 622,619
timeout 25
pilot *116
description #HuntGroup Rv Distri-RamasseDN621#
voice hunt-group 17 parallel
final 600
list 619,619
timeout 25
pilot *117
description #HuntGroup Rv Distri-RamasseDN622#
voice translation-rule 1
rule 1 /^251xxxx10/ /100/
rule 2 /^251xxxx12/ /600/
rule 3 /^251xxxx13/ /700/
rule 4 /^251xxxx14/ /614/
rule 5 /^251xxxx15/ /611/
rule 6 /^251xxxx16/ /623/
rule 7 /^251xxxx17/ /621/
rule 8 /^251xxxx19/ /625/
rule 9 /^251xxxx18/ /512/
rule 10 /^251xxxx20/ /511/
rule 11 /^251xxxx21/ /300/
rule 12 /^251xxxx22/ /111/
rule 13 /^251xxxx23/ /520/
rule 14 /^251xxxx26/ /412/
rule 15 /^251xxxx27/ /310/
rule 16 /^251xxxx28/ /411/
rule 17 /^251xxxx29/ /960/
rule 18 /^251xxxx30/ /120/
rule 19 /^251xxxx34/ /922/
rule 20 /^251xxxx35/ /618/
rule 21 /^251xxxx36/ /200/
rule 22 /^251xxxx40/ /920/
rule 23 /^251xxxx41/ /220/
rule 24 /^251xxxx42/ /110/
rule 25 /^251xxxx45/ /420/
rule 26 /^251xxxx46/ /522/
rule 27 /^251xxxx47/ /421/
rule 28 /^251xxxx48/ /980/
rule 29 /^251xxxx49/ /620/
rule 30 /^251xxxx94/ /210/
rule 31 /^251xxxx95/ /991/
rule 32 /^251xxxx96/ /990/
rule 33 /^251xxxx98/ /410/
rule 34 /^251xxxx62/ /500/
rule 35 /^251xxxx65/ /510/
rule 36 /^251xxxx66/ /610/
rule 37 /^251xxxx67/ /616/
rule 38 /^251xxxx68/ /615/
rule 39 /^251xxxx24/ /1313/
rule 40 /^251xxxx25/ /1314/
rule 41 /^251xxxx43/ /970/
voice translation-rule 10
rule 1 /^100$/ /0251xxxx10/ type any national plan any isdn
rule 2 /^600$/ /0251xxxx12/ type any national plan any isdn
rule 3 /^700$/ /0251xxxx13/ type any national plan any isdn
rule 4 /^614$/ /0251xxxx14/ type any national plan any isdn
rule 5 /^611$/ /0251xxxx15/ type any national plan any isdn
rule 6 /^623$/ /0251xxxx16/ type any national plan any isdn
rule 7 /^621$/ /0251xxxx17/ type any national plan any isdn
rule 8 /^625$/ /0251xxxx19/ type any national plan any isdn
rule 9 /^512$/ /0251xxxx18/ type any national plan any isdn
rule 10 /^511$/ /0251xxxx20/ type any national plan any isdn
rule 11 /^300$/ /0251xxxx21/ type any national plan any isdn
rule 12 /^111$/ /0251xxxx22/ type any national plan any isdn
rule 13 /^520$/ /0251xxxx23/ type any national plan any isdn
rule 14 /^412$/ /0251xxxx26/ type any national plan any isdn
rule 15 /^310$/ /0251xxxx27/ type any national plan any isdn
rule 16 /^411$/ /0251xxxx28/ type any national plan any isdn
rule 17 /^960$/ /0251xxxx29/ type any national plan any isdn
rule 18 /^120$/ /0251xxxx30/ type any national plan any isdn
rule 19 /^922$/ /0251xxxx34/ type any national plan any isdn
rule 20 /^618$/ /0251xxxx35/ type any national plan any isdn
rule 21 /^200$/ /0251xxxx36/ type any national plan any isdn
rule 22 /^920$/ /0251xxxx40/ type any national plan any isdn
rule 23 /^220$/ /0251xxxx41/ type any national plan any isdn
rule 24 /^110$/ /0251xxxx42/ type any national plan any isdn
rule 25 /^420$/ /0251xxxx45/ type any national plan any isdn
rule 26 /^522$/ /0251xxxx46/ type any national plan any isdn
rule 27 /^421$/ /0251xxxx47/ type any national plan any isdn
rule 28 /^980$/ /0251xxxx48/ type any national plan any isdn
rule 29 /^620$/ /0251xxxx49/ type any national plan any isdn
rule 30 /^210$/ /0251xxxx94/ type any national plan any isdn
rule 31 /^991$/ /0251xxxx95/ type any national plan any isdn
rule 32 /^990$/ /0251xxxx96/ type any national plan any isdn
rule 33 /^410$/ /0251xxxx98/ type any national plan any isdn
rule 34 /^500$/ /0251xxxx62/ type any national plan any isdn
rule 35 /^510$/ /0251xxxx65/ type any national plan any isdn
rule 36 /^610$/ /0251xxxx66/ type any national plan any isdn
rule 37 /^616$/ /0251xxxx67/ type any national plan any isdn
rule 38 /^615$/ /0251xxxx68/ type any national plan any isdn
rule 39 /^1313$/ /0251xxxx24/ type any national plan any isdn
rule 40 /^1314$/ /0251xxxx25/ type any national plan any isdn
rule 41 /^970$/ /0251xxxx43/ type any national plan any isdn
voice translation-rule 20
rule 1 /^/ /0/
voice translation-profile ANI-IN
translate calling 20
translate called 1
voice translation-profile ANI-OUT
translate calling 10
application
service cmeaa flash:its-CISCO.2.0.2.0.tcl
  param aa-pilot 1000
service predecroche flash:Predec1.5.12.tcl
  param predec flash:predec.wav
license udi pid CISCO2921/K9 sn FCZ171860MS
license accept end user agreement
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
archive
log config
  hidekeys
path tftp://10.252.240.34/
write-memory
username 841 password 0 841
username 842 password 0 842
username 843 password 0 843
username 844 password 0 844
username 821 password 0 821
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-16
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.X.240.5 255.255.254.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
ip default-gateway 10.x.240.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.x.240.1
control-plane
voice-port 0/0/0:15
cptone FR
timeouts interdigit 5
bearer-cap Speech
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
voice-port 1/0/8
voice-port 1/0/9
voice-port 1/0/10
voice-port 1/0/11
voice-port 1/0/12
voice-port 1/0/13
voice-port 1/0/14
voice-port 1/0/15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dspfarm profile 2 transcode
associate application SCCP
shutdown
dspfarm profile 1 conference
shutdown
dial-peer voice 1 pots
description ***APPELS Entrants***
translation-profile incoming ANI-IN
incoming called-number .
direct-inward-dial
dial-peer voice 2 pots
description *** APPELS SORTANTS vers T2 local - 0/0/0 ***
translation-profile outgoing ANI-OUT
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0:15
forward-digits all
dial-peer voice 3 pots
description *** APPELS SORTANTS URGENCE vers T2 local - 0/0/0 ***
destination-pattern 1T
port 0/0/0:15
forward-digits all
dial-peer voice 4 pots
description *** APPELS SORTANTS NATIONNAUX vers T2 local - 0/0/0 ***
shutdown
destination-pattern 0[1-9]........
port 0/0/0:15
forward-digits all
dial-peer voice 5 pots
destination-pattern 11.
port 0/0/0:15
forward-digits all
presence
presence call-list
max-subscription 400
sip-ua
presence enable
gatekeeper
shutdown
telephony-service
protocol mode ipv4
conference hardware
max-ephones 80
max-dn 400
ip source-address 10.x.240.5 port 2000
service dnis overlay
service dnis dir-lookup
cnf-file location flash:
user-locale FR
network-locale FR
load 7962 SCCP42.9-2-1S.loads
load 6941 SCCP69xx.9-3-3-2-SR1.loads
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
moh "moh.wav"
multicast moh 239.10.16.4 port 16384
web admin system name admin password retis
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
call-forward pattern .T
after-hours block pattern 1 00336........ 7-24
after-hours block pattern 2 00337........ 7-24
night-service everyday 17:31 08:59
directory last-name-first
ephone-template  17
softkeys idle  Newcall Redial Cfwdall Gpickup Dnd
ephone-template  18
softkeys idle  Newcall Redial Cfwdall Pickup
ephone-template  19
softkeys idle  Newcall Pickup Gpickup
ephone-template  20
softkeys ringing  Answer Dnd HLog
ephone-dn  55  dual-line
number 980
pickup-group 1
description 980
allow watch
call-forward busy 06XX885655
call-forward noan 06XX885655 timeout 25
ephone  55
mac-address 20BB.C01F.02B6
ephone-template 19
max-calls-per-button 3
busy-trigger-per-button 1
presence call-list
type 6941
button  1:55
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
RONAN,
try to add sip supplementary-service under voice service voip and try again.
But SIP profile are only for DECT and one test phone.
All phones are registered in SCCP so I don't think it is a good idea to add "sip supplementary-service"....
I this is the issue of Plan:ISDN type
coz for original calls its showing as type: National for calling and unknown as called number and while in forwarding it is showing as National for both.
try setting "numbering-type any unknown" in DP or voice-port or in translation rule of ANI
amansin74
Beginner
Hi Ronan,
Can you try the workaround given in the following link ?
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a0080816cac.shtml
“If you have knowledge, let others light their candles in it.”
I tried to put "numbering-type unknown" in the outgoing dial-peer but without success...
I checked the workaround before but i don't understand anything about the explain and workaround. I have to do a translation rule but I don't know what translation I have to do ??
Can you explain me more about the workaround please ?
I'm sorry but I start in the voice world
Thanks a lot
Ronan
Content for Community-Ad
Spotlight Awards 2021
