11-05-2013 08:50 AM - edited 03-16-2019 08:14 PM
Hi guys,
I'm trying to fix my problem since to more time and I need help now.
On Cisco Call Manager Express 9.0:
My customer can manually transfert call to external number without problem (internal to external and external to external).
But when he configure call-forwarding all / busy /noan , the call is disconnected when the original call come from external. It works fine when the orignial call come from internal.
This is the Q931 debug :
I tested to call my customer 0251892248 which have a CFAll to his mobile phone 0610885655.
My number is 0299066161.
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98383
Exclusive, Channel 3
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '02025189339666161'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '0610885655'
Nov 5 14:58:49.160: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xB696
Nov 5 14:58:52.204: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0B8E
Cause i = 0x8A90 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
Nov 5 14:58:52.208: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x482F
Nov 5 14:58:52.228: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8B8E
Nov 5 14:58:52.552: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0B8E
Nov 5 14:58:55.940: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xB696
Cause i = 0x8A81 - Unallocated/unassigned number
Nov 5 14:58:55.940: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xB631
Nov 5 14:58:55.944: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8B97
Cause i = 0x8081 - Unallocated/unassigned number
Nov 5 14:58:56.384: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0B97
Cause i = 0x82E3 - Information element not implemented
Nov 5 14:58:56.384: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8B97
Nov 5 14:58:56.392: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x3696
Nov 5 14:58:56.768: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xB696
Can you help me please ?
Ronan
RETIS
11-05-2013 01:05 PM
Hi Ronana,
The debug which you attached is not complete. Please collect the debugs for the following scenarios:
> The failing call.
> Call Forward when call is made from an internal extension.
> An external call transfered to an external number.
The debug is "debug isdn q931"
Jagpreet
11-06-2013 12:22 AM
Hi Jagpreet,
This is the Q931 debug for the first test "failing call" :
External Number : 0299066161
Call to 251892248 whith Call forward no answer to mobile phone : 0610885655
debug isdn q931 is ON.
STEF-GW#
Nov 6 08:07:46.538: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0C57
Sending Complete
Standard = CCITT
Channel ID i = 0xA9838A
Exclusive, Channel 10
Calling Party Number i = 0x2180, '299066161'
Calling Party Number i = 0x2183, '299066161'
Called Party Number i = 0xA1, '251892248'
Nov 6 08:07:46.538: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x8C57 callID = 0x48F8 switch = primary-net5 interface = User
Nov 6 08:07:46.558: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8C57
Nov 6 08:07:46.558: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8C57
Progress Ind i = 0x8188 - In-band info or appropriate now available
Nov 6 08:08:11.566: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 02025189339666161
Nov 6 08:08:11.566: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x3765 callID = 0xB700 switch = primary-net5 interface = User
Nov 6 08:08:11.566: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x3765
Sending Complete
Standard = CCITT
Nov 6 08:08:12.122: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xB765
Nov 6 08:08:17.310: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x3763
Cause i = 0x8090 - Normal call clearing
Nov 6 08:08:17.994: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xB763
Nov 6 08:08:17.994: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x3763
Nov 6 08:08:18.858: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xB765
Cause i = 0x8A9C - Invalid number format (incomplete number)
Nov 6 08:08:18.858: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xB700
Nov 6 08:08:18.862: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8C57
Cause i = 0x809C - Invalid number format (incomplete number)
Nov 6 08:08:19.278: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0C57
Nov 6 08:08:19.278: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8C57
Nov 6 08:08:19.282: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x3765
Nov 6 08:08:19.470: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xB765
Nov 6 08:08:23.502: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8C59
I can't to do the next test do you need because nobody on site actually...
Ronan
11-06-2013 06:47 AM
Hi Ronana,
Thank you for that debug. A debug for a transfer would have been helpful in comparing. However, from this debug I could see that:
> The calling number in the outbound call is : 02025189339666161. Can you confirm if that is correct ? Or do we have some sort of translations or number expansions configured.
> The called Number is : 0610885655; which the service provider is unable to find:
Cause i = 0x8A9C - Invalid number format (incomplete number) Nov 6 08:08:18.858: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xB765
> Can we collect a debug for a direct call to that mobile phone number from a phone registered on the CME?
If possible, please include the "show run" from the router. We might need to involve your service provider on this one.
Jagpreet
11-06-2013 07:01 AM
No the calling number is 0299066161 which try to join 0251892248 but this phone has a CFA throught 0610885655.
It really strange because the CME do a translation about the number 0299066161 with the number 02025189339666161 when it try to forward the call...but there isn't any translation like this in my configuration.
I send you the information when I can.
Regards.
Ronan
11-20-2013 02:22 AM
Hi Guys,
Sorry for the delay but I was on other issue
I managed to translate with a good calling number (modify translation pattern) but the problem persist and I don't know what is the problem.
This is the 2 traces (Call-Forward No Answer to Mobile phone) and manuel transfert to mobile phone :
Manuel transfert from phone 980 (translation to 251892248) to mobile phone 0610885655 : OK
Nov 19 13:26:42.066: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 0251892248
Nov 19 13:26:42.070: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x4AB2 callID = 0xCA50 switch = primary-net5 interface = User
Nov 19 13:26:42.070: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x4AB2
Standard = CCITT
Channel ID i = 0xA98381
Calling Party Number i = 0x2180, '0251892248'
Called Party Number i = 0x81, '0610885655'
Plan:ISDN, Type:Unknown
Nov 19 13:26:42.374: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xCAB2
Nov 19 13:26:42.458: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xCAB2
Nov 19 13:26:47.910: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xA543
Nov 19 13:26:48.118: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xCAB2
Nov 19 13:26:48.230: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x2543
Nov 19 13:26:48.230: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA543
Nov 19 13:26:51.510: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0xCAB2
Date/Time i = 0x0D0B130E1A00
Date (dd-mm-yr) = 13-11-19
Time (hr:mnt:sec) = 14:26:00
Nov 19 13:26:51.510: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x4AB2no de
Nov 19 13:26:57.462: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x2545
Cause i = 0x8A9F - Normal, unspecified
Now, the trace when the CME do Call-Forward from my calling number 0299066161 to Mobile configured in CFNA 0610885655 : KO
Nov 7 16:16:51.475: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 0299066161
Nov 7 16:16:51.475: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x3B83 callID = 0xBB1E switch = primary-net5 interface = User
Nov 7 16:16:51.479: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x3B83
Sending Complete
Standard = CCITT
Channel ID i = 0xA98384
Exclusive, Channel 4
Calling Party Number i = 0x2180, '0299066161'
Nov 7 16:16:52.071: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xBB83
Nov 7 16:16:59.007: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xBB83
Nov 7 16:16:59.007: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xBB1E
Please help me !!!!!
Ronan
11-20-2013 02:39 AM
share a running-config please
11-20-2013 02:55 AM
The sh run :
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.153-2.T.bin
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
clock timezone FR 1 0
clock summer-time FR recurring last Sun Mar 2:00 last Sun Oct 3:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
ip dhcp excluded-address 10.X.240.1 10.X.240.30
ip dhcp pool ToIP
network 10.X.240.0 255.255.254.0
option 150 ip 10.X.240.5
default-router 10.X.240.1
lease 8
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
voice rtp send-recv
voice service voip
gcid
rtp-ssrc multiplex
media flow-around
media transcoder sync-streams
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server expires max 600 min 60
voice register global
mode cme
source-address 10.x.240.5 port 5060
max-dn 10
max-pool 10
load 6941 SIP69xx.9-3-3-2.loads
authenticate register
authenticate realm ccmsipline
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0000504380044943
voice register dn 1
number 962
allow watch
name Technique
voice register dn 2
number 900
name Responsable quai
voice register dn 3
number 940
name Surgele
voice register dn 4
number 941
allow watch
name Reception
voice register dn 5
number 942
name Zone A
voice register dn 6
number 943
name Zone B
voice register dn 7
number 944
name Micro Distri
voice register dn 8
number 921
name PRESTA-1
voice register dn 9
number 999
name Test
voice register pool 1
id mac B8AC.6FCB.A14F
number 1 dn 1
username 962 password 962
codec g711ulaw
voice register pool 2
busy-trigger-per-button 2
id device-id-name 900
number 1 dn 2
username 900 password 900
codec g711ulaw
voice register pool 3
id mac AAAA.AAAA.AAAA
number 1 dn 3
username 940 password 940
codec g711ulaw
voice register pool 4
id mac AAAA.AAAA.AAAB
number 1 dn 4
username 941 password 941
codec g711ulaw
voice register pool 5
id mac AAAA.AAAA.AAAC
number 1 dn 5
username 942 password 942
codec g711ulaw
voice register pool 6
id mac AAAA.AAAA.AAAD
number 1 dn 6
username 943 password 943
codec g711ulaw
voice register pool 7
id mac AAAA.AAAA.AAAF
number 1 dn 7
username 944 password 944
codec g711ulaw
voice register pool 8
id mac AAAA.AAAA.BAAA
number 1 dn 8
username 921 password 921
codec g711ulaw
voice register pool 9
busy-trigger-per-button 3
id mac 20BB.C01E.CBE5
type 6941
number 1 dn 9
codec g711ulaw
voice hunt-group 1 parallel
final 500
list 510,511,512,513
timeout 25
pilot *101
description #HuntGroup Rv Service Client#
voice hunt-group 2 parallel
final 610
list 611,612,613,614
timeout 25
pilot *102
description #HuntGroup Rv Expeditions#
voice hunt-group 3 parallel
final 600
list 622,622
timeout 25
pilot *103
description #HuntGroup Rv Distri-Ramasse-DN619#
voice hunt-group 4 parallel
final 700
list 710,720,730
timeout 25
pilot *104
description #HuntGroup Rv Saisie#
voice hunt-group 5 parallel
final 500
list 520,521,522,523
timeout 25
pilot *105
description #HuntGroup Rv Emballage#
voice hunt-group 6 parallel
final 900
list 940,941,942,943,944
timeout 25
pilot *106
description #HuntGroup Rv Quai#
voice hunt-group 7 parallel
final 900
list 820,921,922
timeout 25
pilot *107
description #HuntGroup Rv Prestation#
voice hunt-group 8 parallel
list 960,961,962
timeout 25
pilot *108
description #HuntGroup Rv Technique#
voice hunt-group 9 parallel
final 111
list 120,500,600,610,620,700,900
timeout 25
pilot *109
description #HuntGroup Rv Responsables Service#
voice hunt-group 10 parallel
final 610
list 617,618
timeout 25
pilot *110
description #HuntGroup Rv Lot#
voice hunt-group 12 parallel
final 111
list 120,500,600,620
timeout 25
pilot *112
description #HuntGroup Rv Commerce#
voice hunt-group 13 parallel
final 111
list 310,320
timeout 25
pilot *113
description #HuntGroup Rv RH#
voice hunt-group 14 parallel
final 111
list 412,421
timeout 25
pilot *114
description #HuntGroup Rv CGO-Facturation#
voice hunt-group 15 parallel
list 611,621,624,710
timeout 25
pilot *115
description #HuntGroup Rv Standard#
voice hunt-group 16 parallel
final 600
list 622,619
timeout 25
pilot *116
description #HuntGroup Rv Distri-RamasseDN621#
voice hunt-group 17 parallel
final 600
list 619,619
timeout 25
pilot *117
description #HuntGroup Rv Distri-RamasseDN622#
voice translation-rule 1
rule 1 /^251xxxx10/ /100/
rule 2 /^251xxxx12/ /600/
rule 3 /^251xxxx13/ /700/
rule 4 /^251xxxx14/ /614/
rule 5 /^251xxxx15/ /611/
rule 6 /^251xxxx16/ /623/
rule 7 /^251xxxx17/ /621/
rule 8 /^251xxxx19/ /625/
rule 9 /^251xxxx18/ /512/
rule 10 /^251xxxx20/ /511/
rule 11 /^251xxxx21/ /300/
rule 12 /^251xxxx22/ /111/
rule 13 /^251xxxx23/ /520/
rule 14 /^251xxxx26/ /412/
rule 15 /^251xxxx27/ /310/
rule 16 /^251xxxx28/ /411/
rule 17 /^251xxxx29/ /960/
rule 18 /^251xxxx30/ /120/
rule 19 /^251xxxx34/ /922/
rule 20 /^251xxxx35/ /618/
rule 21 /^251xxxx36/ /200/
rule 22 /^251xxxx40/ /920/
rule 23 /^251xxxx41/ /220/
rule 24 /^251xxxx42/ /110/
rule 25 /^251xxxx45/ /420/
rule 26 /^251xxxx46/ /522/
rule 27 /^251xxxx47/ /421/
rule 28 /^251xxxx48/ /980/
rule 29 /^251xxxx49/ /620/
rule 30 /^251xxxx94/ /210/
rule 31 /^251xxxx95/ /991/
rule 32 /^251xxxx96/ /990/
rule 33 /^251xxxx98/ /410/
rule 34 /^251xxxx62/ /500/
rule 35 /^251xxxx65/ /510/
rule 36 /^251xxxx66/ /610/
rule 37 /^251xxxx67/ /616/
rule 38 /^251xxxx68/ /615/
rule 39 /^251xxxx24/ /1313/
rule 40 /^251xxxx25/ /1314/
rule 41 /^251xxxx43/ /970/
voice translation-rule 10
rule 1 /^100$/ /0251xxxx10/ type any national plan any isdn
rule 2 /^600$/ /0251xxxx12/ type any national plan any isdn
rule 3 /^700$/ /0251xxxx13/ type any national plan any isdn
rule 4 /^614$/ /0251xxxx14/ type any national plan any isdn
rule 5 /^611$/ /0251xxxx15/ type any national plan any isdn
rule 6 /^623$/ /0251xxxx16/ type any national plan any isdn
rule 7 /^621$/ /0251xxxx17/ type any national plan any isdn
rule 8 /^625$/ /0251xxxx19/ type any national plan any isdn
rule 9 /^512$/ /0251xxxx18/ type any national plan any isdn
rule 10 /^511$/ /0251xxxx20/ type any national plan any isdn
rule 11 /^300$/ /0251xxxx21/ type any national plan any isdn
rule 12 /^111$/ /0251xxxx22/ type any national plan any isdn
rule 13 /^520$/ /0251xxxx23/ type any national plan any isdn
rule 14 /^412$/ /0251xxxx26/ type any national plan any isdn
rule 15 /^310$/ /0251xxxx27/ type any national plan any isdn
rule 16 /^411$/ /0251xxxx28/ type any national plan any isdn
rule 17 /^960$/ /0251xxxx29/ type any national plan any isdn
rule 18 /^120$/ /0251xxxx30/ type any national plan any isdn
rule 19 /^922$/ /0251xxxx34/ type any national plan any isdn
rule 20 /^618$/ /0251xxxx35/ type any national plan any isdn
rule 21 /^200$/ /0251xxxx36/ type any national plan any isdn
rule 22 /^920$/ /0251xxxx40/ type any national plan any isdn
rule 23 /^220$/ /0251xxxx41/ type any national plan any isdn
rule 24 /^110$/ /0251xxxx42/ type any national plan any isdn
rule 25 /^420$/ /0251xxxx45/ type any national plan any isdn
rule 26 /^522$/ /0251xxxx46/ type any national plan any isdn
rule 27 /^421$/ /0251xxxx47/ type any national plan any isdn
rule 28 /^980$/ /0251xxxx48/ type any national plan any isdn
rule 29 /^620$/ /0251xxxx49/ type any national plan any isdn
rule 30 /^210$/ /0251xxxx94/ type any national plan any isdn
rule 31 /^991$/ /0251xxxx95/ type any national plan any isdn
rule 32 /^990$/ /0251xxxx96/ type any national plan any isdn
rule 33 /^410$/ /0251xxxx98/ type any national plan any isdn
rule 34 /^500$/ /0251xxxx62/ type any national plan any isdn
rule 35 /^510$/ /0251xxxx65/ type any national plan any isdn
rule 36 /^610$/ /0251xxxx66/ type any national plan any isdn
rule 37 /^616$/ /0251xxxx67/ type any national plan any isdn
rule 38 /^615$/ /0251xxxx68/ type any national plan any isdn
rule 39 /^1313$/ /0251xxxx24/ type any national plan any isdn
rule 40 /^1314$/ /0251xxxx25/ type any national plan any isdn
rule 41 /^970$/ /0251xxxx43/ type any national plan any isdn
voice translation-rule 20
rule 1 /^/ /0/
voice translation-profile ANI-IN
translate calling 20
translate called 1
voice translation-profile ANI-OUT
translate calling 10
application
service cmeaa flash:its-CISCO.2.0.2.0.tcl
param aa-pilot 1000
service predecroche flash:Predec1.5.12.tcl
param predec flash:predec.wav
license udi pid CISCO2921/K9 sn FCZ171860MS
license accept end user agreement
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
archive
log config
hidekeys
path tftp://10.252.240.34/
write-memory
username 841 password 0 841
username 842 password 0 842
username 843 password 0 843
username 844 password 0 844
username 821 password 0 821
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-16
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.X.240.5 255.255.254.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
ip default-gateway 10.x.240.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.x.240.1
control-plane
voice-port 0/0/0:15
cptone FR
timeouts interdigit 5
bearer-cap Speech
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
voice-port 1/0/8
voice-port 1/0/9
voice-port 1/0/10
voice-port 1/0/11
voice-port 1/0/12
voice-port 1/0/13
voice-port 1/0/14
voice-port 1/0/15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dspfarm profile 2 transcode
associate application SCCP
shutdown
dspfarm profile 1 conference
shutdown
dial-peer voice 1 pots
description ***APPELS Entrants***
translation-profile incoming ANI-IN
incoming called-number .
direct-inward-dial
dial-peer voice 2 pots
description *** APPELS SORTANTS vers T2 local - 0/0/0 ***
translation-profile outgoing ANI-OUT
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0:15
forward-digits all
dial-peer voice 3 pots
description *** APPELS SORTANTS URGENCE vers T2 local - 0/0/0 ***
destination-pattern 1T
port 0/0/0:15
forward-digits all
dial-peer voice 4 pots
description *** APPELS SORTANTS NATIONNAUX vers T2 local - 0/0/0 ***
shutdown
destination-pattern 0[1-9]........
port 0/0/0:15
forward-digits all
dial-peer voice 5 pots
destination-pattern 11.
port 0/0/0:15
forward-digits all
presence
presence call-list
max-subscription 400
sip-ua
presence enable
gatekeeper
shutdown
telephony-service
protocol mode ipv4
conference hardware
max-ephones 80
max-dn 400
ip source-address 10.x.240.5 port 2000
service dnis overlay
service dnis dir-lookup
cnf-file location flash:
user-locale FR
network-locale FR
load 7962 SCCP42.9-2-1S.loads
load 6941 SCCP69xx.9-3-3-2-SR1.loads
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
moh "moh.wav"
multicast moh 239.10.16.4 port 16384
web admin system name admin password retis
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
call-forward pattern .T
after-hours block pattern 1 00336........ 7-24
after-hours block pattern 2 00337........ 7-24
night-service everyday 17:31 08:59
directory last-name-first
ephone-template 17
softkeys idle Newcall Redial Cfwdall Gpickup Dnd
ephone-template 18
softkeys idle Newcall Redial Cfwdall Pickup
ephone-template 19
softkeys idle Newcall Pickup Gpickup
ephone-template 20
softkeys ringing Answer Dnd HLog
ephone-dn 55 dual-line
number 980
pickup-group 1
description 980
allow watch
call-forward busy 06XX885655
call-forward noan 06XX885655 timeout 25
ephone 55
mac-address 20BB.C01F.02B6
ephone-template 19
max-calls-per-button 3
busy-trigger-per-button 1
presence call-list
type 6941
button 1:55
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
11-20-2013 03:07 AM
RONAN,
try to add sip supplementary-service under voice service voip and try again.
11-20-2013 03:10 AM
But SIP profile are only for DECT and one test phone.
All phones are registered in SCCP so I don't think it is a good idea to add "sip supplementary-service"....
11-20-2013 03:42 AM
I this is the issue of Plan:ISDN type
coz for original calls its showing as type: National for calling and unknown as called number and while in forwarding it is showing as National for both.
try setting "numbering-type any unknown" in DP or voice-port or in translation rule of ANI
11-20-2013 03:46 AM
Hi Ronan,
Can you try the workaround given in the following link ?
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a0080816cac.shtml
“If you have knowledge, let others light their candles in it.”
11-20-2013 05:29 AM
I tried to put "numbering-type unknown" in the outgoing dial-peer but without success...
I checked the workaround before but i don't understand anything about the explain and workaround. I have to do a translation rule but I don't know what translation I have to do ??
Can you explain me more about the workaround please ?
I'm sorry but I start in the voice world
Thanks a lot
Ronan
