04-01-2012 12:11 PM - edited 03-16-2019 10:24 AM
I have a CME 9.0 system on which I have configured an ephone-hunt list as shown below:
ephone-hunt 2 longest-idle
pilot 54756222
list 54756235, 54756275, 54756255, 54756245, 54756332, 54756203
final 50000600
timeout 10, 10, 10, 10, 10, 10
I am using Extension Mobility The ephone-dn's etc. are configured as shown below:
voice user-profile 235
pin 1471
user 0040816 password cisco
number 54756235 type normal
feature-button 1 HLog
ephone-dn-template 2
call-forward max-length 13
call-forward busy 50000600
call-forward noan 50000600 timeout 17
hold-alert 30 originator
allow watch
ephone-dn 235 dual-line
number 54756235
ephone-hunt login
The users are able to log in/out of the hunt group using the HLog key.
When at least one user is logged in everything works ok - if the call is not answered it is forwarded to the destination specified in the final command.
However when no users are logged in to the hunt group the call is not forwarded to the final destination and callers hear fast-busy.
If anyone can suggest how this can be resolved I will be very grateful.
04-02-2012 05:31 AM
Hi James,
The first thing I would try is to add 1 DN that is used in the logged-out profile
to the ephone-hunt list. So lets say 54756215 is a DN used in the logged-out
profile for EM, add it to the list as such;
list 54756235, 54756275, 54756255, 54756245, 54756332, 54756203, 54756215
timeout 10, 10, 10, 10, 10, 10, 10
Cheers!
Rob
04-02-2012 06:28 AM
Hi Rob,
Thanks for the response. Unfortunately the problem remained when I tried it.
Luckily for me the customer asked me to remove the hunt group and just configure a physical phone with the pilot number in the same pickup group - the users then pickup calls when they hear the physicl phone ringing.
They had this on their old system and asked to replicate - pretty basic but it got me out of a hole!
James
04-02-2012 06:40 AM
Hey James,
Good stuff my friend
Customers changing their minds is usually very painful, but in this case their
indecisiveness rocks!! Hahahahaha
Cheers!
Rob
PS: +5 for including your final solution. Thanks for this!
