501
Highlighted
Beginner
CME 9.0 voice hunt-group parallel problme
i'm trying to configure how to preserve hunt groups using the SRST-E using SRST manger ( no UMG).
Almost everything is working except hunt groups with parallel serving when one of the members in not connected.
Does somebody know how to solve it? when all ephones-dn from list are active it is working, if i shutdown the sip trunk to CUCM it is also working wit less member.
the SRST-E is hosted by the same router as the local gw so i need to have a trunk to CUCM, i'm using option-keepalive to brough down the sip trunk when simulating WAN outage.
I need to prefer the SIP trunk over local as in normal situation i need  them to go CUCM. I see that the option-keep alive does not bring out down the dial-peer, only busy out. when i shutdown the dial-peer 11 it is also working with only 2 phones active instead of all 3. otherwise i get fast busy signal.
relevant config:
voice hunt-group 1 parallel
list 62,61,63
timeout 60
pilot 300
preference 4 secondary 9
dial-peer voice 11 voip
preference 1
destination-pattern 6[0-9]$
session protocol sipv2
session target ipv4:10.101.55.10
voice-class codec 1
voice-class sip options-keepalive up-interval 15 down-interval 5 retry 2
voice-class sip bind control source-interface Loopback0
voice-class sip bind media source-interface Loopback0
dtmf-relay rtp-nte
no vad
dial-peer voice 12 voip
preference 1
destination-pattern 300$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer hunt 2
ephone-dn  1  dual-line
number 61
pickup-group 1
description 61
name 61
preference 4
call-forward busy 200
call-forward noan 200 timeout 25
ephone-dn  2  dual-line
number 63
pickup-group 1
description 63
name 63
preference 4
ephone-dn  3  dual-line
number 62
pickup-group 1
description 62
preference 4
ephone  1
device-security-mode none
mac-address 34A8.4E60.CD9E
after-hours exempt
username "JursikD"
type 6941
button  1:1
ephone  2
mac-address 5C50.15A9.20E7
after-hours exempt
username "SEP5C5015A920E7"
type 7942
button  1:2
ephone  1000
mac-address FE51.B880.3876
type CIPC
button  1:3
dial-peer hunt 2
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
1      pots  up   up             .T                 6                      up   0/3/0
200    voip  up   up             2..                0  syst ipv4:10.101.55.5
10     voip  down down           6..                0  syst ipv4:10.101.55.10
11     voip  up   up             6[0-9]$            1  syst ipv4:10.101.55.10             busyout
12     voip  up   up             300$               1  syst ipv4:10.101.55.10             busyout
20001  pots  up   up             61$                4                           50/0/1
20002  pots  up   up             63$                4                           50/0/2
20003  pots  up   up             62$                4                           50/0/3
40001  voip  up   up             64$                4  syst ipv4:10.101.55.18:50
21474- voip  up   up             300$               4  syst loopback:rtp
83647
thanks and Regards,
d.
2 REPLIES 2
Highlighted
Beginner
Some update. This happen if the the not registered phone is first in voice hunt group even if it should be parallel.
It not first it works as expected.
Highlighted
Beginner
Hey,
have you ever found a solution for this problem?
I habe a similar problem. It occurs if the first number in the list is busy.
Kind regards
Andre
