Community Helping Community
1181
Beginner
[CME 9.1] Call drops after certain amount of time (b-acd)
Hi all!
I have a strange issue, while deploying b-acd at my customer. Call drops after ~100 seconds when b-acd connects a new call to new availible hunt-groups. I have tested both SIP (6941, 3905, 8961) and SCCP(7937) phones. The call successfully starts, rtp flows ok, sound is good, but call suddenly drops after certain amount of time..
This issue only arises when b-acd script is engaged. Normal calls, transfers etc work normally.
Config is in attach(file config1.txt)
Here is an output from "Debug voice ccapi detail" in the moment when call drops. Also I have attached complete debug from the stage where I call pilot number till the call drops (file debug_voice_ccapi_detail1.txt)
telephony#
*Dec 27 17:15:50.635: //1652/AA020AB68661/CCAPI/ccCallDisconnect:
   Start Calling Accounting;
   Call Entry(Incoming=TRUE)
   Cause Value=41, Call Entry(Disconnect Cause=41)
*Dec 27 17:15:50.635: //1657/AA020AB68661/CCAPI/ccCallDisconnect:
   Call Entry(Incoming=FALSE)
   Cause Value=41, Call Entry(Disconnect Cause=0)
*Dec 27 17:15:50.635: //1652/AA020AB68661/CCAPI/cc_decr_if_call_volume:
   Remote IP Address=10.10.0.41, Hwidb=GigabitEthernet0/0
   Total Call Count=3, Voip Call Count=3, MMoip Call Count=0
*Dec 27 17:15:50.635: //1652/AA020AB68661/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
*Dec 27 17:15:50.635: //1652/AA020AB68661/CCAPI/cc_delete_call_entry:
   Raw Message=0x2D2C0BAC
   Total Call Count=2, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=1
   Deleting profileTable[0x33D6151C]
*Dec 27 17:15:50.635: //1652/AA020AB68661/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=1652
   Flag=FALSE
*Dec 27 17:15:50.635: //1652/AA020AB68661/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=1652
   Call Entry(Voip AAA Flags=0x0)
*Dec 27 17:15:50.635: //1657/AA020AB68661/CCAPI/cc_api_update_interface_cac_resource:
   Hwidb=GigabitEthernet0/0, Bandwidth=-80, Call Id=1657
   Total Call Count=3, Voip Call Count=3, MMoip Call Count=0x0, Bandwidth=80
*Dec 27 17:15:50.635: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
*Dec 27 17:15:50.635: //1650/AA020AB68661/CCAPI/ccCallDisconnect:
*Dec 27 17:15:50.639: //1651/AA020AB68661/CCAPI/ccCallDisconnect:
*Dec 27 17:15:50.639: //1650/AA020AB68661/CCAPI/cc_api_update_interface_cac_resource:
   Hwidb=GigabitEthernet0/0, Bandwidth=-80, Call Id=1650
   Total Call Count=3, Voip Call Count=3, MMoip Call Count=0x0, Bandwidth=0
*Dec 27 17:15:50.639: //1651/AA020AB68661/CCAPI/cc_decr_if_call_volume:
   Total Call Count=2, Voip Call Count=2, MMoip Call Count=0
*Dec 27 17:15:50.639: //1651/AA020AB68661/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
*Dec 27 17:15:50.639: //1651/AA020AB68661/CCAPI/cc_delete_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
   Deleting profileTable[0x33D62E6C]
*Dec 27 17:15:50.639: //1651/AA020AB68661/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=1651
   Flag=FALSE
*Dec 27 17:15:50.639: //1651/AA020AB68661/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=1651
*Dec 27 17:15:50.639: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Dec 27 17:15:50.651: //1650/AA020AB68661/CCAPI/cc_decr_if_call_volume:
   Remote IP Address=10.10.1.50, Hwidb=GigabitEthernet0/0
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
*Dec 27 17:15:50.651: //1650/AA020AB68661/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
*Dec 27 17:15:50.651: //1650/AA020AB68661/CCAPI/cc_delete_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=0
   Deleting profileTable[0x33D6499C]
*Dec 27 17:15:50.655: //1650/AA020AB68661/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=1650
   Flag=FALSE
*Dec 27 17:15:50.655: //1650/AA020AB68661/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=1650
*Dec 27 17:15:50.655: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Dec 27 17:15:50.679: //1657/AA020AB68661/CCAPI/cc_decr_if_call_volume:
   Remote IP Address=10.10.0.90, Hwidb=GigabitEthernet0/0
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
*Dec 27 17:15:50.679: //1657/AA020AB68661/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
*Dec 27 17:15:50.679: //1657/AA020AB68661/CCAPI/cc_delete_call_entry:
telephony#Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
   Deleting profileTable[0x33D6615C]
*Dec 27 17:15:50.679: //1657/AA020AB68661/CCAPI/ccCallGetVoipFlag:
   Data Bitmask=0x2, Call Id=1657
   Flag=FALSE
*Dec 27 17:15:50.679: //1657/AA020AB68661/CCAPI/ccCallSetVoipFlag:
   Flag=FALSE, Data Bitmask=0x2, Call Id=1657
*Dec 27 17:15:50.679: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
telephony#
Version of CME is 9.1
Version of IOS is 15.3(1)T (also tested in 15.2 - the same issue)
Version of b-acd is 3.0.0.2
All ip phones have the latest firware, also I have already downgraded some of them - the issue persists.
I am very suspicious about "Call Entry Is Not Found" and strange "Disconnect Cause=41".
The map of call is:
Internal extension "502" (ip phone 6941 in our case) dials pilot number "799" and then menu#2 is selected, falling to extesion "701" (ip phone 8961 in our case). The call successfully starts but suddenly it disconnects (after ~100 seconds).
Thanks in advance and happy new year!
Everyone's tags (3)
5 REPLIES 5
Hall of Fame Master
Can you try 15.2(4)M2.
Beginner
Re: [CME 9.1] Call drops after certain amount of time (b-acd)
Hi!
Thanks for the reply, i have been far away from customer, so yesterday I checked the b-acd work with
15.2(4)M2. The issue persists, moreover, call failed even it was not answered. Here are additional logs (debug voice ccapi inout, debug voice application tclcomand, etc).
It simply disconnects after 2-3 sec after "2" was pressed (menu#2, send call to hunt group).
Highlighted
Beginner
After I deleted the strings
timer media-inactive 10
timer receive-rtp 1200
in 'gateway' section, all starts work exempt one bug, that I described in this topic:
https://supportforums.cisco.com/thread/2192087
Beginner
Now it stops working. Again, with normal call clearing (cause code 16). Relevant debug are in attach.
I cannot even understand the systematic of this issue. It just drops after 10 seconds if nobody answeres or drops right after somebody pick up a phone.
Yesterday it worked perfectly.
Beginner
After '198' dialed everything work fine exempt Hold Issue. Reboot - dial '198' (dial-peer 198) - all works.
Any ideas ?
Content for Community-Ad
FusionCharts will render here
