02-16-2019 09:24 PM - edited 03-17-2019 02:07 PM
Hi all,
I have a cme and cucm that are connected via a ppoe link between offices. Both sides can ping each other but the calls are not being connected.what or where could be the issue? I have a debug of the attached call test attached. 209 is calling 113. The setup was working before but service providers have been changed!
Thanks.
02-16-2019 10:01 PM
1) As per the provided logs the disconnect cause value is 63 and 38. Which means
Cause No. 63 - service or option not available. unspecified.
This cause is used to report a service or option not available event only when no other cause in the service or option not available class applies.
Cause No. 38 - network out of order.
This cause indicates that the network is not functioning correctly and that the condition is likely to last a relatively long period of time e.g., immediately re-attempting the call is not likely to be successful.
2) Check the CUCM SDL Log to see if CUCM is able to receive the SIP/H323 messaged from CUCME.
3) Check for any ACL, Firewall Rules blocking these ports
4) Disable SIP/H323 Inspection in Firewall
5) you can try to do a packet capture on both ends to verify if issue is from Provider.
For Packet capture on CUCM
For Packet capture on Router
***** Please rate helpful post ; Mark "Accept as a Solution" if applicable
Haris
02-17-2019 11:10 PM
Hi Haris,
Thanks for the reply. I will be troubleshooting the issue as you have recommended,however, i just want to add that both sides use skinny protocol.
