cme and cucm with sip trunk
Dear Expert
I have CUCM using sip trunk to cme. From the CME i am using SIP dial-peer to CUCM. The issue that i have when a call from CME to CUCM everything is fine but when i call from CUCM to CME one way audio (cme user can hear but cucm user can not hear). Please help me to solve this issue
5 Replies 5
Chris Deren
Post your CME config, do you have sip blinded to proper interface which you are using as destination of the SIP trunk in CUCM?
Dear Chris
Yes i binded please check sh run
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.05.03 12:08:37 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 18191 bytes
! Last configuration change at 13:20:24 AST Sat May 2 2015 by root
version 15.4
hostname RAIIC-R-BK
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
clock timezone AST 3 0
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 172.16.4.1 172.16.4.10
ip dhcp excluded-address 172.20.5.1 172.20.5.10
ip dhcp excluded-address 172.20.1.1 172.20.1.50
ip dhcp pool VOICE-POOL
 network 172.20.5.0 255.255.255.0
 option 150 ip 172.20.5.1
 default-router 172.20.5.1
 --More--         ip domain name yourdomain.com
ip host ftpserver 172.20.1.65
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-61842014
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-61842014
 revocation-check none
 rsakeypair TP-self-signed-61842014
crypto pki certificate chain TP-self-signed-61842014
 certificate self-signed 01
  30820227 30820190 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  2F312D30 2B060355 04031324 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 36313834 32303134 301E170D 31353031 30333138 34383237
  5A170D32 30303130 31303030 3030305A 302F312D 302B0603 55040313 24494F53
  2D53656C 662D5369 676E6564 2D436572 74696669 63617465 2D363138 34323031
  3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 81008D3F
  64577784 1E891641 15B37977 6579AF89 2E300D03 485ED4DC 8A54C58A 1C38E575
  1D60BE34 A82ACACA 8636F6AE 95306159 8AD50FF9 5A6202E5 06B7CCEB 0E4DED0F
  0E366EA8 527D763C E28A448C E48D7890 8CF03641 44EDD092 43526251 EA0FF63D
  7DC8630C 373EE81D 016AC11C 0E154969 9B61F752 A4E1BD51 68AEE19F 21CB0203
  010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603 551D2304
  18301680 14A35C51 F1662E79 D2E0A29D 94C104DA B11F7F15 65301D06 03551D0E
  04160414 A35C51F1 662E79D2 E0A29D94 C104DAB1 1F7F1565 300D0609 2A864886
  F70D0101 05050003 81810052 8AF4BE1E 107602DC 28AF296D 21A3F29F 620B316B
  9E787D9A F435396C 15A0F7D3 A940EB2E 8F9FEA00 431D2512 1705C2E3 53278219
  B43EEE17 CEA89208 3E82BA5C 36D05491 A544C260 9746827A C37B282D 79007DB5
  9D2001E1 89003411 0A8A6A23 6CB7DB38 0DD8F519 4650CB2A 3E2EC3CB 3CF95A77
  8EE7187C 5147362D 593900
  quit
voice-card 0
 voice-service dsp-reservation 75
 --More--          dspfarm
 dsp services dspfarm
voice service voip
 ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 no supplementary-service sip handle-replaces
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/1.6
  bind media source-interface GigabitEthernet0/1.6
  registrar server expires max 600 min 60
  no silent-discard untrusted
voice class codec 3
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice register global
 mode  cme
 source-address 172.20.5.1 port 5060
 max-dn 60
 max-pool 42
 load 7945 term45.default.loads
 load 7821 sip78xx.10-2-1-12SR1-4.loads
 authenticate register
 timezone 31
 --More--          tftp-path flash:
 create profile sync 0114107411455382
voice register dn  1
 number 4000
 label CEO
voice register dn  2
 number 4101
 label Supervisor
voice register dn  3
 number 4111
 label IT Support
voice register dn  4
 number 4099
 call-forward b2bua all 4100
 label Reception
voice register dn  5
 number 4010
 label CFO
voice register dn  6
 number 4100
 label IT HoD
voice register dn  7
 number 4102
 label System Admin
voice register dn  8
 number 4120
 label Finance HoD
voice register dn  9
 number 4123
 label Accountant
voice register dn  10
 number 4140
 label Procurement Manager
 --More--         !
voice register dn  11
 number 4141
 label Procurement Clerk
voice register dn  12
 number 4160
 label HR HoD
voice register dn  13
 number 4161
 label HR Clerk
voice register dn  14
 number 4165
 label HR FrontDesk
voice register dn  15
 number 4180
 label Janitor
voice register dn  16
 number 4181
 label Security Post
voice register dn  17
 number 4200
 label Youssef
voice register dn  18
 number 4201
 label Zuraimi
voice register dn  19
 number 4250
 label zahari
voice register dn  20
 number 4300
 label Eng.Abdullah
voice register dn  21
 number 4011
 --More--          label Construction Dir.
voice register dn  22
 number 4012
 label FMO Director
voice register dn  23
 number 4013
 label Procurement Dir.
voice register dn  24
 number 4014
 label CS Director
voice register dn  25
 number 4001
 label CEO
voice register pool  1
 busy-trigger-per-button 2
 id mac 8480.2DD5.6D7D
 type 7821
 number 1 dn 1
 number 2 dn 25
 cor incoming CEO default
 username AliHashem password 12345
 codec g711ulaw
voice register pool  2
 id mac 8480.2DD5.6DF6
 type 7821
 number 1 dn 2
 cor incoming LD default
 username Ahmad password 12345
 codec g711ulaw
voice register pool  3
 id mac 8480.2DD5.6DDB
 type 7821
 number 1 dn 3
 cor incoming Local default
 --More--          username ITDesk password 12345
 codec g711ulaw
voice register pool  4
 id mac 8480.2DD5.6D8E
 type 7821
 number 1 dn 4
 username Reception password 12345
 codec g711ulaw
voice register pool  5
 id mac E0D1.73E4.FC87
 type 7821
 number 1 dn 5
 cor incoming International default
 username MansoorShafi password 12345
 codec g711ulaw
voice register pool  6
 id mac 8480.2DD5.6E17
 type 7821
 number 1 dn 6
 username NassirAtik password 12345
 codec g711ulaw
voice register pool  7
 id mac 8480.2DD5.6D8D
 type 7821
 number 1 dn 7
 username Nohman password 12345
 codec g711ulaw
voice register pool  8
 id mac 8480.2DD5.6D66
 type 7821
 --More--          number 1 dn 8
 username Rajab password 12345
 codec g711ulaw
voice register pool  9
 id mac 8480.2DD5.5F05
 type 7821
 number 1 dn 9
 username Bilal password 12345
 codec g711ulaw
voice register pool  10
 id mac 8480.2DD5.6DD0
 type 7821
 number 1 dn 10
 username Asif password 12345
 codec g711ulaw
voice register pool  11
 id mac 8480.2DD5.6D77
 type 7821
 number 1 dn 11
 username Khalid password 12345
 codec g711ulaw
voice register pool  12
 id mac 8480.2DD5.6DE8
 type 7821
 number 1 dn 12
 username Shami password 12345
 codec g711ulaw
voice register pool  13
 --More--          id mac 8480.2DD5.6DD4
 type 7821
 number 1 dn 13
 username OmarMoosa password 12345
 codec g711ulaw
voice register pool  14
 id mac E0D1.73E5.149B
 type 7821
 number 1 dn 14
 username HRfrontDesk password 12345
 codec g711ulaw
voice register pool  15
 id mac E0D1.73E5.1536
 type 7821
 number 1 dn 15
 username Janitor password 12345
 codec g711ulaw
voice register pool  16
 id mac E0D1.73E5.023C
 type 7821
 number 1 dn 16
 username SecurityPost password 12345
 codec g711ulaw
voice register pool  17
 id mac E0D1.73E5.1AF5
 type 7821
 number 1 dn 17
 username Youssef password 12345
 codec g711ulaw
voice register pool  18
 --More--          id mac E0D1.73E5.22C9
 type 7821
 number 1 dn 18
 username Zuraimi password 12345
 codec g711ulaw
voice register pool  19
 id mac 8480.2DD5.6E3A
 type 7821
 number 1 dn 19
 username Zahari password 12345
 codec g711ulaw
voice register pool  20
 id mac E0D1.73E5.2D19
 type 7821
 number 1 dn 20
 username Eng.Abdullah password 12345
 codec g711ulaw
voice register pool  21
 id mac E0D1.73E5.1430
 type 7821
 number 1 dn 21
 username Imran password 12345
 codec g711ulaw
voice register pool  22
 id mac 1CE8.5D06.205E
 type 7821
 number 1 dn 22
 username SufianLau password 12345
 codec g711ulaw
 --More--         voice register pool  23
 id mac 1CE8.5D06.2035
 type 7821
 number 1 dn 23
 username ProcurementDir. password 12345
 codec g711ulaw
voice register pool  24
 id mac 1CE8.5D06.204A
 type 7821
 number 1 dn 24
 username CSDirector password 12345
 codec g711ulaw
license udi pid CISCO2901/K9 sn FGL190121CX
hw-module pvdm 0/0
file privilege 0
username root privilege 15 secret 5 $1$e4.B$GpPyxi.ZRP9V2ewq06m.c1
redundancy
gw-accounting file
 primary ftp ftpserver/cdr01 username cdr password asd.1234
 maximum retry-count 5
 cdr-format compact
interface Loopback0
 ip address 4.4.4.4 255.255.255.255
interface Embedded-Service-Engine0/0
 --More--          no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address 172.21.225.122 255.255.255.252 secondary
 ip address 188.117.110.145 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1.2
 description Data-VLAN
 encapsulation dot1Q 2
 ip address 172.20.1.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.3
 description Servers-VLAN
 encapsulation dot1Q 3
 ip address 172.20.2.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.4
 description Wireless-VLAN
 encapsulation dot1Q 4
 ip address 172.20.3.1 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.5
 description Security-VLAN
 encapsulation dot1Q 5
 --More--          ip address 172.20.4.1 255.255.255.0
 description Voice-VLAN
 encapsulation dot1Q 6
 ip address 172.20.5.1 255.255.255.0
interface GigabitEthernet0/0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0/0.235
 encapsulation dot1Q 235
 ip address 172.18.61.230 255.255.255.252
router bgp 65306
 bgp log-neighbor-changes
 network 172.20.1.0 mask 255.255.255.0
 network 172.20.5.0 mask 255.255.255.0
 neighbor 172.18.61.229 remote-as 65000
ip default-gateway 172.16.4.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool Internet 188.117.110.145 188.117.110.145 netmask 255.255.255.248
ip nat inside source list 10 pool Internet overload
ip route 0.0.0.0 0.0.0.0 172.21.225.121
tftp-server flash:rootfs78xx.10-2-1-12SR1-4.sbn
tftp-server flash:sboot78xx.10-2-1-12SR1-4.sbn
tftp-server flash:sip78xx.10-2-1-12SR1-4.loads
tftp-server flash:kern78xx.10-2-1-12SR1-4.sbn
tftp-server flash:term65.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:SIP45.9-4-2-1S.loads
 --More--         tftp-server flash:jar45sip.9-4-2TH1-1.sbn
tftp-server flash:dsp45.9-4-2TH1-1.sbn
tftp-server flash:cvm45sip.9-4-2TH1-1.sbn
tftp-server flash:cnu45.9-4-2TH1-1.sbn
tftp-server flash:apps45.9-4-2TH1-1.sbn
access-list 10 permit 172.20.1.0 0.0.0.255
access-list 10 permit 0.0.0.0 255.255.255.0
control-plane
voice-port 0/1/0
 cptone SA
 connection plar 4099
 caller-id enable
voice-port 0/1/1
 cptone SA
 caller-id enable
voice-port 0/1/2
 cptone SA
 caller-id enable
voice-port 0/1/3
 cptone SA
 caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/1.6
 --More--         sccp ccm 172.20.5.1 identifier 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/1.6
 associate ccm 1 priority 1
 associate profile 1 register KHOM-CFX
 associate profile 2 register KHOM-TRX
dspfarm profile 2 transcode
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 maximum sessions 3
 associate application SCCP
dial-peer cor custom
 name localcall
 name ldcall
 name internatcall
 name CEOLine
dial-peer cor list Local
 member localcall
dial-peer cor list LongDis
 member ldcall
dial-peer cor list INTERNAT
 member internatcall
dial-peer cor list LD
 member localcall
 member ldcall
dial-peer cor list International
 member localcall
 member ldcall
 --More--          member internatcall
dial-peer cor list CEO
 member CEOLine
dial-peer voice 92689 pots
 corlist outgoing Local
 destination-pattern 8[2689]T
 port 0/1/1
dial-peer voice 926890 pots
 corlist outgoing LongDis
 destination-pattern 8[02689][123456789]T
 port 0/1/1
dial-peer voice 9268900 pots
 corlist outgoing INTERNAT
 destination-pattern 8[02689][0123456789]T
 port 0/1/1
dial-peer voice 12001 pots
 incoming called-number .T
dial-peer voice 92289 pots
 port 0/1/0
dial-peer voice 922890 pots
 port 0/1/0
dial-peer voice 9228900 pots
 port 0/1/0
dial-peer voice 92229 pots
 port 0/1/2
 --More--         !
dial-peer voice 922290 pots
 port 0/1/2
dial-peer voice 9222900 pots
 port 0/1/2
dial-peer voice 92223 pots
 corlist outgoing CEO
 port 0/1/3
dial-peer voice 922230 pots
 port 0/1/3
dial-peer voice 9222300 pots
 port 0/1/3
dial-peer voice 1000 voip
 destination-pattern 1...
 session target ipv4:10.10.10.20
dial-peer voice 2300 voip
 destination-pattern 3...
 session target ipv4:10.10.10.11
dial-peer voice 9000 voip
 description "Incoming Call from Laith"
 session protocol sipv2
 session target sip-server
 session transport udp
 voice-class codec 3
 dtmf-relay rtp-nte sip-notify
 no vad
 --More--         !
dial-peer voice 9001 voip
 preference 2
 voice-class codec 3
 no vad
dial-peer voice 2301 voip
 destination-pattern 2...
dial-peer voice 9002 voip
 preference 1
 destination-pattern 9...
 session target ipv4:172.16.5.1
 codec g711ulaw
 no vad
dial-peer voice 9003 voip
 preference 2
 session target ipv4:172.16.5.2
 codec g711ulaw
 no vad
sip-ua
 sip-server ipv4:172.16.5.1
gatekeeper
 shutdown
 --More--         !
telephony-service
 sdspfarm units 2
 sdspfarm tag 1 KHOM-CFX
 sdspfarm tag 2 KHOM-TRX
 ip source-address 172.20.5.1 port 2000
 max-conferences 8 gain -6
 web admin system name root password admin@123
 dn-webedit
 time-webedit
 transfer-system full-consult
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
 --More--
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
line vty 5 15
 privilege level 15
 login local
scheduler allocate 20000 1000
end
RAIIC-R-BK#
Man,.....
im sorry for that but i know you just made this topic in order to solve issue in at your borders i just want your help in order to make SIP trunk between CUCM and CME ,.. i have just made it and now the CUCM able to call CME but CME not able the CUCM pattern is 59XX
all i have did at my CME is the following,
telephony-service
 load 7911 SCCP11.8-3-3S
 max-ephones 50
 max-dn 100
 ip source-address 172.16.150.20 port 2000
 system message Welcome in UPS
 create cnf-files version-stamp Jan 01 2002 00:00:00
dial-peer voice 1 voip
 destination-pattern 59..  <<<<<<<<<<<<<<< for example 5925
 voice-class codec 1
 session target ipv4:172.16.10.51     CUCM IP <<<<<<<<<<<<<<<<<<<
 dtmf-relay sip-notify
 no vad
sip-ua
 sip-server ipv4:172.16.10.51
Hi Ibrahim
Could you please send the show run of your CME.
