12-05-2012 01:15 PM - edited 03-16-2019 02:34 PM
I have an AIM-CUE module in a 3825 router running CME 8.6. and CUE 7.4. Can I downgrade both versions? For CME is that as simple as downgrading the IOS? For CUE can I back up 7.4, downgrade to 7.02 and then restore from the 7.4 backup?
Thanks. All replies rated.
12-05-2012 03:29 PM
What is your reason for downgrading? That is not an usual thing to do.
Chris
12-06-2012 07:34 AM
Hello Chris,
This is for my lab. The AIM module will only go up to a certain revision for Unity Express and the version of CME running on my router is 8.6. The version of CUE I had to install to make it compatible requires licenses. Since this is for my lab I don;t want to purchase licenses and I think licenses for CUE 7.x are EOS anyway.
My though was to revert to a version of both CME and CUE that do not require licenses.
Is that possible.
