Webcast SD-WAN
155
Frequent Contributor
cme and uccx integation
Can cme still be integrated with UCCX- Ive seen some web pages are suggesting this is no longer available as an option- is it supported ?
thanks
wayne
5 REPLIES 5
Beginner
No, not anymore. Last version
No, not anymore. Last version of CME and UCCX integration support was on 8.6 and 8.5 respectively.
Sami
Thanks,  what about BE-does
Thanks,  what about BE-does that contain UCCX and ccm?
Any reduction in UCCX features?
Beginner
I am not sure, if I clearly
I am not sure, if I clearly understand that. I am assuming you're looking at CUCM-BE integration with UCCX. If so, CUCM-BE and UCCX integration is still supported.
Starting with UCCX 10.x option of running CAD or moving to Finesse is supported as well.
It was instead of the
It was instead of the existing cme.  If they can not do cme with a new UCCX then possibly suggest to migrate,  upgrade to be and UCCX
Does cucm-be come with UCCX ad a bundle?
Highlighted
Beginner
No, it doesn't. It isn't part
No, it doesn't. It isn't part of the BE package.
Content for Community-Ad
June's Community Spotlight Awards
