I have a CME 8.X setup. Call blocking is done by using both CORlists and after-hours blocking. I assign a phone's calling privilege (can call internal, local, NDD, IDD)by assigning CORlists, but I try to control long distance calling (NDD and IDD) via PIN codes by using after-hours blocking. Basically, phones that can call long distance should be able to do so only by using PIN codes.
I have configured some phones to be unable to call long distance, but when I login with the PIN, this phone can call any numbers blocked by the after-hours blocking. Is this the expected behavior when using COR with after-hours blocking?
