CME Call Forward to another extension with Nevotek Voicemail is not working.
Shobhit Sinha
Hi All,
I have Cisco Call Manager Express and Nevotek Server for Voice Mail.
Scenario: PSTN/Internal -->Reception Phone 1 ( Rings 4 ) --> Call Forward Busy/NO Answer -->Recpetion Phone 2 ( Rings 4) -> Go to Voice Mail of Reception Phone 2.
Problem : When we are dialing from PSTN/Internal it rings at Phone 1 then Phone 2 but it is going to Voice Mail of Phone1.As per Scenario we need it at Phone 2 Voice Mail.
Please advice.
ephone-dn 1 dual-line
number 2001
call forward busy 2002
call forwarn noan 2002 timeout 10
ephone-dn 2 dual-line
number 2002
call forward busy 8200
call forwarn noan 8200 timeout 10
5 Replies 5
Rob Huffman
Hi Shobhit,
This will be something that needs to be configured on the
Nevotek voicemail system as CME is doing it's job properly here.
Most voicemail systems use the "originally dialed number" to route calls
to the proper mailbox, in this case that would be phone 1/2001. In systems
like CUE or Unity Connection you can change the system to use the
"last redirecting number" which in this case would be phone 2/2002.
You will need to look for this setting in the Nevotek system
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
Hi Rob
Thanks for your reply !!
But Nevotek system is getting called Number as 2001 for their Voice Mail in their logs.
Is there any way if we can change it called number to 2002 as it forwarded from 2001 in CME??
Appreciate your help..
Rob Huffman
Hi Shobhit,
First off, you are most welcome my friend
The problem here is that 2001 "is" the called number. On all voicemail systems
that I've seen or worked with, the way to "fix' this is always done by a configuration
change on the voicemail system not the Call control system (CME in this example).
I can't find any Nevotek config guides online or I would be happy to help you look
for what needs to be tweaked here.
Cheers!
Rob
Hi Rob,
Is there any way that we can use hunt group for this case?
I tried to create a hunt group and place these two extensions in it, but still no luck..
I used a translation rule for incoming calls to go to 5000 instead of 2001
ephone-hunt 1 sequential
Pilot 5000
List 2001,2002
timeout 10,10
Can we do something with hunt groups?
Rob Huffman
Hi Shobhit,
The use of a Hunt set up will just transfer the problem to a different
"Called" number. Does the Nevotek have any place where you can configure
an "Alternate" extension under the 2002 mailbox.
This would be where you can have another called number like 2001
built as an Alternate number under 2002?
Cheers!
Rob
PS: you might be able to try the "Final" command under the Hunt to Final 2002
