Community Helping Community
905
Participant
Most likely, your Telco
Most likely, your Telco requires the redirecting number to be a valid DID assigned to your PRI. You need to use translation rules to change it from a four digits extension to a DID. Here is an exemple how to make this happen:
voice translation-rule 1
rule 1 /.*/ /XXXXXXXXXX/
  (where XXXXXXXXX is a valid DID on the PRI, exemple: main number)
voice translation-profile ReplaceRedirect
translate redirect-called 1
Apply the translation rule to your outgoing dial-peers:
dial-peer voice Y pots
translation-profile outgoing ReplaceRedirect
Please rate helpful answers!
Rising star
Hello,could you please try
could you please try configuring 'call-forward pattern .T' under telephony-service and check?
//Suresh
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Highlighted
Beginner
I had actually removed that
I had actually removed that command, I have placed it back.  Does not make any difference.  Thank you.
Participant
Hi Jaswild999, Can you remove
Beginner
No luck.  Still says, "Call
No luck.  Still says, "Call can not be completed as dialed".
chrs-phx-cme#sh logg
Syslog logging: enabled (0 messages dropped, 10 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 580 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 587 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 290 message lines logged
Log Buffer (300000 bytes):
Mar 23 21:09:11.061: //-1/36D344F781B1/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=888
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Mar 23 21:09:11.065: //-1/36D344F781B1/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4B87A944, Call Info(
   Calling Number=888,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20056, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 23 21:09:11.065: //-1/36D344F781B1/CCAPI/ccCheckClipClir:
   In: Calling Number=888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 23 21:09:11.065: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 23 21:09:11.065: :cc_get_feature_vsa malloc success
Mar 23 21:09:11.065:  cc_get_feature_vsa count is 1
Mar 23 21:09:11.065: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273047416,feature_id:206
Mar 23 21:09:11.065: //156/36D344F781B1/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Mar 23 21:09:11.065: //156/36D344F781B1/CCAPI/cc_process_call_setup_ind:
   Event=0x495F0470
Mar 23 21:09:11.065: //156/36D344F781B1/CCAPI/ccCallSetContext:
   Context=0x4BE344DC
   >>>>CCAPI handed cid 156 with tag 20056 to app "_ManagedAppProcess_Default"
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/ccCallSetupAck:
   Call Id=156
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=156
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/ccCallReportDigits:
   (callID=0x9C, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=156
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4B87A944, callID=0x9C, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x4B87A944, Call Id=156
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
Mar 23 21:09:11.269: //156/36D344F781B1/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=156, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x30958, Rtp Expiration=0x0
Mar 23 21:09:11.269: //156/36D344F781B1/CCAPI/cc_api_call_digit_end:
   Source Call Id=156, Digit=1, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Mar 23 21:09:11.469: //156/36D344F781B1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=156, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x38658, Rtp Expiration=0x0
Mar 23 21:09:11.469: //156/36D344F781B1/CCAPI/cc_api_call_digit_end:
   Source Call Id=156, Digit=2, Duration=100,
Mar 23 21:09:11.669: //156/36D344F781B1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=156, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x40358, Rtp Expiration=0x0
Mar 23 21:09:11.669: //156/36D344F781B1/CCAPI/cc_api_call_digit_end:
   Source Call Id=156, Digit=3, Duration=100,
Mar 23 21:09:11.673: //156/36D344F781B1/CCAPI/ccCallReportDigits:
   (callID=0x9C, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 23 21:09:11.673: //156/36D344F781B1/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4B87A944, callID=0x9C, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 23 21:09:11.673: //156/36D344F781B1/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Mar 23 21:09:11.677: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=123
Mar 23 21:09:11.677: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=123, Called Number=123, Calling Number=888, Calling DN=432 Calling Id=156,
   Redirect Number=919155269001, Redirect Reason=15
Mar 23 21:09:11.677: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 23 21:09:11.677: :cc_get_feature_vsa malloc success
Mar 23 21:09:11.681:  cc_get_feature_vsa count is 2
Mar 23 21:09:11.681: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 23 21:09:11.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048312,feature_id:207
Mar 23 21:09:11.681: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Mar 23 21:09:11.681:  feature_vsa is 4BE12970,featname is 0
Mar 23 21:09:11.681: :cc_get_feature_vsa malloc success
Mar 23 21:09:11.681:  cc_get_feature_vsa count is 3
Mar 23 21:09:11.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048760,feature_id:208
Mar 23 21:09:11.681: : Generating new featurevsa,inserting it
Mar 23 21:09:11.681:  feature call forward featname is 1
Mar 23 21:09:11.681: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 23 21:09:11.681: :cc_free_feature_vsa freeing 4BE12CF0
Mar 23 21:09:11.681:  vsacount in free is 2
Mar 23 21:09:11.681: //156/36D344F781B1/CCAPI/ccCallForwardTo:
   Call Forward Number=919155269001, Call Forward Cause Reason=15, Call Id=156
Mar 23 21:09:11.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048312,feature_id:209
Mar 23 21:09:11.685: :cc_free_feature_vsa freeing 4BE12CF0
Mar 23 21:09:11.685: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 23 21:09:11.685:  vsacount in free is 2
Mar 23 21:09:11.685: //156/36D344F781B1/CCAPI/ccCallForwardTo:
Mar 23 21:09:11.685: //156/36D344F781B1/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=8, Params=0x4BE36D3C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 23 21:09:11.685: //156/36D344F781B1/CCAPI/ccCheckClipClir:
Mar 23 21:09:11.689: //156/36D344F781B1/CCAPI/ccCallSetupRequest:
   Destination Pattern=9T, Called Number=91915xxxx001, Digit Strip=TRUE
   Called Number=919155269001(TON=Unknown, NPI=Unknown),
   Redirect Number=123, Display Info=Wilder
   Account Number=, Final Destination Flag=FALSE,
   Guid=37327A6D-B206-11E3-81B5-8869F94C78DE, Outgoing Dial-peer=8
Mar 23 21:09:11.689: //156/36D344F781B1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=888
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=91915xxxx001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=123
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=15   fwd_final_type =0
Mar 23 21:09:11.689: //156/36D344F781B1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4A265E54, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=888,(Calling Name=Wilder)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=91915xxxx001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=8, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 23 21:09:11.689: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 23 21:09:11.689: :cc_get_feature_vsa malloc success
Mar 23 21:09:11.689:  cc_get_feature_vsa count is 3
Mar 23 21:09:11.689: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048312,feature_id:210
Mar 23 21:09:11.689: //157/36D344F781B1/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Mar 23 21:09:11.689: //157/36D344F781B1/CCAPI/ccCallSetContext:
   Context=0x4BE36CEC
Mar 23 21:09:11.689: //156/36D344F781B1/CCAPI/ccSaveDialpeerTag:
Mar 23 21:09:11.689: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Mar 23 21:09:11.689:  feature call forward featname is 1
Mar 23 21:09:11.689:  feature_vsa is 4BE12CF0,featname is 0
Mar 23 21:09:11.689:  cc_get_feature_vsa count is 4
Mar 23 21:09:11.689: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048536,feature_id:211
Mar 23 21:09:11.689: : Generating new featurevsa,inserting it
Mar 23 21:09:11.729: //157/36D344F781B1/CCAPI/cc_api_call_proceeding:
   Interface=0x4A265E54, Progress Indication=NULL(0)
Mar 23 21:09:11.857: //157/36D344F781B1/CCAPI/cc_api_call_cut_progress:
   Interface=0x4A265E54, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/ccConferenceCreate:
   (confID=0x4BDFD374, callID1=0x9C, gcid=36D344F7-B20611E3-81B18869-F94C78DE, tag=0x0)
Mar 23 21:09:11.857: //157/36D344F781B1/CCAPI/ccConferenceCreate:
   (confID=0x4BDFD374, callID2=0x9D, gcid=36D344F7-B20611E3-81B18869-F94C78DE, tag=0x0)
   Conference Id=0x4BDFD374, Call Id1=156, Call Id2=157, Tag=0x0
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B, Source Interface=0x4B87A944, Source Call Id=156,
   Destination Call Id=157, Disposition=0x0, Tag=0xFFFFFFFF
Mar 23 21:09:11.857: //157/36D344F781B1/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B, Source Interface=0x4A265E54, Source Call Id=157,
   Destination Call Id=156, Disposition=0x0, Tag=0xFFFFFFFF
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1B, Destination Call Id=157)
   Call Entry(Conference Id=0x1B, Destination Call Id=156)
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4A265E54, Destination Call Id=157, Source Call Id=156,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Mar 23 21:09:11.861: //156/36D344F781B1/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Mar 23 21:09:11.861: //157/36D344F781B1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B87A944, Destination Call Id=156, Source Call Id=157,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Mar 23 21:09:11.861: //157/36D344F781B1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4179)
Mar 23 21:09:11.861: //156/36D344F781B1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6755)
Mar 23 21:09:11.861: //156/36D344F781B1/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=156
Mar 23 21:09:11.865: //156/36D344F781B1/CCAPI/cc_api_voice_mode_event:
   Call Id=156
   Call Entry(Context=0x4BE344DC)
Mar 23 21:09:11.865: //157/36D344F781B1/CCAPI/cc_api_voice_mode_event:
   Call Id=157
   Call Entry(Context=0x4BE36CEC)
Mar 23 21:09:11.865: //156/36D344F781B1/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B, Call Id1=156, Call Id2=157
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x4A265E54, Call Id=157
   Call Entry(Responsed=TRUE, Cause Value=18, Retry Count=0)
Mar 23 21:09:22.293: //156/36D344F781B1/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=157
Mar 23 21:09:22.293: //156/36D344F781B1/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B, Tag=0x0
Mar 23 21:09:22.293: //156/36D344F781B1/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=157, Disposition=0x0, Tag=0x0
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=156, Disposition=0x0, Tag=0x0
Mar 23 21:09:22.293: //156/36D344F781B1/CCAPI/cc_generic_bridge_done:
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/ccCallDisconnect:
   Cause Value=18, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=18)
   Cause Value=18, Call Entry(Responsed=TRUE, Cause Value=18)
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Mar 23 21:09:22.297: //156/36D344F781B1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
Mar 23 21:09:22.321: //157/36D344F781B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A265E54, Tag=0x0, Call Id=157,
   Call Entry(Disconnect Cause=18, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Mar 23 21:09:22.321: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 23 21:09:22.321: :cc_free_feature_vsa freeing 4BE12DD0
Mar 23 21:09:22.321:  vsacount in free is 3
Mar 23 21:09:22.321:  vsacount in free is 2
Mar 23 21:09:22.321: //156/36D344F781B1/CCAPI/ccCallDisconnect:
   Cause Value=18, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 23 21:09:22.325: //156/36D344F781B1/CCAPI/ccCallDisconnect:
Mar 23 21:09:22.325: //156/36D344F781B1/CCAPI/cc_api_get_transfer_info:
Mar 23 21:09:32.289: //156/36D344F781B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B87A944, Tag=0x0, Call Id=156,
Mar 23 21:09:32.289: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 23 21:09:32.289: :cc_free_feature_vsa freeing 4BE12EB0
Mar 23 21:09:32.289:  vsacount in free is 1
Mar 23 21:09:32.289:  vsacount in free is 0
Content for Community-Ad
FusionCharts will render here
