CME Call Forward
Jaswild999
I had posted this before, but can't seem to find it under these new forums.  I have a CME that the CFWA feature was working when service was POTS.  They changed to PRI and it has stopped.  Call trace from the carrier shows that on CFWA they are receiving 3 digits.
A manual CFWD works, but not a CFWA programmed on an IP phone.
I am assuming its the dial-peers or telephony configuration.  Please let me know what other information is needed to help me understand why this is failing.
chrs-phx-cme#sh logg
Syslog logging: enabled (0 messages dropped, 10 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 2157 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 1147 message lines logged
Log Buffer (300000 bytes):
Mar 21 02:41:48.689: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=123, Called Number=, Voice-Interface=0x4B40DF0C,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_ANSWER; Calling Number=123
Mar 21 02:41:48.689: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Mar 21 02:41:48.689: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=123T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
Mar 21 02:41:48.689: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=123
Mar 21 02:41:48.689: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=123 Is Matched
   Result=Success(0); Incoming Dial-peer=20011 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20011
Mar 21 02:41:48.689: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Mar 21 02:41:48.689: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6564
Mar 21 02:41:54.533: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=123, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=123
Mar 21 02:41:54.533: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=123, Expanded String=123, Calling Number=
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 21 02:41:54.533: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=123 Is Matched
   Result=Success(0); Outgoing Dial-peer=20011 Is Matched
   Result=Success(0) after DP_MATCH_DEST
Mar 21 02:41:54.533: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:41:54.533: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20011
     2: Dial-peer Tag=123
   dialstring=123, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Mar 21 02:41:54.533: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Mar 21 02:41:59.769: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=117, Called Number=, Voice-Interface=0x4B630BEC,
   Match Rule=DP_MATCH_ANSWER; Calling Number=117
Mar 21 02:41:59.769: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Mar 21 02:41:59.769: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=117T
   Result=-1
Mar 21 02:41:59.769: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=117
Mar 21 02:41:59.769: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=20053 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20053
Mar 21 02:41:59.769: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:41:59.769: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6564
Mar 21 02:42:00.349: //-1/35DD1DF8A678/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=1, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 21 02:42:00.349: //-1/35DD1DF8A678/DPM/dpMatchCore:
   Dial String=1, Expanded String=1, Calling Number=
   Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 21 02:42:00.349: //-1/35DD1DF8A678/DPM/MatchNextPeer:
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=123
   Result=1
Mar 21 02:42:00.353: //-1/35DD1DF8A678/DPM/dpMatchPeersCore:
   Result=Partial Matches(1) after DP_MATCH_DEST
Mar 21 02:42:00.353: //-1/35DD1DF8A678/DPM/dpMatchSafModulePlugin:
   dialstring=1, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Mar 21 02:42:00.353: //-1/35DD1DF8A678/DPM/dpMatchPeersMoreArg:
Mar 21 02:42:00.621: //-1/35DD1DF8A678/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=12, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 21 02:42:00.621: //-1/35DD1DF8A678/DPM/dpMatchCore:
   Dial String=12, Expanded String=12, Calling Number=
Mar 21 02:42:00.621: //-1/35DD1DF8A678/DPM/MatchNextPeer:
   Result=1
Mar 21 02:42:00.621: //-1/35DD1DF8A678/DPM/dpMatchSafModulePlugin:
   dialstring=12, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Mar 21 02:42:00.621: //-1/35DD1DF8A678/DPM/dpMatchPeersMoreArg:
Mar 21 02:42:00.861: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Mar 21 02:42:00.861: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Mar 21 02:42:00.861: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Mar 21 02:42:00.861: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:42:00.861: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Mar 21 02:42:00.865: //-1/35DD1DF8A678/DPM/dpMatchPeersCore:
Mar 21 02:42:00.865: //-1/35DD1DF8A678/DPM/dpMatchCore:
Mar 21 02:42:00.865: //-1/35DD1DF8A678/DPM/MatchNextPeer:
Mar 21 02:42:00.865: //-1/35DD1DF8A678/DPM/dpMatchSafModulePlugin:
   dialstring=123, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
Mar 21 02:42:00.865: //-1/35DD1DF8A678/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Mar 21 02:42:00.869: //-1/35DD1DF8A678/DPM/dpMatchPeersCore:
Mar 21 02:42:00.869: //-1/35DD1DF8A678/DPM/dpMatchCore:
Mar 21 02:42:00.869: //-1/35DD1DF8A678/DPM/MatchNextPeer:
Mar 21 02:42:00.869: //-1/35DD1DF8A678/DPM/dpMatchSafModulePlugin:
Mar 21 02:42:00.869: //-1/35DD1DF8A678/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Mar 21 02:42:00.869: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=123, Called Number=123, Peer Info Type=DIALPEER_INFO_SPEECH
Mar 21 02:42:00.869: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=123, Expanded String=123, Calling Number=123T
Mar 21 02:42:00.869: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Mar 21 02:42:00.869: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:42:00.869: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Calling Number=, Called Number=9602xxx6403, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=96025056403
   Dial String=96025056403, Expanded String=96025056403, Calling Number=
   Result=Success(0); Outgoing Dial-peer=8 Is Matched
   dialstring=96025056403, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
   Calling Number=123, Called Number=, Voice-Interface=0x0,
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=123
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Mar 21 02:42:00.873: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Mar 21 02:42:00.873: //-1/35DD1DF8A678/DPM/dpMatchPeersCore:
Mar 21 02:42:00.877: //-1/35DD1DF8A678/DPM/dpMatchPeersCore:
Mar 21 02:42:00.877: //-1/35DD1DF8A678/DPM/dpMatchCore:
Mar 21 02:42:00.877: //-1/35DD1DF8A678/DPM/MatchNextPeer:
Mar 21 02:42:00.877: //-1/35DD1DF8A678/DPM/dpMatchSafModulePlugin:
   dialstring=123, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Mar 21 02:42:00.877: //-1/35DD1DF8A678/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Mar 21 02:42:00.877: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9602xxxx403, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=9602xxxx403
Mar 21 02:42:00.877: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=96025056403, Expanded String=9602xxxx403, Calling Number=
Mar 21 02:42:00.877: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Mar 21 02:42:00.877: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:42:00.877: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=8
   Result=1
   dialstring=96025056403, saf_enabled=0, saf_dndb_lookup=1, dp_result=1
Mar 21 02:42:00.881: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=96025056403, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=9602xxxx403
Mar 21 02:42:00.881: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Mar 21 02:42:00.881: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=9602xxx403T
   Result=-1
Mar 21 02:42:00.881: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=9602xxxx403
   Dial String=, Expanded String=, Calling Number=9602xxxx403T
Mar 21 02:42:00.881: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=8 Is Matched
Mar 21 02:42:00.885: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:42:00.885: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
Mar 21 02:42:00.885: //-1/36876761A67C/DPM/dpMatchPeersCore:
Mar 21 02:42:00.885: //-1/36876761A67C/DPM/dpMatchCore:
Mar 21 02:42:00.885: //-1/36876761A67C/DPM/MatchNextPeer:
Mar 21 02:42:00.885: //-1/36876761A67C/DPM/dpMatchSafModulePlugin:
   dialstring=96025056403, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Mar 21 02:42:00.885: //-1/36876761A67C/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
Mar 21 02:42:00.889: ISDN Se0/3/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 117
Mar 21 02:42:00.893: ISDN Se0/3/0:23 Q931: Sending SETUP  callref = 0x01A3 callID = 0x8124 switch = primary-ni interface = User
Mar 21 02:42:00.893: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8  callref = 0x01A3
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9838A
                Exclusive, Channel 10
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x0080, '117'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xA1, '602xxxx403'
                Plan:ISDN, Type:National
        Redirecting Number i = 0x00008F, '123'
Mar 21 02:42:00.917: ISDN Se0/3/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x81A3
Mar 21 02:42:01.017: ISDN Se0/3/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x81A3
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Mar 21 02:42:01.021: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=117, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=117
Mar 21 02:42:01.021: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=117, Expanded String=117, Calling Number=
Mar 21 02:42:01.021: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20053 Is Matched
Mar 21 02:42:01.021: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:42:01.021: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20053
   Calling Number=, Called Number=602xxxx403, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=602xxxx403
   Dial String=6025056403, Expanded String=602xxxx403, Calling Number=
   Result=-1
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Mar 21 02:42:01.025: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:42:01.025: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
Mar 21 02:42:01.025: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Mar 21 02:42:01.025: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
   dialstring=6025056403, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1
Mar 21 02:42:01.025: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Mar 21 02:42:01.401: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Mar 21 02:42:01.401: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Mar 21 02:42:01.401: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Mar 21 02:42:01.401: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 21 02:42:01.401: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=8
Mar 21 02:42:05.893: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x01A3
        Cause i = 0x8090 - Normal call clearing
Mar 21 02:42:05.917: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x81A3
Mar 21 02:42:05.917: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x01A3
chrs-phx-cme#
Here is the telephony:
telephony-service
 sdspfarm units 2
 sdspfarm tag 2 DSPprofile2
 conference hardware
 authentication credential admin cisco
 max-ephones 58
 max-dn 192
 ip source-address 192.168.0.8 port 2000
 auto assign 100 to 150
 timeouts interdigit 5
 system message Making A Difference!
 url services http://192.168.0.9/voiceview/common/login.do
 url authentication http://192.168.0.8/CCMCIP/authenticate.asp
 cnf-file location flash:
 load 7912 CP7912080004SCCP080108A.sbin
 load 7960-7940 P00308010200.loads
 load 7941 SCCP41.9-1-1SR1S.loads
 load 7970 SCCP70.9-1-1SR1S.loads
 time-zone 7
 voicemail 777
 mwi relay
 max-conferences 4 gain -6
 web admin system name admin secret 5 $1$Y5fU$YqKVbGIBzQ/YDVFr9QglP0
 transfer-system full-consult
 transfer-pattern .T
 secondary-dialtone 9
 directory last-name-first
Here are the dial-peers:
dial-peer voice 10 voip
 destination-pattern 778
 session protocol sipv2
 session target ipv4:192.168.0.9
 codec g711ulaw
 no vad
dial-peer voice 11 voip
 destination-pattern 779
 codec g711ulaw
 no vad
dial-peer voice 777 voip
 description Cisco Unity Express voicemail pilot number
 destination-pattern 777
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 776 voip
 description Cisco Unity AA
 destination-pattern 776
 codec g711ulaw
 no vad
dial-peer voice 775 voip
 description Cisco Unity AA-admin
 destination-pattern 775
 codec g711ulaw
 no vad
dial-peer voice 443 pots
 destination-pattern 443
 port 0/1/3
 forward-digits 0
dial-peer voice 444 pots
 description Bogen Paging Adapter
 service stcapp
 port 0/2/0
dial-peer voice 5 pots
 description inbound PRI DP
 translation-profile incoming from_pri
 incoming called-number .
 port 0/3/0:23
 no sip-register
dial-peer voice 8 pots
 description PRI
 preference 1
 destination-pattern 9T
 port 0/3/0:23
 no sip-register
19 Replies 19
Most likely, your Telco requires the redirecting number to be a valid DID assigned to your PRI. You need to use translation rules to change it from a four digits extension to a DID. Here is an exemple how to make this happen:
voice translation-rule 1
rule 1 /.*/ /XXXXXXXXXX/
  (where XXXXXXXXX is a valid DID on the PRI, exemple: main number)
voice translation-profile ReplaceRedirect
translate redirect-called 1
Apply the translation rule to your outgoing dial-peers:
dial-peer voice Y pots
translation-profile outgoing ReplaceRedirect
Please rate helpful answers!
could you please try configuring 'call-forward pattern .T' under telephony-service and check?
//Suresh
Please rate all the useful posts
//Suresh Please rate all the useful posts.
I had actually removed that command, I have placed it back.  Does not make any difference.  Thank you.
Kevin Monteiro
Level 7
Level 7
No luck.  Still says, "Call can not be completed as dialed".
    Console logging: level debugging, 580 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 587 messages logged, xml disabled,
                    filtering disabled
    Trap logging: level informational, 290 message lines logged
Mar 23 21:09:11.061: //-1/36D344F781B1/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=888
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Mar 23 21:09:11.065: //-1/36D344F781B1/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4B87A944, Call Info(
   Calling Number=888,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20056, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 23 21:09:11.065: //-1/36D344F781B1/CCAPI/ccCheckClipClir:
   In: Calling Number=888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 23 21:09:11.065: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 23 21:09:11.065: :cc_get_feature_vsa malloc success
Mar 23 21:09:11.065:  cc_get_feature_vsa count is 1
Mar 23 21:09:11.065: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273047416,feature_id:206
Mar 23 21:09:11.065: //156/36D344F781B1/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Mar 23 21:09:11.065: //156/36D344F781B1/CCAPI/cc_process_call_setup_ind:
   Event=0x495F0470
Mar 23 21:09:11.065: //156/36D344F781B1/CCAPI/ccCallSetContext:
   Context=0x4BE344DC
   >>>>CCAPI handed cid 156 with tag 20056 to app "_ManagedAppProcess_Default"
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/ccCallSetupAck:
   Call Id=156
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=156
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/ccCallReportDigits:
   (callID=0x9C, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=156
Mar 23 21:09:11.069: //156/36D344F781B1/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4B87A944, callID=0x9C, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x4B87A944, Call Id=156
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
Mar 23 21:09:11.269: //156/36D344F781B1/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=156, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x30958, Rtp Expiration=0x0
Mar 23 21:09:11.269: //156/36D344F781B1/CCAPI/cc_api_call_digit_end:
   Source Call Id=156, Digit=1, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Mar 23 21:09:11.469: //156/36D344F781B1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=156, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x38658, Rtp Expiration=0x0
Mar 23 21:09:11.469: //156/36D344F781B1/CCAPI/cc_api_call_digit_end:
   Source Call Id=156, Digit=2, Duration=100,
Mar 23 21:09:11.669: //156/36D344F781B1/CCAPI/cc_api_call_digit_begin:
   Source Call Id=156, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0x40358, Rtp Expiration=0x0
Mar 23 21:09:11.669: //156/36D344F781B1/CCAPI/cc_api_call_digit_end:
   Source Call Id=156, Digit=3, Duration=100,
Mar 23 21:09:11.673: //156/36D344F781B1/CCAPI/ccCallReportDigits:
   (callID=0x9C, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 23 21:09:11.673: //156/36D344F781B1/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x4B87A944, callID=0x9C, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 23 21:09:11.673: //156/36D344F781B1/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Mar 23 21:09:11.677: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=123
Mar 23 21:09:11.677: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=123, Called Number=123, Calling Number=888, Calling DN=432 Calling Id=156,
   Redirect Number=919155269001, Redirect Reason=15
Mar 23 21:09:11.677: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 23 21:09:11.677: :cc_get_feature_vsa malloc success
Mar 23 21:09:11.681:  cc_get_feature_vsa count is 2
Mar 23 21:09:11.681: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 23 21:09:11.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048312,feature_id:207
Mar 23 21:09:11.681: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Mar 23 21:09:11.681:  feature_vsa is 4BE12970,featname is 0
Mar 23 21:09:11.681: :cc_get_feature_vsa malloc success
Mar 23 21:09:11.681:  cc_get_feature_vsa count is 3
Mar 23 21:09:11.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048760,feature_id:208
Mar 23 21:09:11.681: : Generating new featurevsa,inserting it
Mar 23 21:09:11.681:  feature call forward featname is 1
Mar 23 21:09:11.681: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 23 21:09:11.681: :cc_free_feature_vsa freeing 4BE12CF0
Mar 23 21:09:11.681:  vsacount in free is 2
Mar 23 21:09:11.681: //156/36D344F781B1/CCAPI/ccCallForwardTo:
   Call Forward Number=919155269001, Call Forward Cause Reason=15, Call Id=156
Mar 23 21:09:11.681: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048312,feature_id:209
Mar 23 21:09:11.685: :cc_free_feature_vsa freeing 4BE12CF0
Mar 23 21:09:11.685: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 23 21:09:11.685:  vsacount in free is 2
Mar 23 21:09:11.685: //156/36D344F781B1/CCAPI/ccCallForwardTo:
Mar 23 21:09:11.685: //156/36D344F781B1/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=8, Params=0x4BE36D3C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 23 21:09:11.685: //156/36D344F781B1/CCAPI/ccCheckClipClir:
Mar 23 21:09:11.689: //156/36D344F781B1/CCAPI/ccCallSetupRequest:
   Destination Pattern=9T, Called Number=91915xxxx001, Digit Strip=TRUE
   Called Number=919155269001(TON=Unknown, NPI=Unknown),
   Redirect Number=123, Display Info=Wilder
   Account Number=, Final Destination Flag=FALSE,
   Guid=37327A6D-B206-11E3-81B5-8869F94C78DE, Outgoing Dial-peer=8
Mar 23 21:09:11.689: //156/36D344F781B1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=888
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=91915xxxx001
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=123
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=15   fwd_final_type =0
Mar 23 21:09:11.689: //156/36D344F781B1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4A265E54, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=888,(Calling Name=Wilder)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=91915xxxx001(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=8, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 23 21:09:11.689: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 23 21:09:11.689: :cc_get_feature_vsa malloc success
Mar 23 21:09:11.689:  cc_get_feature_vsa count is 3
Mar 23 21:09:11.689: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048312,feature_id:210
Mar 23 21:09:11.689: //157/36D344F781B1/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Mar 23 21:09:11.689: //157/36D344F781B1/CCAPI/ccCallSetContext:
   Context=0x4BE36CEC
Mar 23 21:09:11.689: //156/36D344F781B1/CCAPI/ccSaveDialpeerTag:
Mar 23 21:09:11.689: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Mar 23 21:09:11.689:  feature call forward featname is 1
Mar 23 21:09:11.689:  feature_vsa is 4BE12CF0,featname is 0
Mar 23 21:09:11.689:  cc_get_feature_vsa count is 4
Mar 23 21:09:11.689: :FEATURE_VSA attributes are: feature_name:0,feature_time:1273048536,feature_id:211
Mar 23 21:09:11.689: : Generating new featurevsa,inserting it
Mar 23 21:09:11.729: //157/36D344F781B1/CCAPI/cc_api_call_proceeding:
   Interface=0x4A265E54, Progress Indication=NULL(0)
Mar 23 21:09:11.857: //157/36D344F781B1/CCAPI/cc_api_call_cut_progress:
   Interface=0x4A265E54, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/ccConferenceCreate:
   (confID=0x4BDFD374, callID1=0x9C, gcid=36D344F7-B20611E3-81B18869-F94C78DE, tag=0x0)
Mar 23 21:09:11.857: //157/36D344F781B1/CCAPI/ccConferenceCreate:
   (confID=0x4BDFD374, callID2=0x9D, gcid=36D344F7-B20611E3-81B18869-F94C78DE, tag=0x0)
   Conference Id=0x4BDFD374, Call Id1=156, Call Id2=157, Tag=0x0
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B, Source Interface=0x4B87A944, Source Call Id=156,
   Destination Call Id=157, Disposition=0x0, Tag=0xFFFFFFFF
Mar 23 21:09:11.857: //157/36D344F781B1/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B, Source Interface=0x4A265E54, Source Call Id=157,
   Destination Call Id=156, Disposition=0x0, Tag=0xFFFFFFFF
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1B, Destination Call Id=157)
   Call Entry(Conference Id=0x1B, Destination Call Id=156)
Mar 23 21:09:11.857: //156/36D344F781B1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4A265E54, Destination Call Id=157, Source Call Id=156,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Mar 23 21:09:11.861: //156/36D344F781B1/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Mar 23 21:09:11.861: //157/36D344F781B1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4B87A944, Destination Call Id=156, Source Call Id=157,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Mar 23 21:09:11.861: //157/36D344F781B1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4179)
Mar 23 21:09:11.861: //156/36D344F781B1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6755)
Mar 23 21:09:11.861: //156/36D344F781B1/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=156
Mar 23 21:09:11.865: //156/36D344F781B1/CCAPI/cc_api_voice_mode_event:
   Call Id=156
   Call Entry(Context=0x4BE344DC)
Mar 23 21:09:11.865: //157/36D344F781B1/CCAPI/cc_api_voice_mode_event:
   Call Id=157
   Call Entry(Context=0x4BE36CEC)
Mar 23 21:09:11.865: //156/36D344F781B1/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B, Call Id1=156, Call Id2=157
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/cc_api_call_disconnected:
   Cause Value=18, Interface=0x4A265E54, Call Id=157
   Call Entry(Responsed=TRUE, Cause Value=18, Retry Count=0)
Mar 23 21:09:22.293: //156/36D344F781B1/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=157
Mar 23 21:09:22.293: //156/36D344F781B1/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B, Tag=0x0
Mar 23 21:09:22.293: //156/36D344F781B1/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=157, Disposition=0x0, Tag=0x0
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=156, Disposition=0x0, Tag=0x0
Mar 23 21:09:22.293: //156/36D344F781B1/CCAPI/cc_generic_bridge_done:
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/ccCallDisconnect:
   Cause Value=18, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=18)
   Cause Value=18, Call Entry(Responsed=TRUE, Cause Value=18)
Mar 23 21:09:22.293: //157/36D344F781B1/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Mar 23 21:09:22.297: //156/36D344F781B1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
Mar 23 21:09:22.321: //157/36D344F781B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4A265E54, Tag=0x0, Call Id=157,
   Call Entry(Disconnect Cause=18, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Mar 23 21:09:22.321: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 23 21:09:22.321: :cc_free_feature_vsa freeing 4BE12DD0
Mar 23 21:09:22.321:  vsacount in free is 3
Mar 23 21:09:22.321:  vsacount in free is 2
Mar 23 21:09:22.321: //156/36D344F781B1/CCAPI/ccCallDisconnect:
   Cause Value=18, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 23 21:09:22.325: //156/36D344F781B1/CCAPI/ccCallDisconnect:
Mar 23 21:09:22.325: //156/36D344F781B1/CCAPI/cc_api_get_transfer_info:
Mar 23 21:09:32.289: //156/36D344F781B1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4B87A944, Tag=0x0, Call Id=156,
Mar 23 21:09:32.289: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 23 21:09:32.289: :cc_free_feature_vsa freeing 4BE12EB0
Mar 23 21:09:32.289:  vsacount in free is 1
Mar 23 21:09:32.289:  vsacount in free is 0
