03-29-2016 03:31 PM - edited 03-17-2019 06:23 AM
I trying to park some call but is not working i receive a message at the IP Phone that the park destiny is not available
My config:
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 3
sdspfarm tag 1 CONFER
sdspfarm tag 2 XCODEC
conference hardware
conference transfer-pattern
video
max-ephones 20
max-dn 250
ip source-address 192.168.10.2 port 2000
service directed-pickup gpickup
timeouts interdigit 5
system message HomeLab
cnf-file location flash:
user-locale U1 load CME-locale-pt_BR-Portuguese-10.5.3.0.tar
load 8941 SCCP894x.9-2-2-0.loads
load 8945 SCCP894x.9-2-2-0.loads
time-zone 17
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-park system application
call-forward pattern .T
moh enable-g711 "flash:music-on-hold.au"
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
ephone-dn 200
number 4001
park-slot directed timeout 20 limit 5
description ***ParkSlot01***
name ParkSlot
ephone-dn 201
number 4002
description ***ParkSlot02***
name ParkSlot
Leonardo Santana
Solved! Go to Solution.
03-29-2016 04:45 PM
The title of your post says Pickup but appears you are having issues with Call Park.
According to your configuration you have configured the Directed Call Park not the basic call park.
The process to park the call for directed call park is by pressing the transfer key and then transferring the call to the park extension (4001 or 4002) and to retrieve call you have to press a fac standard or custom which you need to configure.
Refer to this document and look for directed call park if you want to configure directed call park or the basic call park: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmepark.pdf
-Terry
Please rate all helpful posts
03-29-2016 04:45 PM
-Terry
03-29-2016 07:17 PM
Hello Terry,
Now its working.
ephone-dn 201
number 4002
name ParkSlot
ephone-dn 200
number 4001
park-slot timeout 10 limit 5 recall retry 2 limit 2
name ParkSlot
ephone-dn 201
number 4002
name ParkSlot
i´m using the basic call park.
Leonardo Santana
03-29-2016 07:20 PM
Thanks for the update Leonardo - glad to know its working.
See you around.
-Terry
