ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
CME CALL TRANSFERT
I've install a uc 500 and I would like to know if I can transfer my calls to my mobile so when there is a call from my position outside it is redirected to my mobile
2 REPLIES 2
Highlighted
Hall of Fame Master
Re: CME CALL TRANSFERT
Yes, absolutely. You only need to configure a transfer-pattern under telephony-service for the numbers you want to allow be transferred to.
Highlighted
in the config I learn these transfer-pattern I think it is sufficient but it does not
transfer-system full-consult dss
transfer-pattern .T
transfer-pattern 8...
transfer-pattern 7777
transfer-pattern 0.T
transfer-pattern 783..
secondary-dialtone 0
directory last-name-first
