Hi Guys
I have a requirement to set some specific rules on outgoing caller ID.
1. Calls from EXT 2900 -> 2949 (External caller ID blocked, internal calls not blocked)
2. Calls from EXT 2950 ->2999 (NO blocking at all send one fixed caller ID of XXXX2950)
Using translation rules we've been able to achieve this (of sorts) by sending a NULL number on matches to 2900 -> 2949
However the carrier does not block and sends the default. Note on a CLID strip that ISDN Q931 codes for caller ID are different.
CLID Strip
Calling Party Number i = 0x01C3, N/A
NULL
Calling Party Number i = 0x0180, N/A
Does anyone know how to actually make htis work?
Cheers
Mike
