CME Caller ID Name PRI
ouhakheme
Level 3
Level 3
Hello --
I have a CME with a new PRI. The Q931 Debug shows all of the caller-id name information; however, the name is not being displayed on the phones, only the number.
Is there anything I can do to bring the name to the phone?
Thanks.
Ohamien
14 Replies 14
thisisshanky
Level 11
Level 11
Ohamien,
Are you able to send display information outbound ?
Try the following commands.
int s0/0/0:23
isdn outgoing display-ie
isdn supp-service name calling
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a008041f237.html#wp1090859
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
paolo bevilacqua
That is strange. What switch type ? In which facility is the name encoded (see debug) ?
Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02010106072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 1
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, 'XXXXXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '7515'
Plan:Unknown, Type:Unknown
May 10 2007 16:14:59.858 EDT: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x004F
Facility i = 0x9F8B0100A117020101020100800F5548414B48454D45204F48414D4945
0xA117020101020100800F5548414B48454D45204F48414D4945
Invoke Id = 1
Operation = CallingName
Name presentation allowed
Name = UHAKHEME OHAMIE
Switchtype NI
Please try:
voice service voip
qsig decode
Isn't that for outbound only? I'm worried about inbound.
Thanks.
any benefit configuing qsig decode as per above? The switch is using the convoluted method instead of the basic display IE.
No dice.
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Invoke Id = 1
Calling Party Number i = 0x2183, '4078977377'
Called Party Number i = 0x80, '4800'
May 11 2007 09:09:04.678 EDT: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x806D
May 11 2007 09:09:04.710 EDT: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x806D
Facility i = 0x9FAA068001018201018B0100A1090202024C0201018000
0x010182
0x01018B
0x0100
0xA1090202024C0201018000
Component = Invoke component, Unsupported operation
May 11 2007 09:09:04.734 EDT: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x806D
Facility i = 0x9FAA068001018201018B0100A1090202024D0201028000
0x010182
0x01018B
0x0100
0xA1090202024D0201028000
May 11 2007 09:09:04.738 EDT: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8 callref = 0x006D
Cause i = 0x80E31C - Information element not implemented
Call State i = 0x07
Not sure. With qsig decode, the logic is different. The decoding stops as the "subsequent facility" is never decoded. Other change, the router tries now to supply his own qsig info that the switch refuses. The calling name information on the other hand was easily available in the previous test and should have been copied to call leg attributes.
Would you, for a try, configure switch qsig. Perhaps this would allow the logic to carry on and make the calling name available.
Well for some reason, it wasn't getting the caller id information from my office phone. I know that we are sending caller id name, because they got it with the FXO lines. The following is a debug from my cell phone with the name information if that will make a difference.
Standard = CCITT
Channel ID i = 0xA98382
Exclusive, Channel 2
Invoke Id = 1
May 11 2007 10:38:49.785 EDT: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x0079
Invoke Id = 1
May 11 2007 10:38:49.801 EDT: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8079
May 11 2007 10:38:49.833 EDT: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8079
Facility i = 0x9FAA068001018201018B0100A1090202028E0201018000
0x010182
0x01018B
0x0100
0xA1090202028E0201018000
May 11 2007 10:38:49.861 EDT: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x8079
Facility i = 0x9FAA068001018201018B0100A1090202028F0201028000
0x010182
0x01018B
0x0100
0xA1090202028F0201028000
May 11 2007 10:38:49.865 EDT: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8 callref = 0x0079
Call State i = 0x07
Also, can I set the switch-type to qsig without breaking the circuit? The carrier is set to NI.
Tnanks again,
I changed the type to qsig and it didn't make any difference.
Any other ideas?
Ohamien
I would try upgrade to a latest maintenance, then ask the TAC to look at this. The name is available and not copying it to call legs looks like be a plain bug.
I needed the 'isdn supp-service name calling' command from earlier, but the problem lied with the AA. The call was being sent to the AA and forwarded back to the phone. If I called a phone directly using this command, it would have probably been fine.
The problem lied with SIP taking the call for the AA after the first facility message and not waiting for the second message to come though.
I added the following command:
sip-ua
timers buffer-invite 500
That will buffer the invite message for another 500ms before the AA accepts the call; thus solving my problem.
Thanks for all of your help!
Good info. Had you said before that there is AA in between, or had timestamps in debug, one could have thought about that before :)
Thanks for letting us know and good luck.
Fair enough. I had to limit the debug text because of the forum limits, and I even forgot about the AA because the phone was ringing during business hours.
No worries, it's all good, just glad that there was such an interest.
