01-21-2016 07:26 AM - edited 03-17-2019 05:35 AM
Hi all. my problem it's more simple (I think).
I ve a cme with two ISDN
EAch ISD have two numbers 0444921667 and 0444831995
I've two phone with extension 300 and 301
I need a following feature:
when i make an external call using exension 300 the remote will see the caller ID 0444921667
when i make an external call using exension 301 the remote will see the caller ID 0444831995
each one can help me to do this?
thanks in advance
01-21-2016 11:00 AM
create a translation rule on CME and apply on calling party number on the outgoing dial-peer
voice translation-rule 1
rule 1 /300/ /0444921667/
rule 2 /301/ /0444831995/
voice translation-profile OUT
translate calling 1
dial-peer voice XX pots
translation-profile outgoing OUT
Nadeem Ahmed
d
01-21-2016 01:06 PM
I've already configured the translation, but it doesn't works....
01-21-2016 01:09 PM
do you mind sending the show run from CME and along with debugs
enable below debugs and make one test call
debug voice ccapi inout
debug translation detail
debug isdn q931
Br,
nadeem
01-21-2016 03:32 PM
You may want to look at this. This is more for FXO but it may work for your case as well.
https://supportforums.cisco.com/discussion/10805311/cme-external-phone-number-mask
-Deven Gandhi
*Please rate all useful post
