CME Callfeature long-dur-duration
Marwan Urabi
Beginner
Beginner
Good day,
I'm tested to configure callfeature long-dur-duration under specific dial-peer as follows :-
dial-peer voice 1201 pots
paramspace callfeature long-dur-duration 3
paramspace callfeature long-dur-action disconnect
paramspace callfeature long-dur-call-mon enable
paramspace callfeature long-dur-disc-cause 16
but the problem all incoming / outgoing call disconnect after 3 min not match dial-peer , I try also under
application :
application
package callfeature
param long-dur-disc-cause 16
param long-dur-duration 3
param long-dur-action disconnect
param long-dur-call-mon enable
but also it's same problem , how can I active only outgoing call for specific dial-peer only I use CME v.10.5
second problem is lpcor , can some one provide simple example to use in specific FXO port and specific dial-peer.
Thank you
Marwan Urabi
6 Replies 6
Nipun Singh Raghav
Any call using the dial-peer will inherit the configuration irrespective of the fact whether it is incoming or outgoing.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Thanks ok I agree with you it’s for incoming and outgoing dial-peer match the problem the restrictions become to all calls not just the dial-peer match same as when you buy it separately under application section .
Post a “show run”.
Nipun Singh Raghav
this config at my side .
trunk group Orange
 carrier-id **Orange**
 hunt-scheme sequential both
trunk group Zain
 carrier-id **Zain**
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
 codec preference 5 ilbc
 video codec h264
voice class codec 2
 codec preference 1 g729r8
 codec preference 3 g711ulaw
 codec preference 4 g711alaw
 video codec h264
voice class custom-cptone Orange-Jordan
 dualtone disconnect
  frequency 420
  cadence 250 250
voice class custom-cptone Zain-Jordan
 dualtone disconnect
  frequency 425
  cadence 400 400
voice class dualtone-detect-params 1
 freq-max-deviation 25
 freq-max-power 0
 freq-min-power 13
 freq-power-twist 4
 cadence-variation 4
application
 package callfeature
  param long-dur-duration 120
voice-port 0/0/1
 trunk-group Orange 1
 translation-profile incoming PSTN-Fix-CallerID
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone Jordan
 supervisory dualtone-detect-params 1
 cptone BR
 timeouts call-disconnect 2
 timeouts ringing 5
 timeouts wait-release 1
 timing hookflash-out 50
 timing guard-out 1000
 timing sup-disconnect 100
 connection plar opx 612
 description **Line 2 **
 caller-id enable
 caller-id alerting line-reversal
 caller-id alerting dsp-pre-allocate
voice-port 0/0/2
 trunk-group Zain 1
 supervisory custom-cptone Zain-Jordan
 cptone JO
 timeouts ringing 5
 connection plar opx 611
 description **Zain 1St Line**
 caller-id enable
dial-peer voice 1103 pots
 trunkgroup Orange
 corlist outgoing pt-call-national
 description ** National Jordan **
 translation-profile outgoing PSTN_Outgoing
 preference 2
 destination-pattern (0)%[2,3,5].......
 forward-digits all
 no sip-register
 trunkgroup Zain
 corlist outgoing pt-call-mobile
 description ** Zain Mobile **
 preference 1
 destination-pattern (0)%79.......
 forward-digits all
 no sip-register
*** all incoming and outgoing disconnect after 3 min even I delete the application package callfeature
      the same issue they don't take action only from the dial-peer .
the logic say at this example the CME should disconnect all calls after 120 min in general and disconnect call from/to (0)%79....... after 3 min
regards
Ok. Can you remove the configuration on 1201 DP and leave the global application in place and then test dialing number for "(0)%[2,3,5]" pattern and let me know the behavior ?
Nipun Singh Raghav
at global config under application it's take action for incoming / outgoing VoIP or pots dial-peer even between local extension under CME so all calls disconnect after long-dur-duration reach.
on the other hand if you remove from application package callfeature and keep it only under
dial-peer there is no action at incoming or outgoing .
and if you keep at both side and example under application is set to 1 Min and under dial-peer set to 2 Min it's disconnect after 1 Min
Recognize Your Peers
