CME - can not dail PSTN (out going calls )
aslam.bajwa
Level 3
Level 3
hello ,
i have CME installed on 2900 router , incomming calls are working fine but i can dial PSTN calls.
below error is comming in Debug:
Outgoing call from gateway: gives diconnect cause value = 34 no circuit
6 Replies 6
Kevin Monteiro
Level 7
Level 7
Is there a PRI or FXO?
Sent from Cisco Technical Support Android App
Thanks for you reply ,
it is PRI
MUDIT MATHUR
Hi Aslam,
1.Could you please explain the complete network topology and please upload the debugs that you collected with the called and the calling number.Also attach the relevant controller config, serial interface config, dial-peer etc to analyze.
2.Cause value 34 implies that there is a mismatch in channel mapping either on your end or the provider's end.
3.So we need to check if we are sending this error message or if we are receiving this error message.
If we are receiving this error message, then provider needs to correct the channel mapping on their end.
4.If we are using H323 then try to change the isdn channel order using this command on gateway
"isdn bchan-number-order" as well as try changing the channel order from under the gateway on CUCM, if we have a CUCM in the network topology.
5.Make sure we have configured only those channels that we are allowed to inside a Controller for pri group command.
Thanks & Regards,
Mudit Mathur
Thanks & Regards, Mudit Mathur
Kevin Monteiro
Level 7
Level 7
Aslam can u attache the debug:
Debug VoIP ccapi input
Debug ISDN q931
Kevin
moataz_mamdouh
Use bchan order command
islam.kamal
Level 10
Level 10
Hi Aslam
1- I hope to share with us : debug isdn Q931.
2-What about the incoming calls?. aslo share debug isdn q931
3-copy of the configuation
Can you try the below command under yourinterface also:-
interface Serial0/0/1:15
isdn bchan-number-order ascending
Please rate all useful information
