CME Challenge
haroun.rasheed
Can any one suggest how to implement the below requirement
1) Particular extensions should have option to dial 0 (zero) to call mobile and they should enter password when they dial the zero digit.
Jaime Valencia
COR + FAC
FAC UC500
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd45262
The other usual option is as Paolo mentions "use after-hours and PIN login"
Plenty of posts on the matter, if you require more info search NetPro.
java
if this helps, please rate
java
dont get it can you please post me the links that can help.
